Best electric tape for securing bar tape?
This looks similar to a tape i had used in the AF years ago when making cables housing many conductors. it was a bit thicker in the middle and had a green witness line that if just covered by the edge when wrapping was considered wrapped correctly. it needed a bit of a stretch to "bond" properly. neat stuff. do you only use that at the end? or for the entire bar?
looked more closely, just the ends. i switching to this.
You learn something new every day.
I have never seen it but will look out for it.
I do find even ordinary electrical tape will hold/adhere better when stretched.
I always presumed it was the elasticity/stored energy in the tape that helped it work.
You learn something new every day.😀
Quoted: 551 Post(s)
Liked 278 Times
No more electrical tape used here... I use this nifty silicone self fusing tape from Amazon. Holds tightly and never has any gooey reside:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Yes. Just be careful with it... once it sticks to itself, it’s not coming unstuck! Works great and no adhesive at all. I also used it to wrap the chainstay on my prior gravel bike. It held up very well.
Quoted: 1324 Post(s)
Liked 927 Times
I wrap my bar tape towards the stem. Then when I get to the reinforcing sleeve on the handlebar I carefully cut the bar wrap at an angle so that it fits to the reinforcing sleeve handlebar joint. I secure my tape with gel cyanoacrylic glue so that there's no need for other tape at all.
Cheers
Cheers
Super Modest
Quoted: 10979 Post(s)
Liked 4,644 Times
Keep the chain tight!
Sunshine
Quoted: 11010 Post(s)
Liked 7,540 Times
Yup- a mix of whats been mentioned a lot here is what I have found works best for me.
A few wraps of electrical tape where the first half is pulled tight and then the last full wrap is not tensioned.
Then a few wraps of self fusing tape where the first half is pulled tight(that stuff stretches) and then the last full wrap is not tensioned.
Both the electrical tape and silicone tape wrap to the edge of the bar tape and not over it. All 3 tapes end at the same point and along the same line.
Gives a clean and square look and bar tape never moves.
Sunshine
Liked 7,540 Times
So like many people I secure my handlebar tape with black electrical tape. However, the most recent tape I bought doesn't stick very well and comes undone. And those pieces of tape they give you with the bar tape don't work very well and aren't very flexible. What specific brand of black electric tape has worked the best for you?
A real easy way to secure the end of the electrical tape is to glue the end with Super Glue. It won't come loose after that.
Likes For jmess:
Quoted: 880 Post(s)
Liked 2,303 Times
I don't use tape anymore. I start at the top of the bar and end at the plug end . This works better for me and stays tight . I use sticky back cotton tape that tucks in nicely with the plug at the end of the bar.
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
Add one vote to 'finish with twine as per Rivendell video'. It takes about two minutes and looks much better.
Although when I used to use Dollar Store elec. tape I never had a problem that I can recall... but maybe that is a problem with my recollection.
I could never get electrical tape to stay in place, always ended up making a goopy mess eventually. Heck, even when used on wiring it tends to end up a mess. I have gone to wrapping my bars from the top down and tucking the end of the tape into the end of the bar, secured with the bar end plug. Looks cleaner now and no chance of mess.
Quoted: 4825 Post(s)
Liked 3,948 Times
With another 6" of twine and barely more work, this could be a proper sailor's whip. Done right, it will last near forever. You can find the instructions in any old how-to-sail or marine knots book. I learned the whip when I was 10 and use it all the time. I don't use it here because 1) it never occurred to me, 2) I use waxed polyester twine which is much thinner and would take many more wraps than I have patience for and 3) I want black there like my bar tape. (And a permanent whip on very temporary bar tape seems kinda pointless, Got better things to do.) I do use quick and dirty whips all the time simply because they are so easy to do and are so useful.
Trick- buy very strong twine. Waxed helps. Tie bowline knots in each end. When finished, slip screwdrivers (or whatever; marlinespike was the traditional tool) into the bowlines and use as handles to pull the whip tight. As you pull tight, you can see the crossing of the lines you are pulling under the wraps. Make sure the crossing stays near the center as you pull tight. Done right, a rope ending in such a whip was expected to stay properly whipped through a hurricane in open ocean. (Failure and the rope unraveling could be one of those little things that add up to a very bad ending. Think - cell phones were still 200 years away. No radio. No search planes. Keeping things shipshape was life and death.) The whip on handlebar tape? Like on the Riviera for that knot!
Ben
Ben
Liked 3,948 Times
Done this way, when you ride, you will rarely be touching the tape ends. When you do, it will be when you are riding the tops of the handlebars, Your hands will be tending to pull the tape back in the direction of the wrap and if your fingers do come around enough to touch the tape end, you will be pulling it forward with your natural motion, trying to tighten it, not unwrap it or peel it off.
Ben
Quality electrical tape will have the UL logo (Underwriter Laboratories) in the inside of the cardboard roll it's wrapped around. If not, quality is suspect. Cheap electrical tape probably doesn't have this logo.
Quoted: 1188 Post(s)
Liked 1,154 Times
There is one brand of electrical tape that stands out above the rest:, Nitto tape from Japan. Works in the jungle and works in Antarctica (used it in both places, so a super wide temperature tolerance) and won't come undone 600m under water. Perfect blend of stretch and strength.. But self amalgamating tape is better for bars anyway.
Likes For 2cam16:
Quoted: 1814 Post(s)
Liked 923 Times
Handy for a number of things- valve stem rattle, fraying fabric, light water-sealing. I've used it on water bottle cages to increase grip on the bottle.
No tensile strength, 'tho, so wouldn't keep bar tape from unwrapping very well.
Clark W. Griswold
Quoted: 4407 Post(s)
Liked 4,049 Times
I am happy with the 3M tape, that is generally what I have on hand or at the shop and it works just fine and dandy. Sometimes I even use electrical tape to put the bar tape down and put the strips that come with the bar tape on top of that but not often.
Liked 3,948 Times
Ben
