Addiction LXXVIII
#1676
Super Modest
Quoted: 10965 Post(s)
Liked 4,621 Times
#1677
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12790 Post(s)
Liked 7,698 Times
#1678
Quoted: 8287 Post(s)
Liked 9,064 Times
New observation:
Key "Off":
Key "ACC"
Engine Running:
Key "Off":
- hazards work correctly
- L/R signal lever: no action
Key "ACC"
- L/R signal lever position
- L: driver side lights illuminate
- R: driver side lights illuminate
Engine Running:
- hazards INOP
- L: no action
#1681
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
EVAP is persistent.
New observation:
Key "Off":
Key "ACC"
Engine Running:
New observation:
Key "Off":
Key "ACC"
Engine Running:
- hazards INOP
- L: no action
#1682
So it is
Quoted: 11407 Post(s)
Liked 4,761 Times
You said it kept running after you turned it off? Could be backfeeding somewhere but might be the BCM. Good luck, if you had a good scan tool it might help.
Saw a Camaro with the 3.4 v6 where someone installed a heavy duty clutch and the extra force would wear out the thrust bearing on the crankshaft. Coming to a stop the engine would stall because the crank would move so far forward it would lose the crank sensor signal. I learned something that day.
#1683
So it is
Liked 4,761 Times
Still sounds like a BCM but I really can't help from here, if I was still at the job I could talk to the guy who do that stuff all day. One thing I do sometimes is test the voltage on different fuses related to the circuits in question. If you get low voltage on a fuse that could be a clue, like 8 or 9 volts and the others are 12. Try to find grounds and make sure they're good.
#1684
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Likes For ls01:
#1685
VFL For Life
Bikes: Velo Volmobile
Quoted: 28641 Post(s)
Liked 1,858 Times
I'm probably the oldest guy here except for Zona Tandem who has not been heard from for a while.This being so, I've likely experienced more aches and pains than anyone else here based on length of service and have devised solutions that may work for you. I've found in the case of my poor back, that the chiropractor does some manipulation and I can feel vertebrae pop back into place and discomfort disappear altogether of diminish. I reasoned that my neck is prone to the same issue.
THE CURE
Roll neck slowly left. Try not to break anything by rushing it. Then roll slowly to right. Repete a few times. Then reach to the back of the neck and you should feel one vertebrae that seems to be protruding. Push it around from left to right a few time and you should feel it pop back into place.
I do some neck exercises almost daily to maintain strength in the effected muscles and this helps minimize recurrence.
THE CURE
It occurs to me this is a hard muscle to "rest." Even when I lay down it doesn't seem completely relaxed.
#1686
VFL For Life
Liked 1,858 Times
#1687
Quoted: 663 Post(s)
Liked 496 Times
A bundle of nerves runs down inside vertebrae. If the vertebrae is displaced, some of those nerves get pinched. Sometimes the pinched nerve may effect an arm of something well removed from the pinched area.
#1688
So it is
Liked 4,761 Times
Likes For LAJ:
#1689
Liked 9,064 Times
#1690
he said member
Bikes: yes please
Liked 1,951 Times
EVAP is persistent.
New observation:
Key "Off":
Key "ACC"
Engine Running:
New observation:
Key "Off":
Key "ACC"
Engine Running:
- hazards INOP
- L: no action
That is a weird one
Likes For ls01:
#1691
he said member
Bikes: yes please
Liked 1,951 Times
2004 Daytona 500 ? Why not
#1692
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#1693
Liked 9,064 Times
OK one more car story. Had a truck that wouldn't start, had spark, injector pulse, fuel pressure and would almost fire up but as soon as it seemed like it was going to run it would peter out. 7.4 v8, high miles and it almost sounded like it was flooded. Crank sensor rpm seemed strange. Turned out the crankshaft was cracked but you could pry on the balancer and it wouldn't budge. Took a chance and pulled the balancer off and threaded a long bolt into the crank and when I leaned on the bolt, I could see the crank was broken. Was happy to find that.
#1694
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
#1695
he said member
Bikes: yes please
Liked 1,951 Times
#1696
So it is
Liked 4,761 Times
#1697
So it is
Liked 4,761 Times
#1698
he said member
Bikes: yes please
Liked 1,951 Times
#1699
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#1700
VFL For Life
Liked 1,858 Times
I'm guessing they're compressions.
I'm no doctor but I'm going with muscle. I'm going to try stretches/rolls to see if it helps.
Never seen one. Hard pass if they're fat. Velo Vol only rolls with thin ones.
