Show Your "American Builders Only" Steel Rides
#551
Quoted: 4512 Post(s)
Liked 6,388 Times
^^^ Those look like stout fork legs, seat stays seem so as well or at least not less than.
#552
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I need to stop spending money on it but here's the Bruce Gordon in hopefully its final form short of a new stem.
Since the last picture:
New rear derailleur
New shifters
New brake levers
New wheels
New front rack
New v-brakes
New seat post
Most is used but new to that bike
Likes For Germany_chris:
#553
Liked 6,388 Times
bikemig
Tx for the like, not sure if you saw, here's the build thread.
https://www.bikeforums.net/classic-v...-decide-5.html
#554
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
Here's my contribution - a 2016 Nobilette.
I spent many years collecting parts for what would be my "ultimate" bike, financing them almost entirely by selling stuff on eBay. As far a ride quality and handling, I knew I wanted the new bike to match my favorite vintage ride, a '78 Andre Bertin C35. To that end, with the help of an ace bike mechanic friend of mine we carefully measuresed and re-measured the Bertin. The only nod to modernity is that the top tube slopes up 1.5 degrees, so that I can get the bars up where my aged back needs them to be.
There were a few builders on my short list, but I decided to go with Mark Nobilette because he seemed like he'd be easy to work with, his prices were reasonable, and his waiting list wasn't years long. I'm sure most of you are familiar with Mark, but just in case, here's a quick bio: He attended one of Albert Eisentraut's first frame building classes (along with Bruce Gordon!) and became Albert's apprentice. Mark later ventured out on his own, and has been building frames under his own name since the mid-70's. He also builds all of the custom Rivendells, and the reincarnated Rene Hereses.
I the end, I was so glad I went with him. Someone once said that Mark has the "highest ratio of competence to humility" of any professional that they had ever met. I couldn't agree more.
- I see these are Richard Sachs lugs, but the lower head tube lug should have attached threaded housing stops. Did you choose to remove those, did Mark choose to remove them, or were they just not on the lugs and the design has changed from what I know of?
- Also, is 853 tubing used? That seems to be the case, based on what I can see from the sticker, but its a unique sticker design so I cant tell for sure. Regardless of whats used for the main triangle, how was it decided on?
- What tubing is used for the stays?
Also obviously- cool bike.
Likes For mstateglfr:
#555
"part timer"
Bikes: 1975 Raleigh Gran Sport, 1978 Bertin C35, 1982 Trek 614, 1983 Trek 620, 1984 Nishiki Seral, 1995 Mercian Ko’M, 1998 Fisher HKEK, 2000 Rivendell RS, 2001 Heron Touring, 2016 Nobilette Custom
Quoted: 114 Post(s)
Liked 160 Times
Ok, im gonna geek out a little as I am curious about the tubing and lugs used.
Yes, Sachs Rene Singer lugset. Mark convinced me that the cast-in cable stops on the lower head lug needed to go. Main triangle is 853. JR at VeloCals made the custom retro French tubing sticker. The stays are Reynolds 725
Likes For SuperLJ:
Likes For jeffpabilonia:
#557
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,480 Times
Likes For obrentharris:
#558
2018 REX. 2004 Garage Door
Likes For PhotonDon:
#559
Quoted: 276 Post(s)
Liked 339 Times
Added a Chris Kvale to my Upper Midwest builders collection. I don't know why but bikes from this area seem to be finding me, this is my 4th. The previous owner had Chris add the posts for Paul brakes and repaint 2 years ago.
80 Mercian Olympic, 92 DB Overdrive, '07 Rivendell AHH, '16 Clockwork All-Rounder
#560
Liked 6,388 Times
Paging gomango ^^^
Likes For merziac:
#561
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,996 Times
Phil Wood with Phil BB, Hubs, Spokes and Nipples. Velocity Rims, Chris King headset, Thomson seatpost and King Cages with some anodizing from Firefly in Boston
Proteus frame from College Park, Maryland. Has a Thomson seatpost and Velocity rims beyond that not so 'murican but still a neat bike.
Also my Co-Motion was made in Eugene, Oregon and has a Paul Rear cassette hub and Thomson post. My 1985 Trek 520 in the U.S. as well. I need some better photos and in some cases just photos of all my bikes.
#562
Bikes: many
Quoted: 1446 Post(s)
Liked 1,395 Times
New Bike Day
New-to-me Serotta out for a shakedown ride this morning. It's what I am calling a provisional build. The wheels are definitely not permanent pieces for the bike as they came off my Frejus Tour de France. While there's nothing wrong with the Campy drivetrain per se, I would probably still opt for something more like SunTour Superbe long term.
I had these Veloce Monoplaner brakes available, so I gave them a try. They are intended to be used with recessed mounting while the frame takes nutted brakes. I used Sheldon Brown's trick of swapping front and rear calipers, mounting the now rear caliper with a nut and the now front caliper with a recessed nut from inside the steerer tube. That seems sturdy enough, but it seems that it might not be strong enough should I really need to stomp on the brakes, since the center bolt only goes through the front hole of the fork crown. Can anyone comment on their experience (good or bad) with this sort of setup? If I like the Monoplaner calipers well enough but want to switch to nutted mounting, should I be able to swap out the center bolt for a normal nutted front center bolt from, say, an old Campy Record caliper (or similar, SunTour or Dia-Compe)?
Likes For smontanaro:
#563
Bikes: Since new: 86 Rodriguez Tandem, wife's 87 Gitane Team Pro, 92 Burley Rock-n-Roll, 85 Fisher Comp, 88 Puch Pro, two 92 Bridgestone X0-1s; later: 66/67 Gitane Champion du Monde, 70 Gitane Super Corsa, 70 Carre, 87 Gitane Team Pro, 77/78 Ritchey Tandem
Quoted: 149 Post(s)
Liked 366 Times
Posted first pic several weeks ago when I first bought this late 70s Ritchey Palo Alto tandem...second photo is after correcting some issues and adding some necessary accessories.
Likes For Markeologist:
#564
Bikes: too many old steel bikes
Quoted: 136 Post(s)
Liked 938 Times
Here are my current American built bicycles
1977 Davidson custom
1992 LeMond Titanium (Clark-Kent built)
1991 Serotta Colorado 2
Likes For Andy Antipas:
#565
Quoted: 821 Post(s)
Liked 255 Times
Paging gomango ^^^
The only fault I notice is it doesn't live at my house.
Congrats Kobe, love the build.
I should have mine built by next summer.
Likes For gomango:
#566
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I’m done working on it..it’s finally complete
#567
Bikes: Cannondale Synapse, LeMond Victoire, Bianchi Campione d'Italia, Kona Hei Hei, Ritchey Ultra, Schwinn "Paramount" PDG, '83 Trek 640
Quoted: 268 Post(s)
Liked 325 Times
#569
I've also done the fork-crown-inside-nut trick, and it does work well, but I feel more secure using a longer nut/bushing from behind the crown.
My main general concern is you're tightening a nut with a flat contact surface against a curved fork crown inner wall. If you've got enough threads poking through, it might be helpful to use a beveled brake pivot bushing on the inside of the crown, between the nut and crown? I only just thought of that, and my sketchy brain/muscle memory thinks threads there are often at a premium, so this is suggestion I've never tried. Won't rush in to check it out either, next time one of those critters is in the stand hopefully I'll remember to check it out.
I ran brakes like this for years, but now you can also pick up a longer nut that will reach properly through the back hole of the fork crown. As modern carbon forks have gotten bigger and bigger while front brake bolts have stayed the same length, there's now aftermarket brake bolts that are longer than standard. I did that for a couple years with a '91 Trek 400 that (bizarrely) took a nutted rear brake and recessed front brake -- flip the brakes front/rear, add a nut, add an extended front nut. Worked great.
Fuggedaboutit!
Fuggedaboutit!
#570
Bikes: many
Liked 1,395 Times
Thanks. I think the longer modern recessed nut would require me to drill the back side of the fork for a recessed nut, not something I'm quite ready to do at this point, especially as the Monoplaner brake might not be a permanent fixture. If I get some time in the next couple days I'll try to figure out if I can swap in a nutted Record center bolt.
Edit: I *really* need to stop replying to anything on my phone...
#571
Lovely Serotta, btw! I didn't read your full post before responding, just went off of your quote in MH's post. So yeah, sorry I missed that the bike was built for nutted, which is why you were swapping them front/rear to begin with. I don't generally drill nutted holes bigger to fit recessed nuts, unless it's a beater, or needs other extensive frame work.
My most recent switcheroos have been to do a reverso rear caliper mount to add a minimal rear rack, so the fork was already drilled for recessed mounting.
FWIW the combo of the fork crown and steer tube usually leaves a fair amount of metal meat there.
I haven't disassembled Monoplanars for a lot of years, can't recall if the center bolts are interchangeable with NR/SR/Superbe/Gran-Compe/etc. I'm sure somebody else can chime in.
Thanks. I think the longer modern recessed nut would require me to bite the back side off the girl for a recessed nut, not something I'm quite ready to do at this point, especially as the Monoplaner brake might not be a permanent fixture. If I get some time in the next couple days I'll try to figure out if I can swap in a nutted Record center bolt.
Fuggedaboutit!
Fuggedaboutit!
#572
Quoted: 7350 Post(s)
Liked 2,475 Times
This is our 2002 Burley Zydeco tandem. Not a fine piece of machinery but I think it's American made. I converted the drivetrain from 3x7 to 3x11, and still want more gears at both ends. I think it's American made
Likes For noglider:
#573
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
#575
Quoted: 346 Post(s)
Liked 175 Times
Current iteration.
