Retro roadies- old frames with STI's or Ergos
#4551
Would anyone be so kind as to recommend a Campy ergo groupset for a vintage steel build?
Things I'm looking for:
Alloy parts
A positive mechanical feel to the shifting. I've used ergo levers that either had plastic levers or just otherwise felt imprecise, flimsy and "smooshy"
Lightweight
Good looking
Athena 11 seemed like a contender, and the Ribble price is right, but a review pointed out the dreaded "plasticky" feeling downshifting.
Any fan favorites out there that meet these criteria?
Alloy parts
Lightweight
Good looking
#4554
you might want to try it before you accept some fancy reviewers comment of plastic feel. i have 2014 Athena 11 and 2014 Record 11 and the down shift buttons/levers feel the same to me. i.e., fast and accurate.
#4555
Liked 7 Times
I have an 11 speed Athena group and like it a lot. Took some time to get use to it because the group I had prior to that was a 10 speed Centar. The 10 speed had much more "feel" to each shift. The 11 speed seems lighter and smoother shifting. I choose the Athena roup because it came in silver finish.
I am sure if i went back to the 10 speed, it would feel clunky now.
#4556
1988 Schwinn Circuit
Thanks to Iowegian for passing along this frame.
My first attempt at a modern build on 'vintage' frame.
A bit of a parts bin mixture. Came with original Sante headset. Responded to a local CL add for the period correct wheelset (Dura-Ace hubset with Mavic rims), and the seller also happened to have a Sante Breakset, go figure. The rest of the drive train is 8-spd triple, Shimano 2300 (I know, everyone else on here has 105+, but it's what I had). I think the stem/handlebars are from my '91 Schwinn LeTour.
#4557
Very nice dpicare26!
I have been reading this thread for some while now. Very nice info! I'm in the middle of collecting more modern materials for my vintage bike.
I've got almost all the hardware in house to build up my late 80's Pinarello frame. I'll use it this summer for commuting 40km a day. Just bought a complete Ultegra 6600 groupset. All I have to do is find a nice wheelset. I have been looking for some shiny, brushed, silver alluminium but it's hard to find. Most of the sets today are black.
Today I found a set of 'Fir Mast' rims with Dura Ace hubs online, in good condition. But my question is, will this fit? The Ultegra 6600 groupset is 10 speed, while these wheels are for 9 speed. I understand that "old" 9 speeds are wider than "new" 10 speeds? Will this hub work with work? Maybe with a spacer?
Also, the space between both drop outs in the rear triangle is about 123 mm. Is that enough for a 10 speed setup?
#4558
Thanks for your input everyone. After a bit more thinking I've decided to go 10 speed.
I'd like an alloy Record/Chorus mixed group. Let me know if anyone is trying to get rid of something like that.
This will be for a late '80s Pinarello Montello I'm restoring to use as my "serious group ride" bike. Will definitely post build pictures here.
#4559
I initially was going to do the same, Campa Record/Chorus all the way, but I found it was hard to find a) reasonable priced hardware, b) any used, good condition hardware at all!
I bought a very nice pare of Chorus alloy brake calipers (Skeletons) but I don't have the patience to wait for the other hardware, I decided to go for Dura Ace/Ultegra instead. So I bought the groupset of Ultegra 6600. Alloy silver colored. Yesterday I got the set of wheels for a bargain, DA 7800 shiny, alloy hubs with Fir Mast rims.
I must admit that I like the looks of the Campa Chorus calipers more than the Shimano ones. I might use them on my Pinarello.
I am interested in how your bike ends up.
#4561
Quoted: 9 Post(s)
Sweet ride.. I had a chance to ride Dura Ace Di on a Pinarelllo Dogma (one of those crazy opportunities)... At first skeptical but then very impressed... Must put a smile on your face when you go through the gears. I bet when you pound on the pedals...your gone!
#4562
^^ Cannondale means business!!
My fair-weather ride hasn't been out in anger since getting back from Mallorca last October, but I've gone back to gum walls for the new season and looking forward to a few Summer miles.
#4563
Aspiring curmudgeon
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 111 Post(s)
Liked 26 Times
That's a beauty. How do you like the Clement Stradas? I've been thinking of picking up a pair.
"Party on comrades" -- Lenin, probably
#4564
Thanks! They're fresh on so I'll have to get back to you after a test ride. From personal reviews I've read they seem to be a good combination of a few things I'm interested in, particularly balancing puncture resistance with a good ride (and, unashamedly, good looks). So maybe not quite as supple and racy as something like Veloflex or Vittoria Open Corsa but a bit more sturdy. Also, I've always used 23c since back in the day, but now switched to 25c, hopefully making a comfortable ride even more comfortable.
#4568
Bikes: 97 Merlin XLight, 99 Merlin XLM
Indeed! TBH, I rushed a bit in the process. On the ST, there are still shadows of the old decals if you look closely (there's a coat of pearl after the OG decals were applied - hard to remove the very thin outline). But it's not too bad so..
#4569
Aspiring curmudgeon
Quoted: 111 Post(s)
Liked 26 Times
I think that Pin's also crying out for a Campy aero seatpost to match that sweet Record group, too.
#4570
You are absolutely right and I've been thinking about that! There's this chorus aero post in the local classifieds.. Decisions..
#4571
^ One thing I like about compact drops is that the area of bar immediately behind the hoods is also horizontal, with the hoods in the "correct" position, and I think it is this which you can't achieve with classic drops. Obviously it's personal preference as to whether you want that or not but I find when I'm resting on the hoods, this flat area is more comfortable for the fat paddy bottom of the palm that's just in front of the wrist, compared to the slight downward slope of the classic bars as shown above, e.g.:
(I've since angled the bars back by a degree or two, so the top of the hoods is ever so slightly closer to horizontal.)
#4572
Bikes: 2021 Rock Lobster Steel "All-Road" // 1989 Eddy Merckx Century TSX "Team Motorola" // 1995 Eddy Merckx Arcobaleno
Quoted: 10 Post(s)
Here is mine, I just finished building it. I've been riding a 2010 spec secteur elite compact with a 105 group since Jan (when i started). i can't believe how much more i love riding this bike.
Full list: Late 80's early 90's Merckx Corsa Extra (57cm top tube), early-mid 2000's Campagnolo Record Titanium Carbon (compact "ct" crankset and FD, RD, shifters/brake levers), Campy Chorus 10sp cassette, Campy Record headset, Campy Record Titanium brakes, older Campy Aero seatpost, new Cineli 1A stem, new Cineli Giro D'Italia bars, Mavic cosmic elite wheelset, Fizik Ardea saddle, Fizik soft touch bar tape, Michelin Krylion Carbon tires, Jagwire cables, Wipperman chain, Look KEO cardon pedals
#4574
Bikes: mid 1980s De Rosa SL, 1985 Tommasini Super Prestige all Campy SR, 1992 Paramount PDG Series 7, 1997 Lemond Zurich, 1998 Trek Y-foil, 2006 Schwinn Super Sport GS, 2006 Specialized Hardrock Sport
Quoted: 59 Post(s)
My Newest Build: 1992 Paramount PDG Series 7 with 9x3 drivetrain, featuring a tripleized Campy Record crankset, DuraAce 9-speed indexed downtube shifters, and Randonneur bars.
This came about when a local craigslist seller put this frame, in exactly my size, up for sale at a screaming bargain price, because he had had foot surgery and would be a long time away from riding. The frame is a beautiful steel frame made for Schwinn by Panasonic out of Tange Oversize Prestige tubing. I decided to build this up as a wide range 9x3 because I could get both tight spacing and some nice hill gears, which are definitely desirable in northern San Diego, I debated whether to go with brifters, or downtube index shifters, and went the downtube route for a few main reasons: 1st, I have found that on long rides, my hands tend to get numb with brifters because I hardly ever change hand positions, and 2nd, I wanted to go with friction shifting on the front triple, and finally, I couldn't find a nice set of Shimano brifters at a reasonable cost above Sora grade that supported a front triple, and ChainReaction cycles had a good price on the Shimano 7700 9-speed Index downtube levers.
The wheels were just some that I had lying around, and I might change the front wheel to a lighter, lower spoke count aero wheel. I finished the build on Thursday night, and took it out for some short shakedown rides to get the brakes and gearing adjusted yesterday morning. I then took it out for about 15 miles later yesterday, and another 25 mile ride today. In short, I LOVE this bike, especially the gearing set-up, which is a real Frankenbike combo of a Campy Record crank using Willow tripleized 51-39-29 chainrings, an SRAM 12-26 cassette (I may change to a Shimano 12-27 that I have on another wheel), an SRAM 8-speed chain which, experience had told me worked really well on a Shimano 9-speed setup, Ultegra 6703 front triple derailleur and a new Sora 9-speed rear derailleur, which was basically a throw-in on a ChainReaction Cycles order to get it above $99 for free shipping. I was originally going to put a used Ultegra 6700 rear derailleur that I had in my spare parts bin on this build, but when the Sora derailleur arrived, visual examination revealed it to clearly be functionally identical to the Ultegra 5700, and I mounted the new Sora RD instead of the Ultegra, because it looks sharp in black, whereas my used Ultegra 6700 is cosmetically not as nice. And BTW, the Sora RD shifts perfectly with the DuraAce downtube shifters.
The SR Randonneur bars and quill stem are a set I had sitting in a parts bin for 25 years that I had taken off of an older bike that I used to ride across the U.S. 35 years ago.
After a couple of rides with around 40 miles on this bike, I flat out love it. The frame is at least as responsive as my Tommasini SLX frame, and it's a hair lighter as well. And the franken-drivetrain is just fantastic.
#4575
I've upgraded my Miele Latina "road issue" to suit my riding style a bit more than the old tri-color crank I was running. I originally built it up with NOS 6400 hubs laced to mavic open pros and NOS 9 speed ultegra shifters, with the idea of upgrading to a triple and 6500 shifters place nicely with the triple. The front derailleur is IRD alpina and the crank is a sugino xd-600 so I still have tall enough gears I can push on downhills or when I have tailwinds. I also did a stem swap and put a Nitto Technomic Deluxe in place of the longer/shorter Italian stem that was on there and my hands don't hurt anymore so I'm pretty pleased with all the changes I've made to this bike. It's served me well so far this season, I've done 2 200K brevets on it and a couple metric centuries as well. I'm probably gonna use it for a 300km next week. I also put my magnesium bmx pedals on this bike since I can't handle the clipless thing.
