ISO and for trade thread part 5
#5901
Quoted: 1303 Post(s)
Liked 1,912 Times
Stoopid me! What are these items? I am pretty sure they go to a Simplex derailleur in some way but I, for the life of me can't remember. Some help please, smiles, MH
I have a pair of these adaptors but don't remember which item the go with.
#5902
Bikes: 1986 Trek 760, 1990 Trek 420, 2020 REI ADV 1.1, 2017 REI ADV 3.1, 1995 Trek 930 Singletrack, 2003 LeMond Arrivee
Quoted: 29 Post(s)
Liked 106 Times
They look like part of either a v-brake or cantilever brake assembly, where the screw adjusts the spring tension on the brake arm; don't know what the technical name of the part is.
Likes For jbz255:
Likes For Schweinhund:
#5904
Quoted: 1609 Post(s)
Liked 2,216 Times
ISO Carnielli stem 100mm
I would like one for my '72 Bottecchia. I have crank sets, look clipless pedals, some Cinelli stems, older saddles, hanldlebars.....
#5905
Edumacator
Quoted: 2441 Post(s)
Liked 3,136 Times
#5906
Liked 2,216 Times
#5907
Edumacator
Liked 3,136 Times
#5908
Liked 2,216 Times
#5909
Edumacator
Liked 3,136 Times
Got the third and responded!
#5910
Butt-Nekid Wonder
Bikes: 93' bridgestone rb-1
Quoted: 5 Post(s)
ISO: Positive (or close) angle threaded stem with 80mm reach, 26.0mm bar clamp, and relatively long quill.
#5912
Seńor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
I've built at least five sets of wheels using them. They are very good quality for the money, build up easily and they are nearly bombproof. The silver ones are the ones to get for a vintage build. They don't look at all out of place on a vintage bicycle... pretty much an ideal choice for a thrifty set of wheels for a tourer.
Likes For USAZorro:
#5913
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
This.
My LBS uses these all the time for vintage bikes. Polished and classy, but also understated with their modest logo decals and relatively boxy profile.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Likes For mountaindave:
#5914
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Likes For JohnDThompson:
#5915
Bikes: many
Quoted: 1446 Post(s)
Liked 1,395 Times
I wonder if you could soften the sharp edges just a smidge to make them slightly less angular in appearance.
#5916
Edumacator
Liked 3,136 Times
Does anyone have use of a set of 27x1.25 Weinmann rims, and handlebars/chicken lever brakes/stem and leatherette bar cover from a 1976ish Motobecane Super Mirage?
#5917
Quoted: 1612 Post(s)
Liked 2,594 Times
#5918
Edumacator
Liked 3,136 Times
I am only wanting the frame. I promised the girl who gave it to me that I would make something cool from it but it is pretty rusty.
And I realized, I should have said “have NEED” not have use. Oops.
Likes For jdawginsc:
#5919
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 437 Times
As for the frame being rusty... How rusty are we talking about? Is it rusted through? Many steel bicycles will have surface rust that might look bad, but when you clear it out, you might see the frame is actually still structurally sound. Worst case scenario, you might have to repaint it (though this adds a cost and/or time you're not going to get back)
As for something cool, what's not cool about Motobecane handlebars? The stem is a bit short (for me), but you can always replace that. The rubber covers can be taken off. Soak it in warm water before to make the process easier and wear some gloves with talcum poweder when removing the covers as they will require a bit of gentle twisting around. They can be put back later on using talcum powder when the handlebar has been polished. If you don't want to use them, you can always ship them to me I know they limit brake levers position to just one place, but that's something one can get used to. You can replace the brake levers with something more funky or just polish them up. You can clean up the hubs and rebuild them into 700c rims (or any rims you'd like). Or just clean up / polish current rims and keep using them, nothing wrong with that. So what you've got there can look pretty alright with some love and affection
Some proof below. The handlebars I used were probably in a worse shape than yours, the frame was battered, all aluminium parts were oxidised... Well, the list would be long.
#5920
Quoted: 1106 Post(s)
Liked 1,328 Times
You have to take the brake levers off as well; the version with holes for hoods may be easier than the one with integrated hoods.
I used wd40 as as lube.
You adjust brake lever position by cutting bits off the end of the bars.
Don't lose the special plugs that keep the end fom cutting through the cover.
Even with the bother, they are worth it.
#5921
Quoted: 215 Post(s)
Liked 437 Times
Those covers are great, except for installing/removing.
Yes, they are totally worth keeping. They offer very good grip and are quite comfortable to use (in my opinion). Personally I prefer cotton when I have a choice, but these covers were well made. The ones I have are over 40 years old and they are holding up very well despite total lack of care for most of this time. Can't see cotton or cork handlebar tape lasting that long.
#5922
Edumacator
Liked 3,136 Times
I have plans to make a straight bar single speed from the Motobecane for someone as an around town bike to give away to someone. The woman who gave it to me asked me to give it some new life.
The bars and stem will likely be taken apart and someone may want them separately. The bars are Motobecane marked, the stem oddly, is not.
The frame will be fine, and I might be able to salvage and prettify the headset.
just seeing if anyone with a Moto project would like them intact.
The rims are classic Weinmanns and are reasonably good. The hubs are not.
#5924
Liked 2,594 Times
Misread your post.
#5925
Edumacator
Liked 3,136 Times
Not keeping any part of them...covers, bars, stem and levers. Yours for the cost of shipping.
