pros and cons of tubular tires vs. clincher
#51
Over the hill
Quoted: 1000 Post(s)
Liked 1,211 Times
You haven't shown any real world tests (at least that I've seen). Only lab results. Anything not done in the real world is theoretical. You can't say it's proven to save x time in a time trial unless you have actually shown such a saving in an actual time trial. Not that I think this could ever be proven conclusively in the real world. That's why many things in all types of racing are theoretical. You claims still have merit, but they aren't proven fact and probably never could be.
#54
Quarq shill
Bikes: 08 Felt F4, 05 Fuji Team SL, 08 Planet X Stealth, 10 Kona Jake the Snake, 03 Giant OCR flat bar.
I don't understand how people fall into this little white lie.
Sure, at equal pressure, a clincher will have theoretically better rr. However, tubulars can be run comfortably at 220psi+
Let's pump up a clincher to 240psi and see how long the rim lasts or how many blowouts you have. You also get pretty bad handling characteristics in comparison.
Clinchers are practical but if you want to know what's better, it's tubulars.
The top 6 in thise test from Jens Heycke show clinchers as the lowest crr.
Compare this link from Roues Sales(note bottom graphs):
https://www.rouesartisanales.com/article-1503651.html
#55
Quarq shill
I run tubulars for various reasons. Not one of them being because pros do it.
I'm glad you guys will dump 2K into your bike and not do any research beforehand on the equipment you purchase. It has been proven time and time again that clinchers with a latex tube will have a lower RR than a comparable tubular at a normal pressure, i.e. 110-130.
No argument, it's been documented time and time again. You guys should spend time reading instead of just blindly looking at what the pros ride.
"But the pros ride tubulars."
#57
Peloton Shelter Dog
This is what I'd have to look like to pump a tubie up to 220 psi with any floor pump I've owned:
#58
I did not link the entire bibliography of rolling resistance tests or applications of all the performance models. I posted what a) made the point, and b) was convenient. If you want real world results start here https://www.midweekclub.ca/articles/broker98.pdf
#60
Peloton Shelter Dog
I wish I had $5 for every bike weenie whose opinion on this is off the pages of Fred Tech Journal. Most of the experienced amateur racers I know (and all the hard core pros) agree with me. But watching the Freds flopping on the BF Dock is always entertaining.
#61
By the way, that article dealt with such Freds as Chris Boardman, the world record setting Italian pursuit squad, and the U.S. National and Olympic team, but what do they know.
#62
Peloton Shelter Dog
#63
Quarq shill
Show one test that shows tubulars have a lowr CRR than clinchers.
And I'll show you 5 that say the opposite.
#64
all of tufo's good road tubulars go up to 15 bar no problem. if you ride tubulars i'm surprised you don't see 12-15 bar tires as normal.
#65
Peloton Shelter Dog
#66
Tubulars resist flats better, handle better, corner better, are more comfortable and faster.
this is what a tubular looks like in cross-section ---> O
it is always a perfect circle to the ground no matter if you are cornering or going straight.
this is what a clincher looks like--> U
I like tubulars because they are the best performance upgrade you can add to your bike. People are willing to pay outrageous prices for clincher wheels, $100+ clincher tires and uber lightweight tubes for no gain in real performance. I think too many have bought into the clincher marketing koolaid.
Spend less for a comparable set of tubulars and you get better handling, comfort, lighter weight & a faster bike.
#67
Quarq shill
https://ddata.over-blog.com/xxxyyy/0/...lar-specs.html
#70
Over the hill
Liked 1,211 Times
Did they break the world hour record or pursuit record on tubulars or clinchers? That's all I need to know.
#71
Peloton Shelter Dog
Your call. I won't debate this with you, I know everything, I'm right, you're wrong, that works for me, and if it doesn't work for you, my work here is done.
#73
Over the hill
Liked 1,211 Times
Not to play devil's advocate on myself, but stating that pros ride tubulars doesn't make any claim to which ones have lower rr. I'm sure some pros prefer tubulars because they'd hate to flat and roll a rim while descending the alps at 70 mph. I imagine that pro time trialists on velodromes would use clinchers if they were really that beneficial, though.
#74
The vehemence with which people are challenging the rolling resistance data make me wonder if they are really as sure of the superiority of tubulars in all those other areas. If tubulars were really as great as they claim, wouldn't they still be the preferred choice even if they had slightly higher rolling resistance?
#75
Part Viking, part machine
For those of you thinking of making a jump to tubulars here is an excellent thread. Goes over the basics and does a good job reviewing some wheels.
https://forums.roadbikereview.com/sho...?postid=301926
