ISO and for trade thread part 5
#3876
Hello all, I'm after a few goodies to complete my new to me unknown frame with DA groupset.
Dura Ace crank dust caps, and toe clips to fit these pedals, don't have to be DA, just something that will work
B and P axle plastic bushings, or a complete DA derailleur for parts. This one has play due to worn and broken bushings.
Not sure what it's called, but I'm after this adjuster collar, the tab or ear broke off
Friction shifters to go with DA 7200 2x6. These are indexed, and work, but looking to match more closely to original. Open to suggestions.
And lastly, I'm after a stem for a 22.2 headset, not sure of technical specs I'm after, but I don't want a riser, and I want a shorter reach. I'd also like if I could get a bar that matches the stem bar clamp as a package, even better if it's a Randonneur bar. Open to suggestions again. These are what I'm after the most, as the bike is fully rideable as is, but the bars are bent slightly, and I really dislike this stem.
Here's a bonus pic of the whole bike with a vintage-ish chariot
The bars and stem are what I'm after the most, all the rest would be a bonus.
#3877
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
In that case I definitely has a spare set.
I’ll get you some pictures later today.
Edited to add:
Welp, that was a bit of a disappointment. Rust and missing or broken bits.
I think another BFer threw these into a shipment when I purchased something else.
The shifter levers are in good shape and the Dura Ace labeled cover are fair to good.
All you see is yours for the cost of shipping if you want to try to cobble together the missing bits from your local coop. Here’s the parts diagram from Disraeli Gears.
Edited to add:
#3879
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
I also have an Early DA RD like yours but it's not "broken" except for a very weak cage spring (which I figured to be repairable, someday, but never got into it) This one has the "push-button" cage and says "Max 26 teeth" on the cage. LMK if you're interested.
EDIT per VeloBase this is the last version of the EX RD and had a few improvements:
https://velobase.com/ViewComponent.as...=108&AbsPos=73
#3880
ISO a hefty 26" rear wheel. Prefer 36 or more spokes and a 135mm shimano cassette hub. I have lots to trade.
Likes For dweenk:
#3882
Stronglight A9 Bearing Shield
Looking for the thin shield that goes on top of the needle bearings. It is larger than the shield that goes on the bottom.
Found it in the grease of the cup. The old park was like soap and when I cleaned it out, there it was.
Thanks for the offer of help.
#3883
Liked 1,064 Times
Those are the actual "races" that the bearings ride on, since they are steel and all the SL A-9 cups are soft alloy. What you want is the "outer" race: does it need to be perfect condition (I may have one to offer that's had some wear)?
#3884
Thanks. I was wondering what it’s name is. Doesn’t need to be perfect just rideable.
#3885
Quoted: 887 Post(s)
Liked 335 Times
ISO or HTT
I have an ESGE silver plastic front fender about 44mm wide. It is very close in appearance to SKS in the same size. I am looking for a rear - ESGE or SKS.
I have stuff to trade.
#3887
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
i have a couple of rando bars and at least one stem to match either. SR custom on both counts. 39cm from end to end on the bars and 80mm reach stem/s. all from early 80's univega touring bike/s. interested in anything?
#3888
Thank You for the offer. This forum is awesome.
#3889
Quoted: 1106 Post(s)
Liked 1,328 Times
And of course a subset of that set have bins full of potential puzzle-completing orphan parts, we know and love each one.
Likes For oneclick:
#3890
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
The reverse happened to me with a SunTour stem. I sold it without the little logo button in front. Weeks (maybe months?) later I cleaned my bench and there it was in a little parts box. Sent it along to complete the stem.
This forum is one of the greatest expressions of “what goes around, comes around.” You only get what you give.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Likes For mountaindave:
#3891
Bikes: 1975 Motobecane LeChampion (silver lilac), 1974 Motobecane Grand Jubile (red/black); 1975 Motobecane Team Champion (orange); 1982 Pinarello Professional (Exorcist Green); 1974 Raleigh Professional MkIV mink blue, 1974 Motobecane Grand Record blk/red
Quoted: 103 Post(s)
Liked 750 Times
ISO Huret Jubilee front and Campy non drive arm
Hi folks, I am in search of:
1. Huret Jubilee front derailleur
2. Campy non-drive side crank arm, 170mm, prefer a 3 in diamond (73) or thereabouts
PM if you have these, and many thanks
Andy
Arvada, CO USA
Andy
Arvada, CO USA
#3892
Liked 1,064 Times
Okay so if anybody else needs an A-9 outer race I do have a spare, it's in pretty good condition (not new but I would not hesitate to use it myself) and ready to mail (I figure 2 stamps will do it to CONTUS).
That "free for postage" deal is open to the first to claim it.
Otherwise it goes back into the HS parts pile.
#3893
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
ISO: A Park HTS-1. The almighty headtube straightener of many lawyerisms.
I used to have one years ago, and in a weak moment, got rid of it. Also open to borrowing one if the owner is OK with it - just be advised that it'll be going up against the toughest Raleigh frame I've ever dealt with: https://www.bikeforums.net/classic-v...l#post22047034
-Kurt
-Kurt
#3894
Quoted: 566 Post(s)
Liked 1,053 Times
Schwinn Super Sport fork
I won’t charge you too much to take it off your hands. 🙂 Straight, no heavy rust and not heavily road rashed please.
Actually - any fork of the same size is fine. Steerer needs to be at least 7.5” and if you had the headset that would be appreciated.
#3895
Quoted: 288 Post(s)
Liked 330 Times
-Kurt
-Kurt
#3896
Liked 4,396 Times
-Kurt
#3897
Quoted: 288 Post(s)
Liked 330 Times
In fact, I was able to straighten the frame without the HTS-1 (but I'm still going to leave the feelers out for one). However, it turns out the frame is also bent to the side, so it looks as if I willhave to make use of some fun framebuilding tools pretty soon.
-Kurt
-Kurt
Likes For jethin:
#3898
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times
Anyone out there up for trading canti brakes?
Have a well-preserved set of Deore BR-MC70 (i think these are part of deerhead?) to offer up, and I'm hunting for DiaCompe 981.
#3899
Liked 4,396 Times
-Kurt
#3900
Liked 4,396 Times
