What's the upgrade you regretted the most?
#151
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
I personally have had no issue with A23's or Kinlins. There are many who have had issue with both of those.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
#152
November wheels (white industry hubs with Pacanti hoops), the hubs a wonderful but as Psiment has mentioned about tubeless it is almost impossible sometimes to get a tire on. So much so that I've thought about getting them rebuilt with a different hoop.
Its not a fault of November themselves.
#153
Forgive my ignorance but it's not a 1 to 1 weight transfer when you are comparing rim brake wheels to disk brake wheels. If I could that just move the same amount of weight in, that would be simple but moving more weight in complicates things right?
#154
Quoted: 42 Post(s)
Liked 26 Times
Sorry for the crappy vid, but the technique really really works.
#155
https://www.youtube.com/watch?v=Dd0QsdCwq6E
#156
I eat carbide.
Liked 1,306 Times
November wheels (white industry hubs with Pacanti hoops), the hubs a wonderful but as Psimet has mentioned about tubeless it is almost impossible sometimes to get a tire on. So much so that I've thought about getting them rebuilt with a different hoop.
#157
Disk brakes fall into the category of unnecessary weight. In addition to the extra risk of getting cut up in a crash, and the increased chance of a peloton pile-up, there is the downsides of rubbing disks, the slow and cumbersome wheel changes, the lack of standards, and idiotic developments such as through-axles. But the bottom line is that they are less aero, and heavy and in a road racing environment, unnecessary. High-level road racing with disks will happen about the same time as the peloton changes over to clinchers: which is never.
#158
Quoted: 4717 Post(s)
Liked 1,882 Times
I'm not one that believes disc are a huge improvement, but your beliefs leave me shaking my head.
#159
Agreed. Between this and the constant quality issues with the rims I completely stopped building with the SL23 V1 and V2 going on the better part of a year. Even with the newer version I have had customers call up while on a ride with a flat cussing me out. Even while I explain what they need to do its already checked off in their head as way overly complicated and something that has made their life worse - not better. Even if I was behind the design there's not much of a point in supporting it if no matter what the customer just don't agree.
#160
Quoted: 6556 Post(s)
Liked 58 Times
I've said it so many times, but apparently not enough. Just get a damned VAR tire tool. Never fails to mount a tire and never tears a tube. Good enough to use in your home shop. Small enough to carry on your rides. Why are we even talking about tires being hard to mount. With the right tool no tire is hard to mount on any rim.
#163
#164
Quoted: 42 Post(s)
Liked 26 Times
Making no excuses/being an apologist for tubeless whatsoever, rims that offer a... more secure fit long pre-date tubeless rims. My brother has an ancient wheel that he uses on the trainer, and called me up yesterday swearing a blue streak about how impossible it is to get a tire on the thing and could he come over and swipe some tire levers. Some older Campy rims are legendary for being impossible to put tires onto. HED Belgium+ tubeless are generally easier tire installation than HED C2 which isn't tubeless, as an example. DT R460 and Kinlin XR31 are both tubeless and have really easy tire install.
Most challenging tire install I've ever done was onto an AX Lightness carbon tubeless clincher. That took every trick in the book, plus some new ones, to accomplish.
#165
Quoted: 324 Post(s)
Liked 251 Times
#166
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
At home, I just use a beefy flatblade screwdriver for difficult tire/rim combinations. I know it's "illegal", but done carefully, it works well.
Why do different rim tapes make much difference?
#168
Bikes: BH, Cervelo, Cube, Canyon
Quoted: 212 Post(s)
Liked 6 Times
I use a sawzall on mtb tires that I'm not going to re-use. But the Pedro brand wide plastic levers have gotten all kinds of hard to mount tires on from mtb to cx to road. Also my manly strength helps but you can't buy that.
#169
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
#172
Quoted: 42 Post(s)
Liked 26 Times
Different rim tapes make an ENORMOUS difference. God help you if you use Velox on a rim that's tight in the first place.
The reason why it makes a difference is that the smaller the diameter of the circle you are trying to get the tire onto, the more easily the tire goes on. The diameter of the channel or well in a tubeless rim, or just the flat tire bed, in a non-tubeless rim, increases with thick rim tape. That makes tire installation harder. If anyone reading this has a rim that's tough to get tires on and is using anything other than a Stan's-type tubeless tape (or any thin strong tape), give the thin tape a try. I guarantee it will be transformative to your experience. Guaranteed.
#173
Quoted: 33 Post(s)
6K miles on clincher wheels, lots of flats, no issues repairing. Broken spoke, rebuild wheel, throw out thin plastic rim "tape", install Velox. Much cursing on subsequent flat trying to get tire off! (Didn't put 2 and 2 together until just now.)
So my upgrade I regret? Velox rim tape.
