Racer Tech Thread
#1651
Bikes: Yeti ASRc, Focus Raven 29er, Flyxii FR316
Quoted: 17 Post(s)
Are you ok with adjusting brakes when swapping wheels? My stable:
Training clincher: 56mm depth 27mm wide rim
Race tubular: 80mm rear 56mm front depth 27mm wide rim
Light race tubular: 38mm depth 25mm wide rim
No adjustment necessary. 25mm tires on all three. Fast with a great ride.
My last question, given budgetary constraints:
I have friends selling wheels of various vintages, and some options from eBay. Some first-edition, paired spoke Bonty Aeolus, some Reynolds DV46s, some Easton EC90s. None of them are super aero, current generation, U-shaped rims.
Do you think any of those would give much to a modern, U-shaped open mold rim on DA or DT Swiss hubs? Leaning towards that option vs. used, old model wheels. Aero seems more important than weight, to me, if it's 100-150g difference.
I'm building this bike under $2500; aiming for 7kg or less. I'm small, and small bikes are light.
#1652
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
No. The old stuff is OK - not much difference. But sometimes older wheels have fatigued holes/nipples/spoke heads. Aero to a degree is more important than weight. 50mm are a sweet spot. The EC90s are good. We found deeper took more effort to control. I would not go deeper than around 50. Then, depending on roads and riding (pace, or solo, flats/hill/wind)you need the right mix.
Don't underestimate the physiological value of light. If it feels faster to you (light feels more than does aero) you will likely make it go faster.
#1653
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
One drawback of older wheels is that the freehubs are limited to ten speed. I got a nice set of Reynolds 66s cheap because the previous owner went to 11 speed. IMO, if you're going with Shimano, going with 11 speed is worth it; don't know about SRAM or Campy.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#1654
Yeah, I'm good with tools. I've built all 3 of my mountain bikes and my CX bike from a bare frame, built all 10 of my wheels from hubs/spokes/nipples/rims, etc.
I think there's a small difference between the DV46 (raced/trained on them for a couple years) and the not-quite-U shaped Stingers (2010, before U shaped, but they are 28mm wide). However I don't have any power/objective data to back it up. I also have cognitive dissonance working against me as I replaced my DV46 clinchers and tubulars with 3 (and now 4.5) sets of wider HED wheels (Stinger 4 front, pair 6s, 7 front U shaped, 9 rear U shaped, Jet 6 front, Jet 9 rear, Bastogne/Ardennes). Therefore I'd be stupid if I concluded that the Stingers aren't better, therefore cognitive dissonance
I basically gave my DV46s to a teammate who just returned them as he's not racing anymore, and I got to use them twice in races, when I flatted my front wheel (Stinger 6 both times). The DV46 felt slow back to back with the Stinger 6 (not-U-shaped), but again, no data to back it up.
A sort of friend who tolerates my questions and who often worked with companies and pros in a wind tunnel doing bike data told me that technically a narrow wheel will be faster but you have to use a narrower tire, with all a narrow tire's disadvantages. The wide rims come into play when you want to use wider tires.
A few other points.
First, a tall wheel is faster in a cross/tailwind kind of situation, where it can sail. Shape isn't as critical. I don't use tall wheels for the headwinds, where everyone is going slow. I use them for the cross tailwind bits where I pick up noticeable speed. On windy courses tall wheels can make a big difference in top speed, and that's what concerns me. For a long time I favored my Specialized TriSpokes, aka HED3, and a rear disc wheel, especially in the really windy flat courses. In less windy but super technical courses I'd use my lightest wheels, not really aero (Zipp 340s), but super jumpy. I had Zipp 440s (58mm tall) but usually put the TriSpokes on instead. For road races, which I still did back then, I'd use a super light front non-aero (280g Campy rim or 330g FiR rim wheel) with a 440 rear (for the sail effect after I got shelled on whatever hill).
Second, the differences between an older narrow V shape wheel set and a newer U shape rim is not as much as a non-aero wheel to an aero wheel. If I was to try to do a bike for less money I'd use my DV46s. If I could I'd get a set of 66s and a whatever the 32mm tall front Reynolds wheel was called (KOM?). Short front wheel for courses where it's super windy or I'm descending fast, 66s for everything else. 66 rear is good for most everything, I'd even go taller if I could without gaining much weight.
Third, tires. I've only used 19 and 21 mm tires on narrow tubular rims. I don't know how they'd fare with a 23 or 25mm tire. I use 23mm tires with my Stingers, used 21mm initially with the 6s (first set I got). I think the 21mm are supposed to be faster than 23mm due to aero profile but they made me nervous in hard corners as the carbon stuck out so much.
Gotta go help Junior with his train tracks.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
#1655
Bikes: Yes
Quoted: 9 Post(s)
It's not a matter of whether you are good with tools, it's whether you can deal with the hassle, especially during crunch time in a race when you need to swap wheels quickly.
10/11 is a consideration with older wheels. Profile is another. My first set of carbon wheels were deep-v. Super fast but absolute hell in crosswinds at 50mm depth. All of my current wheels have a Firecrest shape, and are much easier to handle in a crosswind, and some are deeper. I am also small and pretty aero, and get blown around a lot. The new wheels still catch the crosswinds but it's a more gradual movement that gives you more time to react.
#1656
Liked 371 Times
Good point. For ~$70/hub on some hubs (Easton EC90s, PowerTap), we bought new freewheels that were 11 speed, but others (Zipp 900) I could not find that option.
#1658
OMC
Quoted: 461 Post(s)
Liked 116 Times
Just committed to buying an older set of Zipp 303 tubulars. I'm thinking about mounting a set of 25mm tires on them. Good/bad idea? Recommendations?
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#1659
Liked 371 Times
Good idea. For racing, hard to beat the durability and good performance of the Veloflex. FMB for a bit more money are not as durable, will not mount as well, and are better performance. If you don't race in rain - go silks.
#1660
Bikes: Yes
Quoted: 9 Post(s)
303's are great wheels, a standard for cyclocross where 25mm tires would be narrow. Tubulars aren't the same as clinchers when it comes to matching tire width to rim width. I like Vittoria Corsa CX at $50 each, hard to beat. You can save $15 and go with the Corsa Elite. If you can spend more then the Veloflex Carbon and Continental Competition are nice upgrades.
#1661
OMC
Quoted: 461 Post(s)
Liked 116 Times
Thanks, guys. Most of my experience is with clinchers where rim width vs. tire width is an issue. I'm getting these wheels cheap from a guy who maintains his stuff like Hermes.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#1662
Version 7.0
Bikes: Too Many
Quoted: 1341 Post(s)
Liked 2,483 Times
I have the, this is pretty funny, "older" technology i.e. narrower rims. What Zipp says is that one should match the tire width to the rim width. I run the 22 mm tires on my tubular rims and for the road conditions that seems to work. In selecting tires for racing, I go for the tubulars with latex tubes.
#1664
Bikes: S-Works SL3 Tarmac, Allez E5, Leader 735TT, others
I've wanted to try it but it's pretty expensive for ass cream. I use Chamois Butt'r Euro Style, which is very similar to Assos (my previous go-to), and half the price of DZ Nutz. I have to use it for every ride (and I still end up with saddle sores on occasion), so my cost requirements may differ from yours.
#1666
Quoted: 17 Post(s)
Quoted: 17 Post(s)
Do they still have Wednesday Worlds like 15mi NE of town? 1mi x 1mi square circuit? Old man Stone still show up?
#1669
Quoted: 17 Post(s)
Just picked up a SRM spider for Hollowgrams with SRAM rings and PC V for $297, shipped. I have the arms, bolts, and spider installation tool, now I just have to track down an SRM specific 104mm axle and lockring.
One problem: I don't think it will mount on my bars. I got a smokin' deal on the Cervelo S5 bars before I found the SRM. Any ideas?
#1670
Quoted: 693 Post(s)
#1671
Quoted: 693 Post(s)
all else equal, though, go light.
i've got some SUPER light wheels i built up. they are great (uphill), but i'm not going to beat my clone riding 404s on most terrain...and that's with what would be considered an extreme weight difference for a whilst. i won't write more as this is pretty obvious for anyone who's done a test.
#1672
Liked 371 Times
I know of no road cyclist riding the most aero stuff they can get. They give up aero for other things. Didn't we just do pages on this?
#1673
commu*ist spy
how long to carbon brake tracks tend to last? one of the reasons why I kind of look forward to disc brake road bikes, is because I don't have to worry about hard braking melting the resin in my carbon rims. the circuit race I did yesterday had some turns where you could smell the rubber every lap. it sucked.
#1674
Quoted: 693 Post(s)
Anyway, the context is a wheel around 50, 60mm deep and duke asked about a 150g difference. You told him if it feels lighter the rider will make it go faster. I disagree in this and many cases.....including using the wheel we are talking about (~404) vs about as light a wheel as one can build. Go seek out the writings of poertner on the testing done for light v aero....including some blind testing. Based on what you are writing it doesn't sound like you did that from when it was brought up earlier.
I I was on the fence but am starting to believe what others are writing about trolling.
#1675
Zipp 340, 440, they wren't the same shapes as even the narrower 404. I actually still have a 404 (rebuilt to a front hub) and a couple 340s (one just a rim, one a rear wheel). The other wheels I had and tested for myself were Spinergys, the original Campy aero wheels (only had 16 spoke Ventos, not the 12 spoke Shamals), a prototype tapered? disk wheel (not lenticular, it was a straight line from the hub to the rim) with an ultra light rim, and then some non-aero wheels.
Nowadays, for weight and aero, I like the HED S7/S9 combo for virtually everything. I have a non-U shaped S4 front, used it just once until I flatted. I also have non-U shaped S6s but rarely use them, prefer the U shape for control up front and I want the tallest rear wheel I can deal with.
Goal is to replace my 23mm wide clinchers (Jet 6/9, Bastognes) with some 25-28mm wide clinchers, hopefully carbon. Then no more adjusting the brakes and also more consistent braking between training and racing.
