Adult Tricycle Differential
Old 10-16-17, 11:37 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Rear would have 2 axles 1 for the wheels, the other for the drive shaft that would turn the freewheels on its ends
and have 2 short chains to fixed gear hubs..
like they did on cars in the Victorian era...
NB: there are a few left hand threaded freewheels .
driving a simply flipped over RH one would unscrew with power applied..
regular hubs, just have driven gear to the right of the rim, like on a bike.
weld up the frame to support both ends of the axle, maybe bodge 2 bike frames to be working the drive.
fietsbob is offline
Old 10-18-17, 09:23 AM
Glennfordx4
Glennfordx4's Avatar
Quoted: 90 Post(s)
Liked 137 Times in 45 Posts
While I have seen Diffs listed for trikes in the past I have not lately. You can look at some Lawn Mower supply places or local Small engine repair shops for something that would work. Back in the 70's & 80's small Riding mowers were built using them some with axles as small as 5/8" dia and some had sprockets that worked with singe speed 1/8" chains on their drive sprockets.
Glenn
Glennfordx4 is offline
Old 10-18-17, 02:06 PM
Doug5150
Quoted: 111 Post(s)
Liked 5 Times in 5 Posts
Originally Posted by curbowman
... However, it should be noted that having two wheel driven in the rear is not really necessary if the wheels are on solid floors or pavement. Usually, having a single driven wheel with a freewheeling one is enough. That's why Samagaga also provides an "easy turn" gear system.
SAMAGAGA
The problem with using double freewheels instead of a differential is that the drive torque always goes to the wheel that is rotating the slowest. This characteristic prevents you from making sharp turns.
For example--in the case of a delta trike, where you want to turn so sharp that the trike basically pivots on one of the rear wheels, and one rear wheel doesn't really spin at all. For a trike that is used in confined spaces or at slow speeds, you end up doing these kinds of turns a lot--and not being able to do them becomes a major annoyance.
A differential can do that, but a double-freewheel axle can't.
And a single-drive rear wheel can only turn one-way (either left or right, which ever is opposite the drive-wheel side, but it won't let you turn both left and right).
Double-freewheel axles work much better well for off-road or slippery-surface use but a real bicycle differential is still better for high maneuverability on solid ground.
Doug5150 is offline
Likes For Doug5150:
Old 10-18-17, 02:41 PM
fietsbob
Bikes: 8
OK Doug I suspect the guy wants us to search the internet for him and offer a link, it happens a lot
fietsbob is offline
Old 10-21-17, 11:22 PM
Jeff Wills
Insane Bicycle Mechanic
Jeff Wills's Avatar
Quoted: 809 Post(s)
Liked 712 Times in 380 Posts
Say what? Links for the Samagaga differential were posted above. What more do you want?
Jeff Wills
Jeff Wills is offline
Old 10-23-17, 05:31 PM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
As you move forward on this you may want to incorporate an electronic peddle assist and steering. I can see steering being a bigger issue since it is done by adjusting the speed/direction of one of the rear wheels.
John
70sSanO is offline
elizilla
Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs
14
05-22-23 02:25 PM
Grandpa1946
Electric Bikes
4
09-22-15 12:29 AM
DCBIKEFOROSAZE
Alt Bike Culture
5
08-02-13 03:57 PM
medusa
Bicycle Mechanics
10
07-23-11 10:30 AM
JonnyHK
Bicycle Mechanics
41
12-16-10 01:00 AM
