One Man’s View Of Disc Brakes
Likes For OBoile:
#206
Yep, that's what it's come down to. My early-adopter riding pals drive 30 minutes both to and from home to shop through impenetrable traffic gridlock to get disc pads replaced.
With rim brakes, if someone said that they need to go to a shop to get new pads installed (cost: $4 per pair) they'd be publicly ridiculed.
Likes For Dave Mayer:
#207
Took 5 minutes to assemble a new 8-speed cassette from loose cogs at the local Co-op. Cost me $5. A decent new chain set me back $10. Or I could have bought semi-trucks full of this stuff online in minutes. So 8-speed stuff is not going away for as long as anyone on this forum will be alive.
As far as progress, adding another cog to the cassette every 7 years does not exactly count as progress. When the sorry bike industry develops a lightweight internally-geared hub with say 10 equal gear steps, then I'll gladly pull out the Gold Card.
#208
Quoted: 20810 Post(s)
Liked 9,456 Times
What? That the disc brake guys have unlimited funds? They need to crawl to their shop with Gold Card in hand every time they need brake work?
Likes For WhyFi:
#209
Administrator
Quoted: 11993 Post(s)
Liked 6,719 Times
I’m worked up, I just stew in silence.
Likes For BillyD:
#210
Quoted: 4717 Post(s)
Liked 1,882 Times
LOLOLOLOL - now I know you're full of it! Replacing pads on hydro is literally a 3 minute job that takes nothing more than a screwdriver and a tire lever (or something similar to wedge the pistons back in). When it comes to replacing pads, disc is WAY easier than rim brakes.
I’m still waiting to hear about the maintenance electronic shifting requires.
Likes For noodle soup:
#211
Oh man, I stumbled onto this thread too late. It took me about 20 minutes to replace (upgrade) my SM-RT800 rotors with some Dura-Ace level RT900 rotors that I scored a sweet deal on, and also to replace the resin pads. The resin pads cost me $40, and the rotors $100, and although the 800s were still very much within their lifespan (this was a "coolness" in looks purchase) but now I have some 800 rotors to fall back on once the 900s wear out, until I can purchase another set of 900s.
I did not realize I needed to have unlimited funds, a Gold Card, and to crawl to my shop.
Silly me thought all I needed was some hex keys, a couple of inexpensive bottom-bracket adapters to my torque wrench, gloves, shop towels, grease and isopropyl alcohol, an internet connection to watch a couple of YouTube and Parktool videos, and a can-do attitude. I had most of the tools already because I like working on my bikes, the only real outlay was the bottom bracket adapters, which together were $40.
Oh, while was doing this, I also flipped the front brake caliper mount to convert it from 140mm to 160mm for extra stopping power.
100 miles over 3 days of riding on the new brakes and they work great, totally quiet, and look awesome.
Likes For CarloM:
#212
Quoted: 8344 Post(s)
Liked 9,193 Times
#213
Liked 9,456 Times
Likes For WhyFi:
#214
Liked 9,193 Times
#215
Liked 9,193 Times
Likes For big john:
#216
Liked 9,456 Times
Exactly. Replacing pads, which is far and away the most frequent maintenance task with hydro discs, is so dead simple that no one with any experience would cite it as a deterrent.
Likes For WhyFi:
#218
Liked 9,456 Times
I know, I know - you've reiterated this a dozen times. But while your experience is worth sharing, you also have to consider that your experience is atypical; by the nature of your position, you're going to see more problems than the typical user and you're going to see them at a higher rate (ie, not a random sampling). I've never run in to a nasty surprise when changing pads and I can't say that I've heard of any others; sure, reports of a stuck piston here or there, but that's not a complication of a routine pad change, that's a problem in and of itself (and one that should have been noted early on).
#220
Quoted: 1530 Post(s)
Liked 718 Times
Do you reckon there's much chance of anyone bringing anything fresh to the discussion on page nine (of the forty-third thread on the subject)?
#221
Blazer of saddles, trails
Just to keep this dumpster fire going, here's one man's view of how the global bike conglomerate forces reluctant pros to ride with murder discs that offer no benefits over angelic rim brakes:
https://www.velonews.com/2019/08/vue...-return_500204
“I’ve had some bad accidents in my life so I don’t risk my life on a random corner but I’m confident enough with the disc brakes now, especially to stay with the guys bombing it on the descent, but I’m just not going to be the one attack. We came into those finals with the roundabouts that are wet and it went from hot and humid and ice socks on your back to kind of drizzly and cold and rainy, so your body’s just like, ‘What the hell is going on?’ It was a wild ride.”
#223
Liked 1,882 Times
The hardest thing about maintaining electronic shifting, is remembering where you left the charger.
#225
Who'd have thought 20 years ago that such a thing would ever happen...
