Why is steel out of favour?
#201
Sunshine
Quoted: 10965 Post(s)
Liked 7,493 Times
Likes For guy153:
#203
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,998 Times
Who is adding weight in 2020/2021? I just don't get the sentiment that it's easy to get under the UCI weight limit.
Most pro teams now are running discs (sponsor choice, but they are). In a practical configuration with medium depth clincher wheels, top spec $10000+ bikes once you add pedals, bottle cages and a Garmin mount (that's how you weigh them for UCI compliance, not naked showroom weight) are well over 6,8kg and to get them as low the pro teams tend to use tubular wheels which the average cyclist simply does not want to faff with. The aero bikes are all over the weight limit to the extent there is a choice of bike to be made whether it is a climbing stage or not.
Sure, if you build a lightweight steel bike with rim brakes and low profile wheels and add carbon components and a CF fork, but that's not quite the apples to apples comparison. The move towards discs is largely driven by what people want to buy; people are willing to accept an extra bit of weight to be able to run hydraulic disc brakes, electronic groupsets and the like. People are also willing to accept a bit of extra weight to get deeper and more aero rims, a bit of extra weight to have a power meter, for tubeless and wider tires and so on. It's not like everyone is a weight weenie to the max; but they just don't want extra weight which adds no utility.
In a very real way the UCI minimum weight limit shifted development from "let's make the lightest bike we possibly can" to "let's make the best bike at the target weight". No weights needed or added.
Umm the Bandito is steel with disc brakes and under the limit just FYI.
Teams are still adding weight. Certainly it has gone down a bit with disc brakes but I cannot believe it has completely stopped because the quest for lightweight hasn't ended. Of course nobody wants extra weight but them's the rules, paley.
Tubulars are pretty much always going to be the realm of the pros.Though us mear mortals do have open tubulars and those are perfect as they have that lovely lightweight casing the gives an excellent ride but easy tire replacement like a clincher.
#204
6-4 Titanium
Quoted: 92 Post(s)
Liked 36 Times
I'd use a steel frame for heavy touring for sure. Other than that steel is quite boring to me. To get a good steel bike in your size you'd probably have to go custom to boot which could be just as expensive as a nice carbon bike in your size. So you might as well just get a carbon bike form a good manufacturer backed with a solid warranty on the frame.
#205
Bikes: miyata 83 1000,84 1000,83 610,88 ridge runner ,Schwinn 84 high sierra,88 Cimmeron,86 Passage,84 Stumplumper ,83 Mt Whitney,83 Trek 850,Merckx Century,PX10, RB1,XO 1 XO 4,bunch of stuff like that
Quoted: 57 Post(s)
Liked 51 Times
steel
Worldwide steel is the most widely used frame material........there are more steel bikes on the road than carbon aluminum and titanium combined worldwide.........Giant has really been pumping out the aluminum bikes and they are really popular because people believe they are lighter and stronger but............although aluminum is three times lighter than steel ....steel is three times stronger than aluminum......X - X = 0
#206
Quoted: 338 Post(s)
Liked 408 Times
7, 5kg is the weight of my disc brake aero road bike with 45mm deep wheels which has an, essentially, fairly budget CF frame and mechanical Dura-ace. With a top of the line aero road frame, a couple of possible small but expensive upgrades and running tubulars, I could get it down to maybe 7kg. That's close to where many pro aero road bikes with disc brakes actually end up, and why you'll see some of them opt for the more lightweight model for mountain stages, because they can't get the aero bike down to exactly 6,8kg with the kit which their sponsors provide.
#207
Quoted: 3352 Post(s)
Liked 1,056 Times
Isolated incidents related to one particular issue - which may or may not be related to the material itself - is not logical justification to ignore the thousands of other applications where CF material does the job spectacularly. It's clear you have an unreasonable prejudice against CF. Your choice. Meanwhile, I'm going to continue to enjoy my CF bike every time I ride it.
It is an example tho of the fact that CF is NOT the wonder material that so many think it is. The main "prejudice" I have against CF is the obscene price, because everyone tends to hype it. And because of that people are being ripped off. Ten to 15 thousand dollars for a bike is absolutely crazy.
If you can please explain the difference between say a 5000 dollar CF frame and a 15000 dollar CF frame is.
#208
Quoted: 822 Post(s)
Liked 1,961 Times
Twenty years from now, will cyclists be searching for 20+ year old carbon framed bikes on ebay, craigslist, etc...?
#209
Quoted: 6972 Post(s)
Liked 10,970 Times
Not very "isolated" to the hundreds that died and their families.
Honestly, you keep changing your argument. So, which is it: Are cf bike frames too expensive? Is there not enough difference between a $5,000 cf frame and a (nonexistent) $15,000 cf frame? Is it that cf sometimes fails?
Every time someone shoots down one of your arguments, you come back with another. All that you are doing is failing, over and over and over again.
I've not seen any posters telling you NOT to ride a steel recumbent; why do you feel this constant need to tell others that they are fools for making other choices?
Likes For Koyote:
#210
Liked 1,056 Times
Show me a $15,000 carbon fiber bike frame, and I'll answer your question.
#211
Sunshine
Liked 7,493 Times
Your response would hold some weight if people hadnt died due to steel and aluminum frame failures.
I personally wouldnt buy a bike that costs 10-15K, but those who do arent being ripped off. They find value in it that I dont. And that value means they view it as money well spent. This is a classic example of projection.
I get it, its tough to not project as we all know whats best for others, right? But we dont.
Its cool if you dont find value in a $10K bike and you fell like you would be wasting money if you bought it. But dont push that onto others.
Link a frame that costs $15000, please. I am sure something exists- where there is a market there will be product, but I dont know of one.
You move goalposts a lot.
You still have yet to explain why all of the metals used are far superior for cf. Just focus on that for your next response, please.
Likes For mstateglfr:
#212
Liked 10,970 Times
#213
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Price is driven by the market. If people are willing to spend $1000 for a widget that costs $1 to make, then so be it. It also seems that you aren't willing or able to look past the simplistic view of just the cost of the raw material. As with a LOT of products, material cost is only a small part of the cost of production. Bicycle frames would be one example of that.
Here's another example - A friend of mine sells a product that he assembles and ships out of his garage. The parts for his product aren't a special material, nor are they complex. Someone with some mediocre fabrication skills could easily replicate a single copy of his product for quite a lot less than the cost he sells his for. Is he ripping people off? Absolutely not. Making a copy of his product doesn't include...
- The tremendous amount of time and wasted materials involved with developing the final design.
- The time and effort that goes into sourcing vendors to provide and manufacture the parts for larger-scale production.
- Printing of the company name on the product.
- Packaging for retail sale.
- Website and marketing costs.
- Profit (it's a business, not a charity)
- A bunch of little **** that it takes to run a business of any size.
If you think CF products are a rip-off because the material is so cheap, I invite you to start producing some CF parts of your own so you can pocket all that easy money for yourself.
As I've said, if you want to ride only metal bikes with metal components, have at it. Do what makes you happy...but try not to let the thought of metal airplane failures spoil your ride. Your arguments against CF are only serving to justify your own prejudice.
The difference between a $5k frame and a $15k frame?....Mostly marketing, probably. EDIT: Low-production specialty bikes could justifiably hit that number (see below).
#214
Habitual User
Liked 8,099 Times
#215
Habitual User
Liked 8,099 Times
2 years from now, I will have a 20-year-old carbon-framed bike. Except for the diminished power of the motor, it performs exactly as it did when it was new.
Likes For Eric F:
#216
Quoted: 822 Post(s)
Liked 1,961 Times
Good to know. I would be less inclined unless I knew the owner(s) and the bike's Hx. Steel framed bikes, I would have less of a concern.
#217
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 465 Post(s)
Liked 547 Times
Here is a link to a frame that is going to set you back at least a cool 15,500 GBP, so about $21,500 US.
https://www.hopetech.com/news/hbt-70...-and-counting/
The picture above is from that web site, and there are plenty more, Here is the link to actually buy one, or maybe just get in the queue, or maybe be told that since you are not a world class track racer you can sod off.
https://www.hopetech.com/news/hbt/
Mind you that 15,500 pounds is for the frame only. Those wheels are another 4,500 GBP
Marketing hype? I don't think so. This is what very low production niche products cost. But I'll wager that if the BB is not aligned they crush the frame and start over.
Also, can anyone find me a bike like that in steel? Yeah, maybe not. Mind you I own several steel bicycles, and they are a hoot to ride. My favorite bike is my Ritchey Tandem, and it is certainly steel. But when I bought a fat tire bike I went with carbon because it gave me the best bike for the money.
Likes For DangerousDanR:
#218
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Based on the responses the early CF frames are doing just fine.
Likes For bOsscO:
#220
Habitual User
Liked 8,099 Times
I recently purchased a 2-year-old CF bike based on online pics and a couple of messages with the seller. I have been completely satisfied with it. Unfortunately, it has the same motor issues as my 18-year-old CF bike.
#221
Quoted: 1858 Post(s)
Liked 606 Times
#222
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
#223
Liked 1,056 Times
Quite frankly that bike reminds me of when I was a kid on the farm. Look where that seat is and where the handle bars are. It reminds me of an old hen with her butt in the air and her head down picking corn out of a cow pie.
#224
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
Sadly he hurt himself but
This video really opened my eyes to what CF can do. As a kid who rode BMX I remember taking my Sisters Sears10 speed out and jumping it off a picnic table. The wheels tacoed, and the forks and handlebars bent. In fact I don't think there was a single piece of that bike that wasn't bent after. Later on I actually got into road cycling and one of my friends had a brand new Bianchi, with these stupidly expensive wheels that only had a few spokes in them. Just going off a curb or hitting train tracks and they would be bent.
I would like to get a CF bike but honestly two things keep stopping me.
1) Difficult telling if it's cracked. It's surprising but most sellers will object with you tapping it with a coin
2) Can't tell if it's FAKE. It's not like the good old days where jerks would swap a decal but knowing what traits to look for will save you heart ache. These fakes look identical!!! They just have low amounts of carbon in them etc. I'm sure there is ways to tell but I think it's way more difficult. I also feel like most of the CF breaking you hear about are fake bikes not made properly.
I think there is also a lot of diminishing value in CF. I watched a GCN video where they raced old vs new. And the old $100 1980's special was only something like 20 sec slower. Big deal in a race I agree, but for a guy like me that's meaningless. I could spend $10,000 on amazing CF but I'd probably be a few mins slower then a professional racer on a dutch city bike.
#225
Quoted: 321 Post(s)
Liked 263 Times
People got used to paying a lot for a CF bike and the huge cost savings of mass-producing them in China (not always to the highest standards) have not been passed onto the consumer.
But it's a free market and you can buy the same stuff (or what might be the same, caveat emptor) on Ali Express minus the trekgiantcannondalespecialized stickers for a small fraction of the cost. Or for probably only slightly more from YouTube sugar evangelist and life coach Durianrider.
