Ode to UN55 BB
Ode to UN55 BB
Old 05-20-21, 07:12 PM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 26 Post(s)
Liked 3,433 Times in 2,540 Posts
Hmmm, I think that might be funny...
RubeRad is offline
Old 05-21-21, 05:14 AM
John Valuk
Quoted: 80 Post(s)
Liked 168 Times in 109 Posts
Originally Posted by ShannonM
Given the fact that Tange made the UN55, (along with every other Shimano bottom bracket I know of,) I'd not be surprised to learn that the QB55 is the exact same part.
I don't think that they are in fact the exact same part.
The IRD QB-55 (and -75, and -95) uses a pair of sealed bearing cartridge assemblies.
I think that the UN55 uses an arrangement where balls are in direct contact with bearing surfaces on the spindle and the shell of the cartridge. See details in this thread: Repacking a Shimano BB-UN55.
John Valuk is offline
Old 05-24-21, 02:04 AM
CerveloMad
Bikes: Cervelo R5 Di2, Cervelo S5, Cervelo S1.
Originally Posted by RubeRad
That doesn't help. I did screw the DS in first and tighten, and then screwed the NDS cup in, and without a lip there's no definitive point at which it is 'tight'. But now I'm repeating myself...
You aren't trying to screw a 68mm BB into a 73mm frame are you?
CerveloMad is offline
Old 05-24-21, 09:15 AM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 26 Post(s)
pretty sure not, but hey, I'm dumb enough not to recognize a plastic clip when I see one
In any case, it's already installed and working fine, albeit with possibly the risk of the NDS being inserted too far/tight or not far/tight enough and destroying itself or working loose.
RubeRad is offline
