Today I (v2):
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Today I said "Bye Felicia" to winter and installed the Naches Passes on the fixed-gear:
42mm of cushy goodness!
@SquidPuppet
@SquidPuppet
Calamari Marionette Ph.D
Liked 2,568 Times
First off, it always makes me happy to see tan sidewalls on my bike again. Secondly, cushy tires mess with my head every time! The Nokian Mount & Grounds that I spent about 650 miles on this year are the complete opposite of supple, and add a ton of "buzz" due to the studs. So the NPs felt a little draggy at first, with the instinctual look down to make sure they hadn't gone flat. The fact that I switched from winter gearing (59") to summer gearing (71") at the same time is probably part of it. But as I did my 27-mile ride yesterday, I gradually stopped noticing them, and had no trouble keeping up with anyone in the group.
I did notice that my NDS crank was glancing off the chainstay, which was odd. This set of Sugino GLPs on a 104mm bottom bracket has always had minimal clearance, but I'm not sure what changed. Maybe I knocked the bike over to the left side some time ago, and didn't notice until I had smooth tires? A few swipes with a flat file, and I've bought myself a little more time until I have to figure out a solution that won't throw off my chainline...
Liked 2,568 Times
This weekend I completed the 2018 PA Fleche on the "Sinister Nuts" team. It was 5 guys on fixed gear bikes. Four of us are around 60 and the kid was 47.
https://ridewithgps.com/trips/22366990
Great time riding through the night.
Ride Safe,
Joe
Ride Safe,
Joe
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Jobst Brandt said, "The Alenax is a great example of an outsider inventing a solution to a perceived problem, creating something that is useless for the intended user. Much money was thrown into the design and manufacture of the Alenax, and several years of bicycle-show attendance with many models. As soon as you ride it, you'll realize why it doesn't work."
So, how did it work for you? What was your impression?
And where was this thing that you got to ride it?
Liked 2,568 Times
Yes, and yes! The first time I put a leg over it, I chickened out and had to think about it a little more, because I was sure I'd crash before I figured out the motion. Once I got a few more treadle-strokes in, it started to make sense and I took longer and longer excursions up and down the block.
Shifting is interesting -- there are four speeds, and you use a friction shifter to adjust where the ends of the chain catch on the levers. If the shift cables aren't perfectly adjusted, it's easy to end up in a situation where one treadle is one gear higher than the other.
Although he didn't say it outright, I wonder if some of Jobst's vehement opposition was due to concern that riding one of these things would get in the way of learning how to ride a regular bike if the person was new to it, or if spending time on the Alenax would "de-train" someone from regular bike muscle memory, at their peril.
I thought it was fun by the end -- I want my brother to bring it on club rides to mess with people.
Liked 2,568 Times
It's a weird feeling. This bike was "almost" perfectly adjusted, but each shift was a "clunk-clunk" where the resistance was temporarily different for each leg. Supposedly, the fact that the two treadles could be set to different resistances was billed as a feature for folks with physical impairments. [citation needed]
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
Today I figured out the creaking noise while pedaling my fixed gear. Turns out it was slightly loose pedals, not the crank. It is usually something other than the crank. Had the bb tool, crank puller, and torque wrench all ready to go.. Fixed in 2 seconds with an Allen wrench
- Soli Deo Gloria -
Liked 736 Times
Today I hit 2000 miles and about 87,000 feet climbing for the year.
Quoted: 1332 Post(s)
Liked 398 Times
Nice. I'm almost to 1000 miles and just over 54k feet of climbing so far. I intended on being a lot further along but life had other plans.
Bikes: 2015 Aventon Diamond
Quoted: 151 Post(s)
Nicely done Tim! I am just over 1100 for the year, but only 21,000 ft of elevation Thanks Florida
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times
I'm happy because I eliminated the BB creak on my Steamroller.
Quoted: 151 Post(s)
Quiet riding is so much nicer! My stem creak is gone as well and it is a lot better riding.
Quoted: 481 Post(s)
Liked 131 Times
Quoted: 481 Post(s)
Liked 131 Times
Swapped out the Phil BB I had originally used on my last Steamroller for a generic one. I never had problems with it in my previous 'roller but every since I took it out of that frame I've haven't been able to get it to run quiet. My previous Steamroller had a different Phil BB in it when it was stolen and that one had no issues. The one I took out yesterday made noise in both of my new bikes I've tried it in. The crank tapers showed some slight gouging from the end of the spindle but it's working well now. Not sure what was going on.
Silver Comet Trail Georgia - Welcome
