Let's see some of your geared bikes........ (retired)
#4402
Bikes: Click on the #YOLO
Quoted: 26 Post(s)
Liked 12 Times
All you need to know is that 26.0 is near enough to 1" and 31.8 is near enough to 1 1/4", so you need some 1/16" shim stock taking a full lap (1/16" on two sides= 1/4") to make up the difference.
I made the delrin ring on a lathe at work and cut a slot in it with a hacksaw later, but I had the scrap close at hand. It doesn't need to be nearly that complicated.
#4405
That's the lazy way out. Besides, that much tape would look cheap.
#4408
Quoted: 26 Post(s)
Liked 12 Times
Didn't use a shoulder. Not sure i could have- pretty sure the barfly doesn't have a consistent width the entire circumference. Protip: PVC pipe machines VERY well. I'd bet something with a thicker wall (like schedule 80, bonus grey color) would have enough diameter and thickness to hit both the 26 and 31.8mm targets.
#4410
Quoted: 443 Post(s)
Liked 12 Times
Pulled the saddle, enve bar and xt brakes off the carve.
This bike is a rocket. I'm digging it so far.
set it up tubeless right off the bat.
Weighs 24lbs as shown.
#4416
sɹɐʇsɟoןןnɟsʇıbɟɯo
Bikes: fixed gear recumbent trike
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Overall simplification of a complicated front end.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
#4421
Fresh Garbage
Don't they just bolt on? Lookie what I found.
https://m.youtube.com/watch?v=_WlRqcAQr2w&desktop_uri=%2Fwatch%3Fv%3D_WlRqcAQr2w
#4422
Quoted: 443 Post(s)
Liked 12 Times
it's much stiffer. instead of 2 fork legs fighting each other, you've got one stanchion coming down directly from the headtube w/ square internals.
also, they use needle bearings which are much smoother.
https://www.cannondale.com/innovation/lefty_headshok
#4423
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
#4425
Quoted: 1332 Post(s)
Liked 398 Times
