Let's see some of your geared bikes........ (retired)
#4627
So far, yeah!
Sure can! I've put about 100 mi on it so far and they are buttery smooth. Will report back in another 500 or so.
Originally Posted by IAmSam
After you've put some miles on them, could you please post your impressions of these tires?
#4628
My winter bike, swag 80's MTB style
#4630
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2640 Post(s)
Liked 3,153 Times
you liked it more than the R3, huh?
"Your beauty is an aeroplane;
#4631
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
The problem with the R3 is that due to its special wider press-fit BB the choices in cranks are limited and I wanted 165mm Ultegra cranks that won't fit. The Matrix has a conventional 68mm threaded BB, which works great with the Ultegra external bearing setup. I did ride a Matrix that was built up with different components and it seemed to be about the same as the R3, except maybe a bit harsher in the rear, but that was with 700x23c tires with a lot of pressure in them and I'm going with 700x25c tires and there's room in the rear for 700x28c if I decide to go that route.
#4632
Not actually Tmonk
Liked 3,153 Times
not to open this can of worms, but i hate all of this fancy PF/BB30/BB86/whatever BB crap
i'm a middle of the road competitive cyclist, which means I have to be fitter than 95% of all total road cyclists out there and I can't tell a damn difference between an english bb and bb30 (or whatever).
im gonna be using shimano cranks until the day i die
#4634
Not actually Tmonk
Liked 3,153 Times
ya that seems to be the trend... i'm on board with most oversize innovations in general, it's easy to understand the physics behind the stiffness increase.
the crank assemblies on many less than perfect frames (esp carbon bb shells) can be problematic. ive had a couple less than steller experiences w bb30.
#4635
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
Hi, all.
This thread has served us well for nearly 4 years with over 4,000 posts. It's time to retire it and move to another version to save stress on the databases.
The new thread is here: https://www.bikeforums.net/forumdispl...amp-Fixed-Gear
Feel free to repost your bikes into the new thread.
I am closing this one.
