#4051
Quoted: 1200 Post(s)
Liked 1,356 Times
I noticed the smallest cog from my freewheel was too close to the DS drop. Using a crankset from my Gios and a chain I had absolutely no clearance. I moved the silver spacer from the NDS to DS of the hub axle. Worked perfectly.
Also did a quick new grease job on the hub bearings.
#4052
Quoted: 4513 Post(s)
Liked 6,391 Times
Hey, quick question: I'd like to buy a cartridge style bottom bracket for a trek 420. I'm using a Sugino Maxy crankset with a single chainring. I've been looking at charts, searching through forums, googling like mad, and I feel completely mystified by the standards, spindle lengths, etc. Anyone either have a decent resource to suggest or know this stuff offhand? Thanks!
Also plenty here that know this sort of thing much better, hopefully they will chime in.
Likes For merziac:
#4053
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
As far as spindle length goes, I look for a chainline around 4.3-4.5 cm as measured from the middle of the seat tube to the middle of the two chainrings (if using a double with two chainrings).
Likes For SurferRosa:
#4054
Quoted: 7353 Post(s)
Liked 2,481 Times
@JacobLee, I suggest you replace those calipers. Despite the Dura Ace name, these are not very good. It was the first time they used that name, and it was later when they decided to put it on their best offerings.
#4055
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
#4056
señor miembro
Liked 6,491 Times
@JacobLee, I'd replace the pads before you replace the calipers. Pads with long studs, even though they're threaded, remind me of the type usually used with cantilevers. Those aren't necessary at all with your center pulls and just make things more complex than they need to be. And they look a little out of place.
#4057
Total Scrounge
Quoted: 327 Post(s)
Liked 924 Times
#4058
Quoted: 2588 Post(s)
Liked 4,826 Times
Swapped out these:
For these:
Prepping the Super for the new owner. The milled levers bend - and threaten to break - when going from small to big ring. Hopefully it stays dry so I can do a final function check before the new owner assumes the watch on Wednesday.
DD
For these:
DD
Likes For Drillium Dude:
#4059
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Not so much wrenching on as wrestling with. The Cannondale hybrid I found in the co-op's dumpster found a fan in trailmix , who has shown some interest in rehoming it. I finally gave up on finding a box of the proper dimensions and decided to make my own, so this thing will finally be able to leave my garage and go away.
#4060
Quoted: 835 Post(s)
Liked 2,152 Times
A couple French things and a mixte for my daughter.
Likes For gaucho777:
#4061
WV is not flat..
Rebuilding a very nice condition Ross Signature 294S and just took this shot looking down the row of wall hangers to see what the next rebuild will be.
#4062
Liked 2,446 Times
#4063
WV is not flat..
Likes For brandenjs:
#4064
WV is not flat..
Tear down complete on the Ross 294s. I love when the bench is covered in cool parts!
#4065
Liked 6,391 Times
Likes For merziac:
#4066
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
Removed the bottom bracket from my steel Colnago. The bearings felt fine, but a new Chorus Ultra-Torque crankset is coming my way, and the Italian cups just arrived so I thought I'd get a head start on this.
I'm really glad I did, I've never had this bottom bracket apart - never needed to, but I do know it's something that should be done yearly, but certainly 99% of us don't.
It was not easy, even soaked with WD-40 and with my giant cheater bar everything was "at the limit" and I was slightly concerned I might strip the teeth on the bottom bracket. Obviously, that didn't happen. Nice to get it out and cleaned up, and ready for a newer crankset with outboard cups.
#4067
Liked 6,391 Times
@ridelikeaturtle
Great work, glad you were successful getting out in front of it.
I don't do it yearly BUT I always remove the fixed cup when I have one apart, every time, period.
And am always amazed at the derision when we have this discussion.
Likes For merziac:
#4068
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
It's always a surprise what you will find in those places and I too have had my share of stuck bottom brackets that needed cheater bars.
I decided I wanted to use the front rando bag on my other bikes as well and while the magnetic fittings of the Restrap x Pelago work pretty well they are also wider that the normal rando bags.
So I got myself a pair of Grand Bois 'Velo du Reve' EB bag clamps so the bag can be used on both the SilverAce, my girlfriend's Gazelle Lausanne and the WorldTraveller.
Still needs some slight cleanup on the inside but it feels solid as a rock.
Likes For JaccoW:
#4069
Liked 1,356 Times
Touched up the panto on this SR crankset for a buddy. I painted the flutes but they didn't look right to me so I removed the enamel paint.
Likes For malcala622:
#4070
Quoted: 605 Post(s)
Liked 480 Times
I picked up a Trek Y11 back in December, knowing the rear pivot bushing was a bit worn, and a little sloppy - and also knowing these aren't available. On the bright side, I got a very nice little bike for not much money.
I did find a pivot bushing for a Fisher Sugar, and took a chance that it was either the same or close... and I got lucky! Same all around, just slightly longer. Got out my grinder, finished it off with the file, and voila! It's much, much better now, a lot less slop than before.
[Edit] the bushing I used is for a Fisher Sugar, "Pivot Axle Bushing", I got it from pedalon[dot]co[dot]uk, their reference number is W200091. Maybe this can help someone in the future looking to replace the pivot bushing for any Trek Y11, Y22, or Y33 (it's all the same frame).
#4071
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times
I went from 48/16 to 46/18. It’s a bit hilly here depending on route, so tough to balance staying on top of the gear for the most part without hitting that valve float feeling too often.
Likes For Sir_Name:
#4072
Quoted: 339 Post(s)
Liked 632 Times
Been working on this 1975 Windsor Carrera special . I just painted the frame cherry red and am waiting on decals . I also just finished painting an SR Semi Pro. It is hammered Copper. You can see the fork in the second picture. After a lot of trouble with the Rustoleum Clear which aligatored the paint, I finally got a nice coat of paint on it. I am not going to use clear anymore except over old hard paint. The acetone solvent in the clear reacts with the paint underneath unless it is VERY well cured.
Likes For capnjonny:
#4073
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
cyccommute
Picked this up on Sunday and doing the usual service...Thanks to Stuart's advice (honestly why haven't we been doing this all along, nothing like the B.W.E!) it made removing and servicing the BB a breeze. I used a socket instead of BB cup. The hardest part was cleaning off the dried Campy grease on the cups and bearings.
It's relatively clean with just very minor chips to the paint.
I will be ordering some other consumables later.
Best, Ben
Best, Ben
Voltaire
Voltaire
#4074
Bikes: Bianchi Nyala, Bianchi Volpe, Bianchi Campione D'Italia, Trek 640, Luxus folding bike, Schwinn Speedster, Bianchi Torino, KHS Aero Sport, probably something else around here somewhere
Quoted: 117 Post(s)
Liked 198 Times
I really should have measured the Nyala specs before ordering the headset. That was a big time suck of a mistake. "Luckily" it's too cold to ride it anyway. https://www.re-cycled.net/posts/2021/02/nyala-oops/
#4075
Bikes: 82 Trek 710, 90 Trek 750, 86 Vitus, Nishiki Cervino, 1989 Bianchi CdI, 2 Nashbars, an Italian Steel MTB, Sears Spaceliner, and a 74 Schwinn Speedster. I also manage a fleet of Volcanic Patrol bikes, 83 of them.
Quoted: 109 Post(s)
Liked 234 Times
cyccommute
Best, Ben
Best, Ben
I was looking for a frame to build and came across this on Craig's list. Never was a big Bianchi geek but once the weather clears up I'll ride it and see what the fuss is all about. I stripped everything off and cleaned and waxed the frame. Lubed all the bearings, replaced the Shimano cartridge bearing bottom bracket (don't think that was original) with a SKF roller bearing bb, new gear cables and San Marco saddle.
I ordered a pair of Modolo brake levers and Celeste cable housing.
Likes For Jmpierce:
