Addiction LXXVIII
#1651
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Again, if you spoke to the ancient Romans about cars, planes, televisions, radios... they would have thought you were a heretic talking about the supernatural. What was once unbelievable and inconceivable...
#1652
Quoted: 943 Post(s)
Liked 172 Times
#1654
Quoted: 3361 Post(s)
Liked 3,638 Times
#1655
Liked 3,638 Times
Threw a cam position sensor code, got the sensor replaced. Few weeks later it threw the same code. After two days at the dealership and a reported call to GM they replaced the engine due to what they said was "excessive crankshaft endplay". I didn't question it much, mostly because it was just barely still under the powertrain warranty so I was thinking that I'd be okay getting a new engine at 60k if its free to me.
#1656
Quoted: 8287 Post(s)
Liked 9,064 Times
Gotcha. I'll see if anything obviously funky is going on down there. On my way home from work the left signal position on the lever didn't do anything, the right signal position on the lever activated the left side signals, and I lost the hazards. Got to be more centralized than just the signal switch if I lost the hazards, too, right?
Saw a Camaro with the 3.4 v6 where someone installed a heavy duty clutch and the extra force would wear out the thrust bearing on the crankshaft. Coming to a stop the engine would stall because the crank would move so far forward it would lose the crank sensor signal. I learned something that day.
#1657
Liked 9,064 Times
Welcome to Car Talk. (sorry)
#1658
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12790 Post(s)
Liked 7,698 Times
Oops. I guess it could've been worse. Almost looks like he just parked it there.
https://www.wyomingnewsnow.tv/conten...lb1xMBGLDJypKU
Likes For LesterOfPuppets:
#1659
Liked 3,638 Times
I've got a scan tool but it's the bare minimum. It has thrown a code for EVAP P0449 but I can't really see how that's related.
Nothing obviously wrong at the BCM, everything is clean and no scorching or anything crazy like that. Still just starting simple and disconnecting the battery for an hour or so, the internet says that it should reset.
It can't hurt, at least.
#1660
Liked 3,638 Times
#1661
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
It did keep running, just once though.
Likes For Bah Humbug:
#1662
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#1663
Liked 9,064 Times
Likes For big john:
#1664
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
I have a deep fear that the outcome of all this will be a clearing of small companies and the final domination of the megaconglomerates.
#1665
Should Be More Popular
Quoted: 22609 Post(s)
Liked 8,930 Times
Now that my financially imprudent partners have lost a big chunk of change and are askeered, they have changed their mind and it's looking likely the group will sell out.
Sad. Very Sad.
Likes For datlas:
#1666
Liked 8,930 Times
Likes For datlas:
#1667
Super Modest
Quoted: 10965 Post(s)
Liked 4,621 Times
#1668
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
On a more personal level, my small organization had been in discussion with a HUGE "partner" and previous to the current crisis, the consensus was to stay small and lean.
Sad. Very Sad.
Sad. Very Sad.
But also, since I hadn't said it yet. Wish it were under better circumstances for everyone.
#1669
Super Modest
Liked 4,621 Times
We have two franchise restaurants in our area that have said they probably will never reopen.
Keep the chain tight!
#1670
Liked 9,064 Times
#1671
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#1672
Super Modest
Liked 4,621 Times
#1673
Liked 3,638 Times
New observation:
Key "Off":
- hazards work correctly
- L/R signal lever: no action
Key "ACC"
- L/R signal lever position
- L: driver side lights illuminate
- R: driver side lights illuminate
Engine Running:
- hazards INOP
- L: no action
#1674
Quoted: 663 Post(s)
Liked 496 Times
Sunday I did 50+ miles, a level higher ride than I had been doing. No surprise my legs and even lungs weren't up for it. But my neck also bothered me. The next day it was apparent I had pulled something in my lower neck or upper shoulder, presumably from looking behind me.
Four days later and it still hurts almost as much as on Monday. wut
THE CURE
Roll neck slowly left. Try not to break anything by rushing it. Then roll slowly to right. Repete a few times. Then reach to the back of the neck and you should feel one vertebrae that seems to be protruding. Push it around from left to right a few time and you should feel it pop back into place.
I do some neck exercises almost daily to maintain strength in the effected muscles and this helps minimize recurrence.
Likes For berner:
#1675
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Man. I have icecream on the brain.
