The Dockless Donor: The 1980 Raleigh Sports will live again
#126
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
As far as I know there are two different sizes for rack mounted reflectors, 50mm and 80mm bolt distance. I've used the thin B+M version on my girlfriend's bike. Here is a post of someone who has it on his Tubus rear rack.And there are tons of light + reflector options from Spanninga, Axa, Contec (though you have to browse their catalog to find it), Herrmans and Simson
#127
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
I am this weekend.
The Spanninga is available in Canada, and the Herrmans on US Amazon, so I should have no problems getting either. The Herrmans is also $10 cheaper.
-Kurt
#128
Quoted: 3464 Post(s)
Liked 2,831 Times
It seems to me that blinky lights are easier to notice than steady lights. Perhaps they are harder to track and gauge where they are, but I can't see how the difference is much. In any case, you get the best of both worlds if you use both types of lights at once. I often run a blinky taillight and a steady taillight.
I agree that a blinky headlight is silly at night. Well, some use them, but I have no interest. It seems useful in the day. The Cygolite headlights have a "steady flash" mode that gives a burst of high intensity while otherwise staying steady at medium intensity. I find I can ride with this, though it is a bit distracting to me.
I'm glad the German laws led to the development of excellent lights, but I think the laws are too restrictive, and I'm glad we don't have similar laws here in US.
bright, other flashing and aimed higher. Endurable. I use planet bike taillights - at the time they appeared to me to have a variable pattern instead of just a blinking. That catches my eye when I am driving best, so I went that way. I will note that when using those passing vehicles give a wider birth, a good thing.
i use one now during the day even.
my wife mentions that she would rather not collect on the life insurance.
Likes For repechage:
#129
Liked 4,396 Times
For the millionth time, I'm updating this thread with information that is not pertinent to the 1980 Sports (apparently, square taper Heron cranksets off Raleigh Choppers or Raleigh PUBs aren't easy to get used) - instead, this has to do with the original, first-generation Sturmey X-RF8 which seemed to be unfixable.
Well, it's fixed.
Absolutely nothing was wrong with it, except lubrication. Filling a Sturmey hub with ATF - which seems to work for the later X-RF8(w) and later Sturmey hubs - does not provide enough lubrication.
The cams that actuate the pawls have a fair bit of friction, as do the pawls against the axles. It's super easy for them to jam when the gears are shifted, engaging the wrong pawls when shifting though the cluster.
These are the bits that fit onto the shaft as shown in Fig. 10:
The simple solution was to liberally grease the axle, cams, and pawls with "00" grease - namely, the generic equivalent of what Sturmey-Archer specifies for the internal parts of these hubs in the first place.
This is a semi-runny grease that sticks well to parts when you apply it. Turns those friction-prone machined surfaces into super-slick contact patches.
This might seem obvious to the point of stupidity - namely, "grease the hub with what Sturmey recommends in the first place," but I can tell that when I opened this X-RF8, it had barely enough grease to be passable, and it didn't have the consistency of the 00 grease that I purchased. This is why the hub was malfunctioning in the first place and why the ATF didn't cure it either.
Now, taking in mind what some have suggested earlier - in operation, you can definitely tell this hub is really not meant for use on anything larger than a 20” wheel. The crank rotation before engagement w/the X-RF8 on a 26" wheel (and 28t front chainring) is terrible. However, I presume the effect is quite the opposite if you pair the same hub with a small wheel and a large chainring, as is usually found on the small-wheel bikes these were intended for.
Here it the hub on its current testbed - one of the unfinished Bike Share Museum bikes (which is named "Proprietary Parts" - the irony should be obvious). The Gazelle was sold a long while back when I realized it didn't fit as well as my Spin Gen 2, and would otherwise duplicate it.
-Kurt
Well, it's fixed.
-Kurt
Likes For cudak888:
#130
Quoted: 57 Post(s)
Liked 41 Times
Well, I went ahead and did it - donor bike and uber-cool parts have been acquired. Had I remembered all the bits that I removed from the Romani, I would have never batted an eye at the price.
First off, the not-relevant-to-this-build-but-I-got-it-in-the-bargain-so-here-they-are bits. I forgot that the crank is an early Dura-Ace FC-7110 unit, not 600 Arabesque. I'm not objecting one bit! The brakes are 6200-series 600EX/Arabesque though. Meh, at least for my tastes, but there are tons of other goodies (and the obligatory NR RD) in here to keep me happy.
Now, the fairly interesting donor bike - a 26" Gazelle Whale. This is not an ideal name for a bike I've ever heard, but for a Dutch market well versed in the practical benefits of a bicycle, I wouldn't be surprised if the weight corollary is largely ignored.
Frankly, I must admit that I'm a bit smitten with the little thing. It looks halfway to a dockless bike, and my return to bike collecting is heavily influenced by IGH hubs, so it ticks two of the boxes that get my heart rate up (in a good way).
It also has a fair amount of practical little touches on it that make me smile. The headset is capped with a hammerhead-shaped cable keeper (and the bottom of the frame has a nice bespoke cable guide), there's a disc-shaped cap that seals off the bottom bracket, the stem is nice and short, and there are bosses for a rear wheel lock under the chainstays:
Finally, a V-brake cable run that keeps the noodle away from one's shins:
This is also a genuine Dutch-market Gazelle sold from a shop in Leidschendam:
And the one thing that really surprised me: Woods valve tubes. You don't see these here in the States everyday, despite being a pretty sensible design.
Anyway, I think I'm losing the point, which is - of course - the Nexus Inter-L (HB-NX22) hub that this bike is donating to the '80 Sports:
I'm going to size up the Raleigh for it's spokes tonight and begin the swap soon. I do want to tune up the Gazelle just to find out how it rides though.
-Kurt
-Kurt
Likes For Kent T:
#131
Liked 4,396 Times
#132
Quoted: 7353 Post(s)
Liked 2,481 Times
I like the crank, and I'm sure you're right about a Hollotech in a Sports.
#133
Liked 4,396 Times
Unfortunately, Goof Off wasn't taking those tacky Motsuv letters off. I'll approach it with different tactics at another time.
Also, excuse the photos - they're not the best framed of the lot. Half of them were ruined by what appears to be an autofocus issue with my el-cheapo Panasonic 14-42 lens.
-Kurt
Likes For cudak888:
#134
Freewheel Medic
Quoted: 1455 Post(s)
Liked 2,197 Times
Kurt, I vote to keep the lightning bolt in running down the center of each arm. It will make the Sports 25% faster.
Looks great actually. Is that one of the China made cranksets?
Bob
Bob
Likes For pastorbobnlnh:
#135
Liked 4,396 Times
I found it on AliExpress. My guess is that it's Chinese-made for the Russian market, given the name slapped on it. It's a pretty nice piece too, and the chainring is all beef.
-Kurt
#136
Regarding the rear rack-mounted battery-powered light:
I bought a cheapo light (looks like they still offer it some 7 years later for ~$7!) to replace a broken one on a used Finnish city bike I bought in Sweden. I had just figured that the spacing was standard.
When the mounting hardware didn't line up with the holes in the rack, I looked more closely at the lamp. The plastic body was moulded in such a way that the mounts could be moved to the other standard of spacing once I gently punched out the perforated plastic. Came in handy when I replaced the broken rack with one that had the other standard...
It's possible that some can be easily modified for either standard.
#137
Liked 4,396 Times
I'll post a photo when I take a rear-angle shot of the bike.
-Kurt
#139
Liked 4,396 Times
I love putting a nice set of cranks on an old Raleigh!
This is a Raleigh Sprite, not a Sports, but, campy record crank with the little ring removed, I did have to make some aluminum block spacers to get the chain guard to fit, but I love the look of the 53 tooth ring under the chain guard!
I went for the stock 46T ring size just to ensure no issues. I probably could have stepped it up to the 1950's standard and used a 48T, but given that it took a month for this crank to arrive, I figured I wouldn't press my luck. I do want to put a silver guard from a 1975/76 Sports on this thing though. The later one that's currently on the bike looks downright awful.
I just noticed - that's some significant Schwalbe meats under it. Has that thing been 650B'ed?
-Kurt
#140
Quoted: 457 Post(s)
Liked 462 Times
46T ring under a Raleigh chain guard will always look great to me!
Likes For jackbombay:
#141
Liked 4,396 Times
Here is a pic of one of the spacers, a solid block of aluminum with 2 holes drilled and tapped to 5x1, the chain guard got lifted far enough that the holes were not near each other, I also did some "fine tuning" of the chain guard placement by bending the tabs on the frame and the guard slightly.
Yep, 650b, As long as I was buying rims and spokes I figured I'd try to "future proof" it, and I got a big order of parts at wholesale prices through a buddy for this project and another one... Those are 41c tires, and they are a very snug fit, and that is with some tweaking of the fenders, I had it set up like that for some gravel touring, that didn't come together this year due to Covid, so I pulled the gravel tires and went to a 38c asphalt tire and am notably happier with it for its every day townie use. The rims are Pacenti Brevet rims, and the current tires are Vee tire co Speedsters, https://www.modernbike.com/product-2...hoCcowQAvD_BwE
The ridiculous price of 650B's have kept them off all but one machine that I'm building at the moment - that and the lack of affordable used rims out there. I went the VO route only because I was lucky enough to get the 32/32's cheap. I don't think I could justify them for a Sports. Half of the motivation for this project were those aluminum EA3's too. I don't think I would have considered this project otherwise.
-Kurt
#142
Quoted: 4513 Post(s)
Liked 6,392 Times
We'll see what will take it off without damaging it. No lightning bolts for me though - too bad I can't silkscreen a Sir Walter onto them
-Kurt
-Kurt
Sharpie coverup could show what it will look like if you take it off, maybe leave some of the lightening bolt to look like an "S" for Sports, 1x single ring or Sturmey.
Likes For merziac:
#143
Quoted: 457 Post(s)
Liked 462 Times
The back of the rear fender took the most tinkering, and I have about a 1/4" on either side of the tire at the chain stays, but the fork was pretty tight too.
Aluminum rims on a 3 speed really make them so nice, the expense only hurts once, the light wheel set provides smiles forever!
#144
Liked 4,396 Times
Yea, 650b rim brake rims are uncommon for sure, even getting wholesale pricing on most of the bits for my Sprite, it still ended up fairly expensive, but it has an S5 hub and I ride it almost every day, so I'm happy with the cost.
I have pushed the limits of the lightweight experience though, as the bars formerly from this are on one of my '75 Professionals at the moment. Talk about a sporty Sports - this combination deserves a LOT more recognition for being super comfortable, yet very zippy.
The geometry might not be perfectly dialed in for upright bars, but the fact was that I was making e-bike pace on this thing on its first test ride. I wasn't even trying to do that.
Still looking for that front Record caliper...
-Kurt
#145
Quoted: 457 Post(s)
Liked 462 Times
I love it! Thats one high performance townie!
#146
Liked 4,396 Times
It'd be better if it was a '74 with eyelets. Can't do jack with a bike that doesn't have a rack, doesn't have fenders for the wet, and doesn't have an IGH. The Nuovo Record rear mech is particularly a useless PITA for the constant stop-and-go of commuting. But it looks good
I wouldn't mind throwing full Dura-Ace 7200 on it. Black-knuckle RD and brakes too. Haven't seen a '75 Pro built up like that.
-Kurt
-Kurt
#147
Liked 4,396 Times
Oldschool carb clean, Berrymans, Gumout, foamy, soapy type, not the kind that evaporates will take it off, maybe judiciously enough not to hurt whats underneath. I always start out with less than I think will do it and increase with need, I can usually get stubborn paint transfer off of cars without compromising the good paint underneath, if I'm careful then it shines right back up with Meguiars fine cut cleaner/wax.
This stuff is tough. Also appears to have a 3D effect on it; it's not solid silver. Closeups later.
-Kurt
#148
Liked 6,392 Times
FWIW, when I have something really stubborn, I use Motorcraft PM-2 carb cleaner which I usually keep on hand, it seems to work even better than the others. You have to get it at the dealer so its not cheap and some states don't have it cause its too nasty.
If its that tough you might want to let it sit with a puddle and keep adding until it softens up.
Not sure what you mean by liquid, its all liquid whether spray or in a can, it takes the non evaporative type for the tough to get off.stuff.
I took the "RECORD" off a modern version Campy HS, the imprint was thin and still took a lot cleaner, elbow grease and work to get it off.
#149
Liked 4,396 Times
Huh, ok , well I have used the good stuff and never failed to get anything off. It may be some kind of powder coat or embossing so a different animal.
I don't know what type of application these are; first time I've come across anything this tough. The drive side arm transfer is only silver, but the non-drive-side has that 3D shadow bevel effect in it:
I figure anything this tough would come off with the paint, so I might leave them as-is - or strip them entirely and have them repainted in the same black finish using the remainder of 2-pack paint left over from the Twenty.
-Kurt
