Help me choose crankset gears: 46/36 or 50/34
#51
Quoted: 1096 Post(s)
Because having the chain rings closer reduces the associated rear shifting. On the 50/34 shifting the chain ring is usually accompanied with 3 or even 4 shift in the back if you only want to come up (or down) one gear. The closer spaced cassette, the worse it gets. 50/34 + 12-25 is especially bad in this respect
#52
Liked 10 Times
That kind of begs the question; why a close pair of chain rings (and all the overlap/redundancy) rather than a single one and wider ranging cassette? I don't know much about CX, but it doesn't seem that finessing ones cadence is much of a concern. If it's an effort to make it more road-worthy, 46 doesn't seem worth it, but maybe for others it is? Or am I missing something else?
my CX/gravel has 46/36 and an 11-36. I'll put a 34 on for this Vermont gravel ride i'm going to do but that has extended hills
#53
Quoted: 7653 Post(s)
Liked 3,479 Times
Probably though, making a 46-36 into a 46-34 would involve removing four or fiver bolts, swapping a ring and replacing the bolts.
#54
Liked 10 Times
Rigtht. CX (real CX) bikes are set up for racing not casual riding. 46-34 would make a lot more sense for casual riding, but fir racing they don't need that wide a range of gear options.
#55
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
I guess if you had multiple bikes maybe, but I just wouldn't ever choose to do that just for the simplification/weight of a second crank/shifter.
dave
#56
Bikes: BH, Cervelo, Cube, Canyon
Quoted: 212 Post(s)
Liked 6 Times
My road bike on flat to rolling terrain has a 36/46 11-28. I ride with fast groups and very rarely spin out. When I do, it's for a short time and I'm drafting to keep up. Total non issue.
What I like about the 46 is the chain line is perfect for my usual speed - 18-24 mph. When I had a 39/53, going below 18 would mean a front shift. It was terrible.
Now it's more like 13-14mph where I front shift, and since the rings are closer together, there's no double shifting involved.
Gear overlap is totally irrelevant.
#57
Quoted: 4717 Post(s)
Liked 1,882 Times
It occurred to me a while back that in all the riding that I have done since I returned to cycling in 2014, there probably isn't a single time where I actually needed anything lower than around 50/30. But I can't imagine limiting myself like that as maybe I will end up riding longer climbs some day.
#58
Non omnino gravis
I ran 48/36, then 46/36, then 46/34 all on the same cranks-- that 46T is just a gateway drug to ditching the front derailleur altogether. And yes, it's just a matter of taking out the chainring bolts, swapping the small ring and putting the bolts back in. I ran a CX70 46T with an Ultegra 34T for many, many miles.
#59
Liked 1,882 Times
#60
Non omnino gravis
#61
Liked 1,882 Times
this is true, but irrelevant to a flatland rider. With a 12-25t cassette, there are single tooth increases from 12-19. Things get wonky when people use 11-32t cassettes on flatland because of the gaps between gears.
#63
I dont think its irrelevant. I find the 4-5 cog shifts, when changing chain rings, highly annoying.
#65
Liked 3,479 Times
If your particular setup involves four or five shift (really? Half the cassette?) .. you must have a cassette wider than 11-28, or .. . whatever. I am not trying to invalidate your experience, but i certainly trust my own.
If you find the jump annoying .. well I can understand that. it doesn't bother me, but everyone is different. maybe it won't bother the OP. Maybe it will ruining his riding experience. Only one way to tell.
As noodlesoup notes, with a 50-34 and 11 cogs, the whole idea is not to jump between rings ... the cogs are generally close enough that a rider can avoid frequent front shift .. not like it was back in the day of five, six, or seven cogs, when swapping rings and cogs was essential to get the right cadence.
But, I repeat ... if it bothers you, it does, and thank you for sharing that and warning the OP that it might be an issue.
#66
" ... first off, it is three cogs between the rings,"
50/34 + 12-25 is 5 cogs.
"... you must have a cassette wider than 11-28,"
Its combining a wide crank, like a compact, with a narrow cassette, like the 11sp 12-25 that does it. Not a wide cassette.
https://ritzelrechner.de/?GR=DERS&KB=...&SL=2.3&UN=KMH
#67
Liked 3,479 Times
As i noted, the whole idea of the tight cassette and big jump in chainring teeth is to Not shift so much between chainrings, and to use the one-step differences on the cassette. For those who need .78 or .83 of a tooth difference, they might need to move to the other ring and move much further up or down the cassette ... but I haven't fond it happening to me.
The OP has 50-43x11-28, just like I do so hopefully, it will please him. if not, we have offered him a wealth of options.
#68
"Well, like I said ... i ride 50-34 and 11-28"
We (noodle and I) were discussing 50/34 +12+25. 50/34 + 11-28 is 3 cogs but that is (was) not the topic.
No one is talking about 0.75 toots jumps, and I have no idea why you argue with me. Do you?
#69
Liked 3,479 Times
#70
Bikes: Dahon Speed P16 (Upgraded P8)/ 2014 Dahon Vybe c7a / 2015 Trek 7.2fx / 26" Schwinn Ranger
Quoted: 49 Post(s)
I'd say get used to the gearing and try high cadence lower gear or high gear lower cadence and find out which one appeals to you more. For mostly flats, you can do middle gear then play around 50 or 34 chainring.
#71
Fax Transport Specialist
My cross bike had road tires on it most of the time, with either 48/38 or more recently (and preferred), 46/36 (and 11/28 cassette). I just got a road bike with 52/36 (11/28) last summer and I've used a 50/34 before. I'm a bit north of you, but along the fox river you probably have a few short hills if you seek them out? Check strava for your local climbs and popular routes. A few short climbs of 6-10% aren't hard to find further north (Barrington, Crystal Lake) and you can string them together.
A 36/28 will likely tackle the short hills around here once you have a bit of riding in your legs. I think it's easier to leave the bike in a 36 and not run out of gear when you're going from stop signs to cruising speed with a decent group (16-22mph up and down the rollers?). To me, as compared to the 34, it felt like the difference between being able to GET to cruising speed before needing to shift, vs. needing a shift to get there at a comfortable cadence.
That said, if you enjoy riding and head up to Wisconsin for the popular centuries, they have bigger hills and you may want a 34. I would suggest finding the steepest hill nearby and see how it feels spinning in the 34. If you're miserable, then maybe stick with the 34 (but you'll get faster as you ride more, of course).
Rupert2016
34
07-05-17 11:01 AM
JAMES_AMTRAK
"The 33"-Road Bike Racing
19
10-05-11 10:55 PM
JAMES_AMTRAK
Road Cycling
20
10-05-11 09:29 PM
