Show me your cruiser.
#1426
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
Beautiful bike.
Did you plasma cut the sheet metal between the 2 top tubes? Looks clean.
The wheels look shallow. Are the original to the bike? Are they hooked for the tire bead?
The crank arms look flattened. Is that an optical illusion?
Thank you.
Thank you.
#1427
Bikes: 91 Ritchey Ultra, 1992 Specialized Stumpjumper, 1990 Klein Rascal, 97 Trek OCLV9700, 90 Minnelli Eclipse, 95 Marin Bear Valley SE, 1991 Breezer Lightning Flash 1991 Diamondback Axis 1992 Stumpjumper Comp 1983 Stumpjumper Sport
Quoted: 102 Post(s)
Liked 674 Times
Tires and wheels off a 1954 CCM, original Dunlop tire which look small for this bike we’re just to cool for me not to use. 2” in the rear and 1 3/4 up front. The crank arms are flat and original to the bike. They look great in real life.
As for the panel I got it cut with our laser table at my work. The CAD guys whipped it up for me😎 we cut it out of 18gauge satin coat metal but the flames were too floppy so we ended up using 1/4” aluminum plate
#1428
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
Makes sense for the crank arms to be drawn into that profile. I just don’t know if I’ve ever seen those cranks before.
#1429
Bikes: a couple
Quoted: 563 Post(s)
Liked 868 Times
Something is not quite copacetic there...
You have a Wald headset on aschwinn Ashtabula fork. I bet the crown race doesn't sit on the fork crown quite right and the top adjust cone race doesn't have a matching id to the forks od. It's off just a smidgen. so you're either too tight or a bit sloppy. no in between.
Likes For Schweinhund:
#1430
Just bought this from a friend. 1970's Schwinn with a mix of parts - skinny tank fitted from a Columbia, seat from a 1990's big box bike, riser bars from a 1969 Stingray, 36T chainring for a cruisable gear for these old knees.
Likes For NYLowLife:
Likes For GeezyRider:
#1432
Bikes: a couple
Quoted: 563 Post(s)
Liked 868 Times
It's a 90's model. Yes I'm sure, but that's not a bad thing. The 90's schwinns ride better than the older electroforged frames.
Likes For FREEBIRD1:
#1434
55+ Club,...
Bikes: 9+,...
Quoted: 1133 Post(s)
Liked 860 Times
Hurley Hydrous 27.5 Cruiser,... Needs a kickstand, maybe/not fenders. Great little, mod'able single speed.
Likes For tds101:
#1436
55+ Club,...
Bikes: 9+,...
Liked 860 Times
tds101 Is that in NY? I'm in NY and like to ride in dead-end places myself....
Likes For tds101:
#1437
#1438
Bikes: Most of my bikes are Single Speed Conversions
Quoted: 267 Post(s)
Liked 3,067 Times
HardRock Cruiser
Converted my Hardrock hard tail over to a single speed cruiser .
Low gearing , 30/22 for climbing hills around here.
Smooth riding on the Hookworms.
Likes For OldCruiser:
#1439
I picked this up a few weeks ago at an estate sale. I'm told its likely a '49 or '50 model, (Columbia). .
Its mostly original parts wise besides the seat and maybe a newer front sprocket.
I re-greased the cranks, hubs, and headset and it rides great as shown.
The tires need some attention as they're loosing bits of tread here and there from age but I hate to lose that original look with those huge round, wide original tires. Newer tires just don't look the same on these old bikes.
Likes For missingspoke:
#1440
Bikes: There is always room for one more.
Quoted: 188 Post(s)
Liked 396 Times
https://www.biketiresdirect.com/prod...ser-urban-tire
Don
Don
#1441
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
ETA. Beautiful bike.
#1442
Nice find! Here is a link to some 26 x 2.3 tires that may give you the look and feel that you want:
They didn't look much bigger than the original Carlisle tires on this bike.
When I do that I may respoke the wheels too, the original spokes are looking a bit rough, a few are seized and can't be adjusted.
I've also been thinking about building the wheels with larger diameter spokes, like the same year newsboy models, but haven't decided on that one yet. I even have a correct era hub drilled for the larger spokes, and a spare set of painted black rims too. That way I could put the originals away for safe keeping and ride on the set best suited for a bigger rider like myself.
#1443
'85 Nishiki Pacific Coaster Brake model
All original except for the rear hub which I upgraded to a Bendix RB2 when the spoke flanges broke loose of the hub body on the original Shimano clone hub.
#1444
Bad pic but just got and hoses the layers of dust off.
1988 General Catalina Cruiser 26” coaster brake model.
Snagged off the scrappers truck for a few bucks. Even has the shop sticker from the local bike shop which has been in business forever.
Likes For 3speedslow:
#1446
Finally got it rolling for a test cruise around the neighborhood. Not bad. Will be replacing the wheels, saddle, post and handlebar with parts which don’t belong to other projects!
1988 General Catalina which was sold by the 50+ LBS here and still in business!
#1447
Quoted: 102 Post(s)
Liked 674 Times
through on some new rubber and bars look pretty good
Likes For victorm:
#1449
Bikes: Western Flyer, Schwinn, Rollfast, Gambles, J.C. Higgins, Waverley, Crescent, Hercules, Nishiki, Huffy, Mohawk, AMF, Electra, A ridable replica hi-wheel and a few others.
Quoted: 42 Post(s)
Liked 45 Times
#1450
Quoted: 816 Post(s)
Liked 1,037 Times
