Building a light drop bar SA 3 sp
#51
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 375 Post(s)
Liked 886 Times
Where the lowest gear is direct drive 1:1 and then each additional gear is higher. The idea is you start 1:1 and tune your cog-chain ring combo accordingly. The old Sturmey hubs like the AW and FW had direct drive in the middle, with lower gears being reduction.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Likes For SirMike1983:
#52
Freewheel Medic
Quoted: 1461 Post(s)
Liked 2,212 Times
SirMike1983 thank you for the explanation. I missed the description tcs had provided earlier. That's the trouble with reviewing C&V on my phone.
Bob
Bob
Likes For pastorbobnlnh:
#53
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 152 Post(s)
Liked 177 Times
Likes For arex:
#54
Senior member
Quoted: 946 Post(s)
Liked 663 Times
Still one of my favorite bikes in the herd. A 1983 curb find Nishiki that I renovated with an SRF 3 speed and bull horns. Super comfortable ride and the gearing is just right if I don't encounter any big hills.
It's the bike I used to take with me in the truck before I retired from the road.
Likes For Dan Burkhart:
#55
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 169 Post(s)
Liked 351 Times
I've got a lead on a Super Course! I'm hoping it works out, this thread has been a big inspiration and rekindled my desire to build a bike in this style. I plan to build a set of 700c wheels with a SA rear hub. Looking for front hub suggestions to match the aesthetic. I'll be using Sun CR-18 rims.
Likes For Rooney:
#56
Old fart
Quoted: 3604 Post(s)
Liked 3,431 Times
#58
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,664 Times
Likes For 52telecaster:
#59
Senior member
Quoted: 946 Post(s)
Liked 663 Times
This stuff is EXACTLY what I want do with my old BSA-thing.
You folks using modern bar-ends, I see S-A is selling one that has the correct pull for old hubs. Anyone have any experience? I was going to use a ratcheting Suntour just to try it but “indexing” would be more betterer.
#60
Senior member
Quoted: 946 Post(s)
Liked 663 Times
Another one I built on a generic no name track frame. Sturmey Archer S3X. Riding fixed gear was a new experience for me, and the 3 speed made it doable, but when I had to cull the herd a few years ago to make space, it was one of the bikes that had to go.
#61
Bikes: old ones
Quoted: 26460 Post(s)
Liked 10,418 Times
They stopped making them, but I guess old stock is still around on the hubs. It works pretty well, as proof of concept. But I ride it more in town and traffic, so I switched it over to flat bars. The SRAM twist grip shifter for these hubs is kind of iffy, but it hasn't worn out enough to experiment with other shifters for the 5 speed hub, which works with a push rod, not a pull chain. It does seem to be a well made hub, though.
Likes For 3alarmer:
#62
Overdoing projects
Quoted: 784 Post(s)
Liked 1,264 Times
Would my Koga-Miyata SilverAce fit in here? Granted the drum brakes, fenders and locks make it heavier than some on here. It is 18.4 kg (40.5 lbs) as pictured. But without the front rack (1kg / 2.2lbs), frame lock (0.75kg / 1.6 lbs), fenders (0.8g / 1.7 lbs) and saddle bag (0.5kg / 1.1 lbs) this would be a 15.3 kg (33.7 lbs) bike. Some lighter tyres or a smaller rear drum would probably shed another 1 kg (2.2 lbs) or so.
But hey, it's a Dutch commuter bike. I need all that stuff.
Likes For JaccoW:
#63
Palmer
Quoted: 1681 Post(s)
Liked 1,840 Times
The bike(s) I posted offended a viewer, so I have removed them.
Likes For tcs:
#64
Senior member
Quoted: 946 Post(s)
Liked 663 Times
...I did a similar thing with this track frame I bought from Nashbar, on an end of year closeout. At the time, it was cheaper and easier to buy an IGH with a coaster brake online, P5 made by SRAM.
#65
Bikes: old ones
Liked 10,418 Times
...the push rod control box is fussy about orientation. After some fiddling and experiment, this worked the best.
I guess I could have pulled off that fall over protector, but I got tired of messing with it, once it worked well.
#66
Quoted: 3817 Post(s)
Liked 6,751 Times
Here’s a recent drop bar IGH built around an S-A four-speed FM hub. Frame is a 1973 Condor Italia:
Likes For nlerner:
#68
Bikes: Teledyne Titan, Bob Jackson Audax Club, Bob Jackson World Tour, AlAn Record Ergal, 3Rensho Katana.
Quoted: 215 Post(s)
Liked 623 Times
So this is in the to be finished pile, 11speed Shimano gear hub, Stratos Keirin track frame cold set to 135mm, with cantilever brakes...
Untitled by nemosengineer, on Flickr
: Mike
: Mike
Booyah Hubba-Hubba!!!
#69
Senior member
Quoted: 946 Post(s)
Liked 663 Times
I could make this thread go on forever with all the IGH conversions I have done for myself and others, so I won't do that, but I will show this one. 1986 Raleigh Bighorn that I put a Sturmey Archer RXRF 5 into.
I ended up giving this one to my daughter in law.
#70
Bikes: 1977 Tom Kellogg Nr. 27 - 1984 Bob Jackson - 1987 Alpineer - 1999 Bianchi - 2002 LeMond Buenos Aries- 2007 Specialized Tarmac Pro - 2017 Mongoose Argus Comp FatBike - 2024 Gravity 29er 1-Speed Monstercross
Quoted: 67 Post(s)
Liked 293 Times
I really like this general concept of a 3-spd IGH drop bar bike. Keep the examples coming. I've started looking for a good donor bike to do my own.
Likes For cegerer:
#71
1991 PBP Anciens
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Quoted: 71 Post(s)
Liked 336 Times
Here's a few from my stable. 1973 Super Course with an FW modified to 3 speed fixed gear. Shifted with an old Simplex friction shifter.
1954-ish Robin Hood with a fixed gear 2 speed Bendix. Slop free hub.
Not exactly a lightweight, Rivendell Bleriot with a Sram 7.
Not a dropbar, but a hoot of a commuter, 1964-sh Dunelt Sports 2 speed fixed AW, aka, The Tetanus Express.
This is a 1970 Robin Hood Lenton Sports I got new in 1970. It has an alloy shell 1950 AM hub with a Cyclo triple cluster.
Early sixties Dunelt Fluer de Lys(sp). AW with 2 cogs, Huret Allvit, Williams crank. And Blumels.
Definitely not a lightweight, 74 Bitsa Sports.
There are a couple more but I don't have decent pics of them.
Likes For bikamper:
#72
Quoted: 1866 Post(s)
Liked 665 Times
I recently bought one of these contemporary 4-speed thumb shifters: https://www.sturmey-archer.com/en/products/detail/sls40
I'm hoping it'll work on an FW/FM hub family, but haven't had a chance to test it out yet.
#73
I converted a StumpJumper Sport bike to use an 8-speed IGH. To keep it as simple as possible, it uses a single chain wheel up front. It is nimble and fast, surprisingly so. I got lucky picking that frame for the project.
I put some drop bars on it but did not care for them, so I took them off. It was kind of surprising how many things had to be changed to go from flat bars to drop bars, and how much it all cost. It was a total waste because I went back to flat (North Roads) bars.
I once put flat bars on my road bike. That sucked, too. The frame geometry was not good for upright riding. Neither was the saddle.
If you do it, chose the frame carefully.
#75
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,057 Times
The only truly lightweight IGH I've built was a Sakai Champion 2 Duo-matic with mudguards & rack. ~ 23 lbs without the Conquest saddle and pedals iirc.
Likes For clubman:
