Disc brake alignment - how long should back wheel spin for?
I've never had much luck with that approach. Tightening the bolts, even in stages, tend to shift the caliper out of alignment again.
I prefer to loosen the bolts just enough so that firm pressure or tapping with a screwdriver handle (or comparable) is enough to push the caliper into position, and then to tighten in stages while alternating between the two.
Your Brakes bedded in while you were riding it . You would need to lightly sand the disc's to remove the brake pad material in order to start over. I wouldn't worry about it now. Depending on what the pad material is they could be very noisy. My Motorcycle has sintered metallic pads and they can be very noisy ( the compound is very hard). Same thing can happen with your cars brakes depending on the type of pads you buy.
The brakes were still a bit noisy, so I went through a brief bed-in process (gentle brake pressure for 5 seconds, followed by almost 100% braking until wheels locked up), done about 3-4 time. I then went for a gentle ride over wet grass, and the noise has substantially reduced. Probably all is now normal, but I'll ask the LBS to check everything when I go for my post-sales check-up.
Thanks for the advice!
John
Bikes: Mongoose Reform Sport
Quoted: 34 Post(s)
I tried (successfully, I think) to re-centre the rear caliper as described above and can now discern a very thin gap between pads and rotor on both sides. The rubbing/squeak does seem to have disappeared.
John
John
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
Quoted: 150 Post(s)
get someone to help makes it easier than monkeying around with the brake in your hand, body over the rear and tools in the other trying to keep balance
It would be helpful if you mentioned the exact make and model of the brake. You mentioned that the clearance to the pad that was not rubbing seemed very close. This may or may not be wrong--pads on disc brakes are spaced very close because the system can operate with higher mechanical advantage with the pads closer, particularly if the pads travel at a linear rate as the lever is pulled, which varies by brand/model.
However, not infrequently on new bikes, particularly on brakes that are actuated by DOT fluid there will be too much fluid in the system which will space the pads too close to the rotor.
If your bike was in my stand, I'd first center the caliper so that the disc was centered between the pads Loosening the brake mounting bolts, squeezing the lever, and tightening them down SHOULD center the caliper correctly, but often due to some kind of friction this doesn't work, and I always double check and frequently have to slightly loosen the bolts to align them by hand. Be careful to never do this with the wheel moving--I ended up in the ER with a bisected fingernail trying to adjust a caliper with the wheel moving this year.
Then, if I determined that the pads were too close to the rotor, I'd remove the pads and open up the lever bleed port, cover it with a rag, and them press the pistons out to force out any excessive fluid, then close the bleed port, clean up the lever, and reinstall the pads, and recheck. I've built a handful of new bikes that needed this with SRAM brakes.
Also, the cases of pads wearing out involve racing in extremely muddy conditions, and were mostly problematic with cable-actuated disc brakes (because they don't automatically advance the pads as they wear). It would be extraordinary if you did excessive wear with the riding you've described. My advice for your cross bike is to ride it wherever you feel you want to. My experience is that the relative lack of traction and the brutalness of riding a rigid bike with not-particularly-wide tires results in a pretty cautious approach to riding semi-technical singletrack, and I've felt pretty safe about the bike, even when not feeling safe about myself.
While this can resolve some problemsit does not preclude the need to bleed the brakes for real approximately annually. If you have older elixirs of juicys and they're not functioning after a bleed they belong in the trash as the time and money to service then further is better put towards new brakes.
Quoted: 206 Post(s)
Liked 102 Times
I have a bike with the same brakes as the OP, and they were noisy from the get-go. They emitted a grating sound when they were applied, and the rear also had a howling sound. I centered the brakes, cleaned all surfaces, had the shop work on them, and the noise was still there. But the brakes worked great! Finally, this winter I replaced the pads with a different brand, and the noise stopped - but the pads were too thick and that caused the rotirs to rub. I eventually removed the pads and sanded them down a tiny bit. The brakes are oerfect, now. I never had those problems with Shimano brakes on my mountain bike, but maybe they were a different animal.
Some days, it's not even worth gnawing through the restraints.
Ref disc brake squeal: If you didn't break in the pads/rotors before your ride, they can load up with "contaminants" and then begin to squeal. Ask me how I know…lol. I ended up sanding the rotor surfaces with 1000grit sandpaper and washing the pads with dishwashing liquid to remove all "contaminants". That got rid of most of the noise. I then used CRC Disc brake quiet to eliminate the rest. Good Luck.
a few SRAM manual PDF https://www.sram.com/service/sram/3,43
Sure the wheel QR isn't causing the over tightness if the hub axle bearings ,
and that's where the drag is, but you think it's the brakes ..
If it is QR, there is some more flex. TA seems better. Some occasional contact also happens with dirt, or different temps.
But one thing to check with all discs is to get the wheel on an actual truing stand with rotor adapter. I once had some flex noise and tried all the above suggestions to no avail. Truing on the bike isn't so great. I finally gave in and bought the $40 Park rotor thingy for my truing stand. Solved all my problems.
My fork still flexes, it still is QR, but I'm now in good enough tolerence to not have issues.
You problem may be different, but starting out with a true rotor makes all other attempts more likely to succeed. Keep in mind rotors get dinged up in racks, or in cars etc.
