2016 Specialized Sirrus Pro Carbon - A stunning reverse on 2015's Drive Train
#126
Quoted: 16 Post(s)
So if I get a sram force gxp crankset it will fit the mega Evo bottom bracket on the bike?
#127
Quoted: 19 Post(s)
No. You will need a new bottom bracket to fit the shorter length SRAM Force 1 crankset spindle. The FSA BB is a strange 86mm length which requires a longer spindle. You could use a FSA carbon crankset if you don't want to purchase a new bottom bracket. The SRAM GXP BB utilizes the standard road length of 68mm and is threaded.
#128
Quoted: 16 Post(s)
Thanks
#129
Quoted: 19 Post(s)
#130
Bikes: 2015 Specialized Epic Expert Carbon 29 WC, 2015 Specialized Sirrus Carbon Pro
Hi, After a year or so, with the Flow Stem on my 2015 Sirrus Carbon Pro, I'm back on the search for a replacement ... can anybody advise a replacement headset, so I can fit a 'normal' stem, rather than the flow version I currently have ?
#131
Quoted: 19 Post(s)
I have a 2016 X1 model. You don't need anything special to not use the "flow" stem. Your bike should have come with a FSA conical spacer. You can use any stem you want. Just take off the flow stem and spacers, put on the FSA conical spacer and however many regular 1 1/8 spacers you need. I ended up changing mine out for a specialized 24 degree comp stem and drop handlebars.
#132
The problem is that the bike didn't come with a FSA Conical spacer, and I have yet to find a suitable one that will fit.
That is my only issue .... if you have a part number for the spacer you have, or can point me in the right direction, that would be great.
#133
Quoted: 19 Post(s)
Also, tell them you never received it in your "new owners pack". Mine was in with the instruction manual, owners manual, bleed blocks, etc.
Stephen105
General Cycling Discussion
5
02-04-16 09:33 PM
dblackcole
Hybrid Bicycles
5
08-24-15 08:46 PM
Chopstah
Hybrid Bicycles
14
01-27-15 04:37 PM
