Show Us Your Techniums! (Technium? Technia?)
#201
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1298 Post(s)
Liked 940 Times
Threadless is what I did with my '89. Are you going with an aluminum fork (I recommend it)? Custom paint job is always cool. I'm about to have mine re-painted (same bold yellow) at Yellow Jersey. Please do not put heinous brifters on it. What are you thinking for paint scheme?
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
#202
Standard Member
Liked 940 Times
I have two Raleighs that are Technium in name only, and one is likely a Raleigh in name only. One is an SBDU road frame in 753 with a bonded aluminum fork. I believe this was shipped in primer to the US and painted and decaled here. It says TECHNIUM on the top tube but is a lugged, brazed frame. The other looks almost exactly like it, and also has TECHNIUM on the top tube with a 753 designation as part of the graphic, but it is a track bike made with mostly aero tubing.
What I know about both of these bikes, which I bought at different times from different people is exactly ... nothing. I expect that both are from the mid-1980s, and the serial number of the road model indicates it was built in Nottingham, after the Ilkeston shop was closed down. The track bike has no serial number. The cynic in me says that the only 753 in the track frame might be the top tube and perhaps the chainstays, as they are the only non-aero tubes besides the headtube, which has a significant fairing added. I've seen dimpled 753 stays, but not as deep a groove as these, and my road frame has oval stays. There were supposedly two small batches of 753 aero tubes produced over the years and the crossection of this bike's tubes does not match at least one of them. It is my understanding that 753 cannot be cold worked, so the other tubes would have to have been factory produced, or of some other steel. Also, 753 is supposed to be silver-brazed, but this frame has all kinds of brass fillets. The components were mostly first-generation Dura Ace track, but this group lasted much longer than its road counterpart, well into the 1980s. The rear wheel had a rim to match the front but a Suntour Superbe track hub, which I've since swapped out for an inferior, but matching Dura Ace track hub (not easy to find in 28-hole!) Spokes are aero Wheelsmith 15 ga. The fork is a standard road model, possibly 753, with the crown heavily relieved, apparently for aerodynamics and weight reduction. It has a very short rake. My thinking is that a road fork was selected for expediency and possibly because it would have been considered more aerodynamic than a track fork with round blades. It also had a cut-down LaPrade seatpost, likely because the post needs to be within a cm, due to the lack of adjustment available. I was lucky and found a round Dura Ace seatpost that was the correct length for me. When I got it, it had a 130 mm Nitto stem and round handlebars.
The bike shows very little wear. Unencumbered by any facts, I think it likely that it was built by an American framebuilder for some special event, perhaps a record attempt or championship race. How much of it is actually 753, if any, or who built it, I may never know. It's possible that Mike Melton wielded the torch, but this is all conjecture. The graphics are almost identical to those of my road model, with the exception of the colors, with green substituted for blue. There is no head badge or decal. It rides beautifully, with predictably quick steering.
Likes For 1989Pre:
#203
Bikes: 82 Univega Specialissima, Bike Friday Pocket Rocket, Kona Wheelhouse, Rocky Mtn Thunderbolt, Viner Strada Bianca, ~73 Bob Jackson, ~75 Volkscycle Mark100.
Quoted: 70 Post(s)
Liked 183 Times
I have always wanted a technium bike. As an engineer, I love the willingness to try an out of the box solution that Raleigh USA did. I think an early version is what I seek.
Does anyone know when they switched from 27" tires to 700c ? I know 1986 was 27", what about 1987 or 1988?
I would prefer a 27" , model so i can get a wider 700c tire in there.... ( i have done this before, as 3mm wider tire almost gets geometry back to norm....). Let the naysayers shout out!
Likes For OldCoot:
#204
Standard Member
Liked 940 Times
Likes For 1989Pre:
#205
Bikes: 1993 Diamond Back Sorrento, 1965 Schwinn Racer 3-speed, 1987 Schwinn High Sierra, 1990 Specialized Sirrus, 2020 Specialized Sirrus 3.0, 2013 Giant Seek 1
Quoted: 87 Post(s)
Liked 776 Times
Likes For zookster:
#206
Quoted: 70 Post(s)
Liked 183 Times
I recently acquired a Technium Tri-Lite. 700cx25 tires, Rigida rims, no eyelets on forks or dropouts, but the internal routing is on the right side of the top tube. 87 or 88? I have not been able to find out. The serial number has thick paint over it, hard to make out what it is.
Likes For OldCoot:
#207
Standard Member
Liked 940 Times
#208
Quoted: 87 Post(s)
Liked 776 Times
I had thought that there was a hard-and-fast rule regarding the cable routing entrances and exits, but I just found an example (the black '89 in photo) that has the same routing scheme as yours. Curiously, I own the same frame, but with both cable housing exit and entrance on the left side! The "in the right side and out the left" of the toptube scheme was used from the very beginning, in '86, but may have been used a bit longer than I had assumed. Is there a number on the fork steerer?
Likes For zookster:
#209
Likes For tough_boots:
#210
Standard Member
Liked 940 Times
It's one of my favorite color schemes on a bike. The grey up-front is brilliant.
#211
Quoted: 2326 Post(s)
Liked 5,012 Times
This is the same "flavor" offered over on Paceline
https://forums.thepaceline.net/showthread.php?t=296653
Steel is real...and comfy.
Likes For jamesdak:
#212
Quoted: 2490 Post(s)
Liked 2,961 Times
Likes For Trakhak:
#213
Standard Member
Liked 940 Times
Re-spray of 1989 Pre
You may remember this frame-set from post #5 of this string. It was a bold yellow for 20 (some odd) years, professionally done by The Color Factory. Bike was originally black. Our friends at Yellow Jersey have just completed the second re-spray of this frame, this time in a lilac color. I hope to get it in the door soon and re-assembled. This is my long-distance bike.
Likes For 1989Pre:
#215
Standard Member
Liked 940 Times
pastorbobnlnh might have a 7-speed freewheel. Maybe even one that is AccuShift compatible.
#216
Quoted: 70 Post(s)
Liked 183 Times
I always build my bike up with components that make it fun to ride for me! That means it must fit, and not have aspirational gears (big gears I can't use....). Otherwise it just sits... So whats the point of owning it? Some like their museum pieces. Not me, I want to ride them!
Likes For OldCoot:
#217
[QUOTE=1989Pre;23056858]That's a great color. I bought my Technium in 1990. Aren't they great? Did you get some miles in this summer?
7 speed thread on freewheels & bolt on cassettes are still available for the time being. Check ebay & AliExpress.
AliExpress is very interesting. They're a direct link to Taiwan, Vietnam, & China for basic bike parts. In other words, if you can't get it on AliExpress they don't make it anymore.
Ramzilla
Ramzilla
#218
Standard Member
Liked 940 Times
[QUOTE=ramzilla;23062946]
When it comes to free-wheels, I would much rather have a N.O.S. Japanese or French than any current freewheel. It just seems the build quality is much better, at least in regard to the Shimano TZ, which is awful. New Sunrace is still not as good as the older stuff from the Technium era.
Ramzilla
Ramzilla
#219
Quoted: 15 Post(s)
Liked 15 Times
Bottom bracket is wobbling, so that's the first on my list. Anyone have the specs for the 1991? Thanks for the tips on the freewheel/cassette locations. I'm honestly debating replacement versus repair at this point. Even finding hood replacements proved troublesome.
#220
Standard Member
Liked 940 Times
Your b.b. is loose? That is a standard, square-taper bottom bracket, and all you have to do is make sure the cups on both sides are tight. This should take a bike shop five seconds if you don't have the wrenches. What is the make and model of your shifters? AME makes replacement hoods. My Technium came with Dia-Compe Aero Compe levers, and I bought the AME new old stock.
#221
Standard Member
Liked 940 Times
These are the only photos I have right now of my newly-painted '89 Technium. I need to buy a new camera, and when I do, I'll get some other outdoors shots. Control Tech bar tape.
New old stock ITM stem, closer to the age of the bicycle than the bolted-face one I had before.
Decals from lettering.com
Likes For 1989Pre:
#222
Quoted: 15 Post(s)
Liked 15 Times
Your b.b. is loose? That is a standard, square-taper bottom bracket, and all you have to do is make sure the cups on both sides are tight. This should take a bike shop five seconds if you don't have the wrenches. What is the make and model of your shifters? AME makes replacement hoods. My Technium has Dia-Compe Aero Compe levers, and I bought the AME new old stock.
#223
Quoted: 638 Post(s)
Liked 1,298 Times
Finally done after years of hanging in the rafters.
#224
Finally got a chance to ride my winter project bike; the frame is from C&V's own "jdawginsc", and the rest is from my parts boxes & ebay. Please forgive the clashing bag colors and the chain on the little ring; the ride was last minute and the front mech was giving me sass (always some bugs to work out on the first ride or two). The 11-speed 105 shifted amazing; smooth as silk and silent as the grave. I will get a better photo somewhere along the line this season and will share it when I can.
John
John
#225
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 671 Post(s)
Liked 980 Times
John
John
glennhatton
3
01-26-11 04:03 PM
