Toe Clips - Why?
What, me hurry?
Bikes: Rivendell Atlantis, 1987 Peugeot Iseran mixte
Toe clips come in sizes, you know. If you get the correct size, your foot will be positioned correctly over the pedal.
Two H's!!! TWO!!!!!
Clipless are great, but they have one big drawback: they require special shoes. I want to commute in my normal shoes. Hence the clips and straps: not as efficient as clipless, but far better than bare platforms, because you can pull up on them some, and you don't have to worry about your foot slipping off. And oh, I certainly leave them loose enough so that I can just get the foot in and out freely.
I used clips and straps for decades. My wife would never consider using them. When I went clipless, I finally convinced her to at least try clips and straps. By the end of the first mile she was sold. She was amazed how much more stable and powerful she felt. She was really paranoid about getting her foot stuck and falling but got over that quickly. She ultimately went clipless on her main road bike but kept clips and straps on the other two.
To answer the OP's question, regardless of whether you use pedals with toe clips or you use clipless pedals, the advantage of having something to hold your foot is mainly that your foot stays there without you having to think about it.
It may not be obvious, but when riding with open pedals, a small part of your energy goes to keeping your foot on the pedal. When you have toe clips or clipless, it doesn't. Your foot automatically stays in the right place.
It's not a big deal on leisure rides, but most serious cyclists would want to ride with toe clips or clipless pedals... one or the other. To start out, you could just buy some cheap plastic toe clips and straps to add on to your existing pedals. This way, you can just use your existing shoes, or any shoe you have. Leave the straps loose, or remove them completely. You could also buy half toe clips instead of the full ones. They don't use straps at all, and you still get most of the benefits. If you think you like that, then later on, you can consider buying toes clips and proper cycling shoes to go with them.
on your left.
Bikes: Scott SUB 30, Backtrax MTB
I use clips and straps on both of my bikes, I wouldn't go back to platforms. You feel way more connected and secure on the bike, and the efficiency gained is pretty substantial. I might go clipless eventually, but I waiting till I find a good deal.
Also, my straps are as tight as i can get them, and I can still get out of them really quickly, and if I fall I get out of them fairly quickly. The only annoying thing is flipping the clip over to get my foot in on my fixed gear, since the cranks always turn if i don't get in really quickly i'm screwed.
ok. less bike forums. i'm out for a ride!
Quoted: 7351 Post(s)
Liked 2,479 Times
Toe clips are actually harder to use than clipless! But I learned to use toe clips when I was 14, so I'm good at getting in them. I'm 48 now, so that's 34 years. I remember the day my friend and I put them on our bikes. We took a long-ish ride and said we'd never go without them.
I'm trying PowerGrips now, and I think they're excellent. I like riding in any shoes I happen to have on. They're a little harder to get into, but they're more comfortable, and they won't scuff shoes.
I put toe clips on my wife's bike. She's a scared cyclist, and she did fine with them. I'll get her some SPD's because I think she'll like them better. She said she's willing to try.
Quoted: 8 Post(s)
Quoted: 800 Post(s)
Liked 218 Times
Like most of the previous posters, I prefer clipless, but was reluctant for years and used toeclips. On my beater winter mountain bike though I have strapless toe clips; just the cage without straps. I don't know who makes them but they are easy to get out of yet provide the added power of regular toeclips and I like them for really hazardous slippery conditions (I also have studded tires). If interested send me a PM and I will get more info from my bike shop.
Bikes: Miyata 600, Marin Larkspur, Marin Muirwoods, GT tequesta, Fuji Ace
I commuted for two years in Calgary with clips. While I didn't use special footwear (alternated between winter boots and hybrid bike shoes [no groove]) I was happy with them.
On one occasion I was cut off by a motorist (right hook), and had to come to a quick stop to avoid a collision. To my surprise, I found I had ripped the toeclip off (broke the plastic part off), and put my foot down to avoid a fall.
I'm not sure I could replicate the event, but the panic stop did not result in a crash or injury, so I was happy.
bulletproof tiger
Bikes: Waterford 2200, Litespeed Tuscany, Salsa La Cruz, Kona Fire Mountain
I put SPDs on my commuter and my road bike so I can wear the same shoes (SIDI Dominator 5) all the time. I leave shoes at work so I don't have to worry about taking a pair with. (And in fact those shoes have my custom orthodics in them, so I need to get another pair of those to keep at home.)
I've got myriad issues with my feet, including plantar fascitis so bad I can barely touch my feet to the floor in the mornings. Clipless shoes that fit perfectly and are stiff enough to do all the work for me are absolutely saving my poor feet on the bike.
For things that help my aching feet (and similarly for things that help my aging back), I couldn't care less how much it costs. For those who do care, I put Shimano M520 SPD pedals on two bikes ($50 ea.) and bought one pair of SIDIs ($200). If your feet aren't as persnickity as mine, you can probably find much cheaper shoes that work just as well for you. I've tried low-end Shimano road and MTB shoes and they're both great and great value; they just don't quite fit me.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
It doesn't make any sense to me that clipless would stop your feet hurting. All they do is to hold your foot in the right position. If you have properly sized toe clips, or platforms and you keep the same part of your foot over the pedal as clipless would, I don't see how there's a difference.
It does make sense that stiff shoes would help, but I don't see how putting a cleat on the bottom of the shoes and locking them into the pedals makes it significantly different than just putting the shoe over the pedal in the same place.
I do like to use cycling shoes rather than sneakers, that does make a difference. But I'm pretty happy being back with toe clips instead of SPD (I'm still riding with the shoes with SPD cleats on them, but I swapped out the pedals for the old platforms + toe clips and it feels exactly the same to me).
Work: the 8 hours that separates bike rides.
I use toe clips -- I'm cheap and painfully absentminded.
I don't even have straps - that way I can get out *really* easily - but I really can get good pull going up (in whatever shoes I'm wearing, tho' some are better than others), and they keep my feet on the pedals. My most recent splat was last April when I was wearing my shoes like sandals with the heel mashed down (they're designed to do that), I was between toe clips, and my gears were out of adjustment. The gear jumped, my foot slid forward, the shoe hit the wheel, the wheel Ssssuuccked the shoe right off my foot, the shoe sucked the fender off the wheel and wedged between tangled fender, fork and wheel, which of course brought the bike to a sudden stop and me to an almost as sudden stop over the handlebars. I stood there in my sock and shoe for a while, trying to figure out how to untangle the mess...
I put the clips on that night and have tried to haev my camera with me more often ever since.
You gonna eat that?
I use toe clips without straps. Easy in, easy out. Maybe not power transfer for the entire cycle, but for a pretty good chunk of it. Years ago I used toe clips and straps; never got used to the straps and got rid of them. Been riding with toe clips & no straps ever since.
I don't like the idea of paying more for my pedals & shoes than I've paid for the whole bike (my most expensive current daily rider cost me $100). I don't want to have to worry about special shoes at all. I don't want to have to consciously think about unclipping when I come up to a traffic light, and I don't want to fall over because I got a little careless.
To me, clipless is what serious competitors use. I'm a commuter and recreational rider and just can't picture myself getting clipless.
Nobody should feel like they are missing out on anything if they only use toe clips instead of clipless pedals. They serve the same purpose: holding your foot in place. As I've said before (but nobody read), either is probably a little more efficient than just a bare pedal, but it depends on the kind of riding you do. Not everybody is interested in maxing out their performance on a bike.
Quoted: 539 Post(s)
Liked 44 Times
There's no doubt in my mind that the bike shoe systems are more expensive, require a lot more fiddling around to get things set up right (like the position of the cleat on the bottom of the shoe), and it would be really nice not to have to change shoes just to go biking. But saying the serious competitors use them so I wouldn't seems just as silly as saying that because serious competitors use wheels that have to be trued every ride I also have to use those same wheels.
Just like you, I just keep using what works for me, and the fact that it's easier, quicker, and more natural in an emergency to unclip with bike shoes and pedals than toe cages keeps me using the "clipless" bike shoes and pedals.
I think any method of keeping your foot more securely on the pedal in the right place is highly valuable. Whether you go with clips and straps or clipless (I have bikes set up both ways) depends on what works for the individual in their situation.
Green lights for all
Location: Ohio, Germany, Florida, West Virginia, and then Georgia now
Bikes: Fuji Team SL 20 spd, Nishiki, Mercian 12 spd. Alan 10 spd, Frejus, Bauer, Motobecane, Schwinn, JC Higgins 3 spd, Columbia coaster brake, Magna BMX
Quoted: 5 Post(s)
Power Grips do not fit in every type of pedal, but they are Ok for people who cannot figure out how to reach down with their thumb and completly loosen a simbple quick release buckle on toe straps. People using clipless stop at a red light and fall over too. When clipless (meaning no strap and toe cage) first came out the hype was about allowing the foot to pivot on the pedal... called "float" which was to help allevaite knee injuries. The proper shoes made for toe straps have a stiff metal shank in the sole and a device on the bottom with a grove that attached to the back of the pedal as described elsewhere above. Yes I have forgotten to release the buckle when stopping and fell over... once, but then I learned quickly to loosen them before I plan to stop. The only problem is these pedals must have been designed by Italians as the designs are made for people with narrow feet.
Quoted: 539 Post(s)
Liked 44 Times
Bikes: "Hildy", a Novara Randonee touring bike; a 16-speed Bike Friday Tikit; and a Specialized Stumpjumper frame-based built-up MTB, now serving as the kid-carrier, grocery-getter.
Quoted: 11 Post(s)
I've never seen anybody do this, or even heard of it until now. I slide my foot in and out of the toe cage as needed. The only time I unbuckle it is if I need to adjust the strap.
Tour Journals, Blog, ride pix
My bands:
My bands:
- Uke On! - ukulele duo - Videos
- Ukulele Abyss - ukulele cover videos - Videos
- Baroque and Hungry's (Celtic fusion) full-length studio album Mended.
- Artistic Differences - 8-track EP Dreams of Bile and Blood.
I was accelerating from a red light towards a 135 degree right turn with my left foot unclipped (so there's no toe overlap), and found that the unclipped foot kept rising off the pedal; its something you don't notice until you witness the side effects.
What, me hurry?
When I bought my first bike that had toe clips back in the day, the people at my LBS showed me how to use the clips, and they told me to leave the straps loose. Even loose, they're still enough to keep your foot from sliding sideways off the pedal.
Liked 2,479 Times
Before clipless pedals came in, we used cleated shoes with our clips and straps. Cleats made life nicer if you were going on a long weekend pleasure ride or if you were doing long distance touring. They were not just for pure image as Boston Commuter implies. You could tighten the strap after putting your feet in, if you wanted a positive connection. Or you could leave it as it was and get near perfection. I generally compromised and tightened my left strap and left the right one loose, as that's the foot I take out first.
Being somewhat cautious, I didn't use cleats with a fixed gear back then. I used toe clips and straps with sneakers. It's a bit tricky getting into them but not terribly so. I am going to try riding with clipless (cleats) on my new fixed gear, as they're pretty easy to get into and out of.
Bikes: Hardtail MTB on city tires
bragi
Bikes: LHT
I find pedals with toe clips to be a total pain in the a$$. Clip-in pedals (SPD) are way easier to use, and much more efficient. But even clip-in pedals are a bit overrated, IMO. Unless you're doing hard-core MTBing or road racing, platform pedals are probably the most convenient option; the performance advantage of clipless, much less toe clips, isn't enough to make up for the hassle...
