Straight Gauge or Double-Butted Spokes?
Old 04-11-19, 05:53 PM
TiHabanero
Quoted: 1746 Post(s)
Liked 1,376 Times in 721 Posts
From the DT Swiss website. It reflects my experience in the shop.
" Is there any significant loss in strength between a J-bend or a straight-pull spoke in real life?
J-bends spokes tend to suffer more breakage issues due to poor build quality and low spoke tension. Also, some hubs have spokes holes too large, which causes poor fit of the elbow. Most of the time you can chalk up premature J-bend spoke breakage to corners being cut in the wheel-building process. For example: it's always surprising to me to see a shop build wheels without the use of a spoke tensiometer. To me, that's like trying to build a house without a tape measure!."
Another tidbit of information is the forming of the butted spoke compacts the middle section of the spoke, pushing the grain together.
My body weight is 230 and I only use straight gauge spokes. Have zero issues until I bend a rim and then they start popping. Replace the rim and all is good again. Have at least 60,000 miles on my bikes and only a bent rim has caused spoke breakage with the exception of Wheelsmith spokes. They do not fit tight enough in the hub holes and break very easily.
TiHabanero is offline
Old 04-12-19, 08:31 AM
Jon T
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times in 39 Posts
Thanks again to all for your input.
Jon
Jon T is offline
Old 04-13-19, 08:50 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6222 Post(s)
Liked 4,222 Times in 2,368 Posts
That “tidbit” has been out there for a while and it has been very wrong. Metals can’t be compressed. The act of drawing the spoke might change the grain structure but it doesn’t “push the grains together”. There is no void between grains. The implication of pushing the grain together is that the density of the metal is increased. That is impossible.
Stuart Black
cyccommute is offline
Old 04-14-19, 01:58 AM
Trevtassie
Quoted: 1188 Post(s)
Liked 1,154 Times in 640 Posts
The other things to do when you are lacing or replacing spokes is to set the outside J bends with a small hammer after applying some tension, and to stress relieve the spoke late in the tensioning process, this helps seat the spoke head and stops flexing at the bend.
Trevtassie is offline
Old 04-14-19, 10:38 AM
Jon T
Quoted: 397 Post(s)
Thank you Trevtassie.
Jon
Jon T is offline
Old 04-14-19, 10:55 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
And adding to minutiae, in the Rohloff service handbook , they suggest filing off
The flashing left by the spoke head forming machine, (back side of the head)
so as to not have it make an impression in the hub flange start creating a stress riser,
and stress risers in aluminum has been found to grow into a crack.. ..
(not just in 1 brand , or only hubs, but generally )
fietsbob is offline
Old 04-14-19, 11:41 PM
Jon T
Quoted: 397 Post(s)
Fietsbob,
Makes sense. Will do when I relace the wheel. I think I'm gonna' use the SAPIM "STRONG" single-butted spokes with the 2.3mm hub-end diameter. It should fill the holes better and have less movement and stress at the J-bend. Again, thanks to all for your input.
Jon
Jon T is offline
Old 04-15-19, 05:54 AM
Trevtassie
Originally Posted by Jon T
Fietsbob,
Jon
Hi Jon,
You need to be careful with the Sapim Strongs, I've used them for a full wheel build and they were a PITA on the NDS, I couldn't get the DS tight enough to keep the NDS tight enough to stop unscrewing without using wick in loctite 290. Once they were loctited though they were good, didn't budge. But ideally you'd use the Strongs on the DS and a thinner spoke on the NDS.
Old 04-15-19, 06:08 AM
Trevtassie
Mostly that's because of the Rohloff hub being turned, not forged, so the flanges are prone to cracking.. It's also why Rohloff came up with the flange reinforcing rings.The filing helps makes a bad situation better.
It's strange, but mass produced hubs can sometimes be stronger than bespoke ones.
Old 04-15-19, 07:42 AM
Jon T
Quoted: 397 Post(s)
Originally Posted by Trevtassie
Hi Jon,
Good to know. Thank you, Sir, for the first-hand experience info. I will follow your advice and lace the "Strongs" on the DS and the triple-butted "Force" on the NDS. I read about that combination a few nights ago. It's great to have the confirmation of the info.
G'day Mate.
Jon
Jon T is offline
Old 04-15-19, 10:08 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
Sounds like a plan. Now if any spokes break, it won't be their fault.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 04-16-19, 01:46 PM
davester
davester's Avatar
Quoted: 932 Post(s)
Liked 1,319 Times in 491 Posts
A lot of good advice above, especially using different spoke diameters on the DS vs NDS. I'm surprised that more people don't do this since it addresses a fundamental problem with rear wheels. If you don't want to spend money on a spoke tensiometer, try out the iPhone app "Tensioner". It's cheap and it works, though it does take a bit of time to figure out the proper technique for getting a tone (read the instructions very carefully). Also won't work if you're in a noisy room...even the refrigerator interferes with it. I've built wheels without a tension measuring device in the past but wouldn't again with this so easily available.
davester is offline
Old 04-17-19, 08:59 AM
Jon T
Quoted: 397 Post(s)
Again,
Thanks to all for your input and helpful advice. I'll keep you posted.
Jon
Jon T is offline
Old 04-17-19, 06:45 PM
TiHabanero
From DT Swiss website: "The forging process allows the metal to be compressed into a denser package and this strengthens the metal by aligning the grain, giving rise to a part with improved strength characteristics."
DT forges their DB spokes, they do not draw them out. Perhaps they are incorrect in saying the process compresses the metal into a denser package?
Old 04-18-19, 08:23 AM
cyccommute
cyccommute's Avatar
Yes, they are incorrect. When you forge metal, the metal doesn't get denser. It moves and the grain structure changes but it doesn't increase in density. The density is the number of atoms of molecules packed into a give volume. You can heat or cool the metal to change the density but that is only because the volume changes. The number of atoms remains the same. When DT (or anyone) forges something, they may compress it into a smaller volume but the number of atoms per a give volume remains the same. Any excess material is squished out the end of whatever they are forging with.
Stuart Black
TiHabanero
Bicycle Mechanics
58
08-12-19 05:53 PM
Scooby Snax
Bicycle Mechanics
35
12-21-14 08:51 PM
CJ Str3tch
Bicycle Mechanics
18
08-17-12 05:07 PM
nazran
3
07-25-11 04:54 PM
Jtgyk
Bicycle Mechanics
16
05-06-10 12:50 AM
