Decoding of Eddy Merckx frames
#326
Quoted: 234 Post(s)
Liked 400 Times
There are 2 possibilities:
- this is Corsa in "century geo"
- This is the Corsa Extra SLX with a mistakenly swapped designation X -> C
A safe way to check:
- Do the tube ends visible through the BB cover have "riflings"?
No = Corsa
Yes = Corsa Extra
No = Corsa
Yes = Corsa Extra
#327
Quoted: 33 Post(s)
Liked 125 Times
No riflings visible, so Corsa. Any thoughts on the paint, original versus repaint? Would the Corsa Extra decals be because it has the century geometry, making it better than the standard
Corsa? Date would be end of 1992 roughly? Thanks.
EDIT! I only just a few hours ago found out that you had already seen these numbers via Michael. What I will do in a week (lockdown here at present) is take the digital angle meter and check the angles to confirm the century geometry.
Likes For Seanaus:
#328
Liked 9 Times
Hi,
This thread is amazing. I need some help about the frame that I acquired a while ago.
I bought the frame from eBay. Seller told me it’s a repaint. I would like to know more about build of this bike.
I found the following inscriptions:
D 2X on the left side
D2217 on the right side
the decal states it’s an SLX
The top cable route is on the side and most of my google search are on the top part of the tube.
thank you for your help.
#329
Quoted: 234 Post(s)
Liked 400 Times
D2X D2217 - Corsa Extra SLX built in spring 1992
"Cable route" is an extra paid option available
On the steering tube you can sometimes find "old paint" or information on an attached piece of paper
#331
Liked 9 Times
I can see a little bit of pink paint, I don’t know if it’s the base coating. There’s no piece of paper attached but there’s a marking of a dove with a code D 3. The paint is exactly the same as the team USA color that I found on google.
#332
Quoted: 33 Post(s)
Liked 125 Times
Likes For Seanaus:
#334
We'll know soon enough for sure. The standard geometry I see in one of your catalog posts is what a normal Corsa would be? I found this chart of (supposedly) the Merckx Century geometry, does this appear correct to you? Is it correct that the MX Leaders were made with the Century geometry? Regards Sean.
#335
What did you ever find out about your frame? Mine has puzzled me SO bad. Columbus sticker and BB stamps say TSX tubing. That would be a Century. Top tube decal says Corsa Extra. And it seems to be a legit decal. Under the clear coat. Then again, someone could upbadge and then coat it. Here is mine, same team col
ors as yours
ors as yours
I think that the Merckx factory would make custom frames quite often, at least for the European market.
My guess is that for the American market, they would just stick to what they had in the catalogue.
#336
Quoted: 234 Post(s)
Liked 400 Times
Jmsoto - the photos would definitely be useful
geo "road racing" introduced in 1980 and used for at least 15 years; Professional/Corsa, Pro/Corsa Extra, 3-Athlete/Strada models; full table in EMC 1994 catalog (grey cover, Titanal model inside)
"century" geo introduced in 1988, in serial frames used until 2003; models Century, Corsa Max/Mx Leader, Arcobaleno, Corsa Thron, Corsa 01, Corsa Extra, Strada OS , alu frames, titanium frames; your table is "century" geo
"century modified" geo introduced in 2003 for alu frames (elongated TT, no change angles), used until 2008
L4C D4691 - Corsa (Columbus SL) built in October 1992
Translated with www.DeepL.com/Translator (free version)
Likes For CyclesMakaron:
#337
#339
Sorry. I'm confused and I don't understand, is the Corsa model equal to the Corsa Extra? Is Corsa pipe class lower than Extra? The Corsa in 1992 was called MXL ? Having read a branch of a forum, I was confused. Thank you.
#340
Liked 9 Times
#341
Quoted: 234 Post(s)
Liked 400 Times
Relax
Corsa is a basic model (Columbus SL/SP or Reynolds 531 tubes)
Corsa Extra is a higher model (SLX/SPX, TSX, Max or Reynolds 753 tubes)
Mx Leader is the highest model, created from the development of the Corsa Extra Max model (Columbus Mxl tube).
#344
Liked 9 Times
#345
Merckx frame id help
Please help id this Merckx frame. It has these markings under the bottom bracket shell ?is this a Strada ? Thanks
4x A 7545
4x A 7545
#347
Liked 9 Times
Here is the photo
Likes For Jmsoto:
