Show Your Vintage MTB Drop Bar Conversions
Old 08-13-20, 07:01 AM
  #6801
wintermute
Bikes: 1980 Motobecane Grand Jubile, 1986 Kuwahara ATB, 2006 Bianchi Volpe, 2016 Salsa Fargo
Quoted: 20 Post(s)
Liked 29 Times in 17 Posts
Originally Posted by dickbandit
Posting my 1988 Univega Alpina Uno in here again.
It went through a period with full fenders, racks and basket-- (first photo) but it started to see some singletrack so I stripped it down and put some tires on it that could handle the dirt a little better. I recently swapped the exage rear derailleur for a Suntour VX GT that I had in the parts bin. It's anachronistic, but it shifts better and looks way cooler. Swapped out the exage front cantis for some tektros.
Just picked up the Ruth Works Brevet bag which has the perfect capacity for the 30-60 miles rides I tend to take this bike on. Did a route the other day that had singletrack, gravel and pavement. Perfect.
I love the grip idea! Makes so much sense on dirt drops!
wintermute is offline
Likes For wintermute:
Old 08-13-20, 07:26 AM
  #6802
revcp
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times in 65 Posts
Originally Posted by HenryhHuber
​​​​​​​Wow! Excellent work! Bike looks modern but not out of place with those components! What tires you running?
Thanks. Th
Don't complain about the weather and cower in fear. It's all good weather. Just different.
revcp is offline
  #6803
revcp
Quoted: 286 Post(s)
Thanks. Those are Vittoria Randonneur Pro 1.5".
revcp is offline
Old 08-15-20, 11:00 AM
  #6804
B17
Quoted: 24 Post(s)
Liked 11 Times in 4 Posts
Okay, she's done, for the most part! The brifters will need to be realigned (left is too low- should have checked before taping), but other than that, good to go.
Nishiki Meridian Drop-Bar Hybrid Project
Frameset- Nishiki Meridian, 18", refinished in Ford Magnetic Metallic Grey under 2K clear
Handlebar- Origin8 Gary 2
Stem- Sunlite 80mm 25 degrees, quill shortened 1"
Headset- Tange Passage
Seatpost- Strong Classic
Saddle- Fizik Rondine
Brifters- Campagnolo 8-Speed Ergo
Brakes- Tektro CR720 Cantilevers
Derailleurs- Suntour top-pull front, Campagnolo Mirage 8 medium cage rear
Crankset- Samox Pinnacle w/Shimano BB, 36/48 Sugino rings
Chain- KMC
Pedals- Velo-Orange Touring, no clips/straps yet
Wheelset- Shimano Deore hubs laced to Alex Rims, Shimano-spaced 7-speed Nashbar cassette
Tires- Panaracer GK Slick 700 x 38mm
Misc- Fizik bar tape, Rustines rubber bar plugs, Jagwire cable housing, Ciussi bottle cages
Ridewise, it's perfect for me. The effective top tube is 22"/55.8cm, making the Origin 8 Gary 2/Sunlite cockpit a great match. Doesn't stretch me out too much, and provides easier access to the drops. The GK slicks are a perfect all-round tire IMO for anyone who isn't racing. Back in the day (70s/80s), I rode 27" x 1.5" recreationally on the road, so a 38mm size is the logical replacement. There's enough clearance for 50mm tires if I want. Shifting Shimano 7 with Campagnolo 8 brifters and RD from my parts bin. No disrespect for vintage STI, but I want my cables under the tape, end of story. None of those aesthetic mods compromise the function for my riding.
B17 is offline
Old 08-16-20, 07:43 PM
  #6805
Bob the Mech
Bob the Mech's Avatar
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 61 Post(s)
Liked 76 Times in 55 Posts
Orange C16R 1996 Full rigid XC Mountain Bike 26er Drop Bar Conversion.
Images at bottom of list
Frameset: Series F8 Custom Double Butted Cromoly, 17" frame with Series F7 Custom Double Butted Cromoly forks, 1" steerer.
Handlebar: Selcof Sterrato Flared 31.8mm, 420mm W, 125mm D, 70mm R, black 6061 T6.
Stem: On One Hot Box, 7 degree, 80mm, 31.8mm clamp, 1.125" steerer fit. System Ex Quill Ahead Adaptor, 1" to 1.125", with 25mm spacer
Headset: Shimano HP-MC30 STX, 1" (NOS)
Seatpost: On-One Twelfty 350mm, 12mm lay back, 27.2mm diameter, 6061 T6
Saddle: Charge Spoon, brown, cro-mo rails
Brifters: Shimano Sora 3500 STI, 2 x 9.
Brakes: Tektro 992AG Oryx Cantilever front and rear. with Jagwire Road Pro cable set.
Derailleurs: Shimano Alivio RD-M4000, 9 speed rear. Shimano XT, FD-739, top pull 8 speed front with Jagwire Road Pro cable set.
Crankset: Stronglite Impact, 6061 Alloy, 110mm BCD, 5 Arm. Length: 170mm, JIS square taper, self extractor. Stronglite Dural 5083 Alloy, 46T and Shimano Sora FC-3550 Steel, SG-X 34T.
Pedals: Shimano PD-520 SPD.
Bottom Bracket: Shimano UN-72, 110mm axle, 68mm shell.
Chain: KMC X9-93, 9 Speed.
Wheelset #1 (Gravel / CX bias): Shimano Deore T610 hubset. EXAL Xtreme M-ZX19, 36 hole eyeletted rims (external W: 24mm, internal W: 19mm, depth: 21mm), 2mm DT Champion stainless straight gauge spokes. Shimano HG400, 12-36, 9 speed cassette.
Tyres #1 (Gravel / CX bias): Schwalbe CX PRO 35c-559 (26 x 1.35)
Wheelset #2 (Road bias): Shimano Deore T610 hubset. Mach 1 MX 6063 T6 alloy 32 hole eyeletted rims (external W: 23mm, internal W: 17mm, depth: 21mm), 2mm stainless straight gauge black spokes. Shimano HG200, 11-34, 9 speed cassette.
Tyres #2 (Road bias): Continental Contact Speed 32c-559 (26 x 1.30)
Inner Tubes: Schwalbe 25/40-559 (26 x 1.00/1.50) SV12A, 40mm Presta valve
Misc: Generic 2mm, punched, brown (double wrapped to the hoods) bar tape, Deda bar plugs, Jagwire Road Pro cable set (gear and brake), Cane Creek 27.2 mm to 29.6 mm, seat post shim, a2z 135mm OLN, 100mm OLN, alloy anodised orange, cro-mo spindles QRs, Zefal Aluplast 124 Technopolymer beam / Aluminium bottle cages, A2 Stainless steel M4 dome head hex cage boss bolts, in line adjusters on rear brake and front mech cables, Tektro 1277a fork mount alloy cable hanger, Tektro 1267A seat post clamp, with cable hanger, 31.8mm diameter, Crud Catcher (original, fitted as standard to the Orange).
Weight: Gravel / CX bias = 11.53 Kg / 25.42 lds. Road bias = 11.22 Kg / 24.74 lbs.
Cost of conversion: £623.01 / US$816.02 over 26 months. Offset against commuting cost savings of £378 / US$495.11 per annum. It will pay for itself in 1 year, 7 months and 23 days (ish)
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Bob the Mech is offline
Likes For Bob the Mech:
Old 08-18-20, 11:57 AM
  #6806
bOsscO
bOsscO
bOsscO's Avatar
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times in 212 Posts
Looks great! How do you like the low-pro Chester pedals?
bOsscO is offline
Old 08-18-20, 04:21 PM
  #6807
dickbandit
dickbandit's Avatar
Bikes: 1980 Peugeot PFN-10, 1989 Bridgestone MB-3, 1988 Univega Alpina Uno, 1974 Velosolex Saint Tropez, 1995 Trek 830, 1986 Lotus Odyssey, 1987 Schwinn Mirada, 1987 Raleigh Elkhorn
Quoted: 21 Post(s)
Liked 99 Times in 32 Posts
I like them a lot. Really grippy and comfortable for me. This bike had the original bear traps, which were fine, but their size was a little smaller than I prefer for off-road platforms.
dickbandit is offline
Old 08-21-20, 08:51 AM
  #6808
bOsscO
bOsscO
bOsscO's Avatar
Quoted: 296 Post(s)
Right on. I decided to go with the One UP composite pedals as they were priced less than the RF and I like the design more; https://www.oneupcomponents.com/coll...cts/comp-pedal
bOsscO is offline
Likes For bOsscO:
Old 08-21-20, 10:10 AM
  #6809
gravelinmygears
Bikes: 64 Cinelli, 81 Merz, Haral
Quoted: 127 Post(s)
Liked 145 Times in 69 Posts
Nice!
I think you nailed it. What a "well curated" bike. Perfect commuter and adventure bike.
gravelinmygears is offline
Likes For gravelinmygears:
Old 08-25-20, 10:00 AM
  #6810
fliplap
Quoted: 97 Post(s)
Liked 328 Times in 105 Posts
Apparently we're a Mirada household now. I'd been waiting for one of these to show up at the co-op as a bar/grocery bike for my wife. 1985ish Mirada Mixte. Mix of Deore (derailleurs), XT (brakes & pedals) and 600 (levers) components, whatever was in the co-op parts bin, shifted by 8 speed Shimano bar ends. Bars are Nitto B115s covered in some real nice feeling leather tape that everyone had decided was too much hassle. The stem is a Tioga T-bone chromoly deal. Fenders are rusty steel from a Huffy on the scrap pile. I think the crank and the headset are the only things left from the original bike.
fliplap is offline
Old 08-25-20, 10:33 AM
  #6811
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 646 Post(s)
Liked 1,044 Times in 667 Posts
I’ve switched this bike back to SS and back to drop bars. I don’t really like this new picture because the driveway isn’t quite level with the door so it looks a bit odd.
Anyway it’s an ‘88 RockHopper that has seen probably 8000 or more miles on crushed stone trails and connecting paths since I got it about three years ago.
Otto
ofajen is offline
Likes For ofajen:
Old 08-25-20, 02:05 PM
  #6812
pbpbbq
Liked 10 Times in 7 Posts
Otto
That looks like sooooo much funnnnnn
pbpbbq is offline
Old 08-25-20, 02:34 PM
  #6813
abshipp
abshipp's Avatar
Quoted: 3361 Post(s)
Liked 3,638 Times in 1,244 Posts
Well, well, well....what do we have here
1998 Hardrock Sport. Not the fanciest bike, but it's at least DB chromoly and in really great shape. And the top tube is about 22.5", right where I like it for drop bar bikes .
Oh, and it was free!
Trying to decide what route to go with it - either keeping the V-brakes and running drop bar levers with barcons or switch to cantis and run an 8 speed Campy Mirage triple group.
This will be my second experience with 26" wheels, the first being a 1985 Mirada that I did not get along with at all. This geometry looks a lot steeper in the front end so I think it will be a bit better feeling ride for me.
abshipp is offline
Old 08-25-20, 03:10 PM
  #6814
rhender
Bikes: Giant TCR Advanced Pro 2; 1988 Cannondale SR500; 1992 Bridgestone XO-2
Quoted: 28 Post(s)
Liked 10 Times in 8 Posts
Wow this thing is so cool! Guess I'm on the lookout for Schwinn Mirada mixte now...
rhender is offline
Likes For rhender:
Old 08-25-20, 03:40 PM
  #6815
droppedandlost
small ring
droppedandlost's Avatar
Quoted: 438 Post(s)
Liked 925 Times in 370 Posts
This bike belongs in the Baja 1000
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
droppedandlost is offline
Likes For droppedandlost:
Old 08-25-20, 04:28 PM
  #6816
abshipp
abshipp's Avatar
That is absolutely checking all of the boxes for me. Kudos
abshipp is offline
Old 08-25-20, 04:51 PM
  #6817
mattk42
mattk42's Avatar
Quoted: 23 Post(s)
Liked 48 Times in 19 Posts
That is just super. Is that a 650b conversion or that accommodating for 700c/29er tires?
mattk42 is offline
Old 08-25-20, 05:19 PM
  #6818
fliplap
Quoted: 97 Post(s)
Those are 26"/559 x 2.1"
fliplap is offline
Likes For fliplap:
Old 08-25-20, 08:54 PM
  #6819
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 646 Post(s)
I’ve really enjoyed this as a drop bar bike. It’s my main bike in the winter and spring when our trails are either frozen or soft (or some of each).
If need be, I have a wheel set with Race Kings that I can put on if things are tending to be soft and slippery. Right now it has the wheels with smooth tires.
And it’s my main ride in summer if I’m going on a route with anything like bigger gravel or if I just want the big tires to baby me.
I even have an extra 26” wheel with a Continental Hometrainer for the month or so in the worst of winter where it might be cold enough or dangerous enough on the trails to tempt me to ride indoors, but I’m more likely to just do a strictly road ride as soon as the ice clears, because I’m not that into riding on an indoor trainer.
Otto
ofajen is offline
Old 08-26-20, 08:09 AM
  #6820
wintermute
Quoted: 20 Post(s)
I'm not a big fan of mixtes, especially with drop bars, but something about this makes it look bad@$$ - like a proto-Fargo.
Old 08-27-20, 02:52 PM
  #6821
bOsscO
bOsscO
bOsscO's Avatar
Quoted: 296 Post(s)
Originally Posted by neo_pop_71
The front derailleur is almost always the hang up with this set up as it really depends on the crankset you are running. You can get away with a "mountain" (XTR, XT, LX, etc.) front derailleur if you are running a compact mountain crank. However, if you are running a chainring larger than 44T (typically), you will need a "road" (Dura Ace, Ultegra/600, 105, etc.) front derailleur because the length of the cage and the curvature of the cage can handle the throw of the chain without binding up on the larger diameter rings. It really doesn't matter if you are running a double or a triple crankset, the limit screws can be let out to handle either but the size of the cage is the sticking point. When I set up my '88 Cimarron LE with the Sugino Super Maxy double (48/38) crank I had to run a 105 front derailleur, this proved helpful later when I decided to run a STI brifter.
Quoting 7-y/o posts from this thread to see what's changed in the ability to use STI style brifters on an early 90's MTB drop bar conversion. Sounds like I should be able to run brifters if I;
- use a compact crankset
- biggest chainring is 40 tooth
- Road FD does work but MTB FD may work
- Stick with linear pull caliper brakes like the IRD Cafam 2
Anything critical I'm missing?
bOsscO is offline
Old 08-27-20, 03:34 PM
  #6822
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times in 601 Posts
^^^ Linear pull calipers? Or did you mean linear pull(V) brakes? You'll be fine with cantilever brakes with brifters.
2cam16 is offline
Old 08-27-20, 06:06 PM
  #6823
Bob the Mech
Quoted: 61 Post(s)
My current drop bar conversion drive chain, with no functionality issues...
https://www.bikeforums.net/attachmen...1&d=1597628362
Crankset: Stronglite Impact 110mm BCD, 46T / 34T. Was toying with the idea of 48T / 36T chain ring combo too.
Old 08-28-20, 04:19 PM
  #6824
bOsscO
bOsscO
bOsscO's Avatar
Quoted: 296 Post(s)
Yes sorry, meant CX style cantilever brakes like what Bob the Mech used.
bOsscO is offline
Likes For bOsscO:
Old 08-28-20, 04:25 PM
  #6825
bOsscO
bOsscO
bOsscO's Avatar
Quoted: 296 Post(s)
Cool thanks for the breakdown on your build. I have a line on a lightly used set of Shimano Tourney 3x7 STI brifters that would work well on my next build.
bOsscO is offline
Likes For bOsscO:
