Clunker 100 Challenge COVID edition #6
#151
Quoted: 790 Post(s)
Liked 1,769 Times
A bit of rainy day wrenching and I got the Mesa GXS MTB sorted out. With the silly boat anchor heavy suspension post tin the junk bin and slightly shorter normal post on the bike it rides a lot better. Basically all the issues with the bike stemmed from this piece of junk.
Ounce changed the bike rides great including the suspension fork without the double bounce wobble effect the suspension post gave.
#152
PeopleCode delaminator
I have another set of wheels to toss on it, let's say $20 for them, along with $10 for some parts bin tires and tubes. Freewheel's currently soaking in paint thinner. I'll need pedals, grips, front brake housing, and a seat, all from from the parts bin, so another $15 there.
Reusing the original bars, stem, headset, cable detangler, rear brake, rear brake cable, cranks, and chainring. Not sure about brake levers, I may have tossed them,
I don't need pedals, the set on the bike are in pretty good shape. Turns out I did toss the brake levers, so I dragged my last matching pair of levers out of the parts bin. Still have lots of other levers, just no complete sets. Seatpost, cranks, chainring, and bars are rustier than I remember so they get some cleanup and paint. I don't have anymore green, not going to spend more money on paint, so it'll have to be something else.
Chain's soaking in paint thinner too.
#153
Quoted: 790 Post(s)
Liked 1,769 Times
Repacked the wheels, they were from a different bike and didn't have too many hard miles on them. Bonus! They aren't a matched set!
#154
Quoted: 1952 Post(s)
Liked 2,013 Times
I wasn't going to but then I started searching for 100 dollar completes with tires that held air and sellers wouldn't get back to me. Then I saw this offered at pre-Carona prices and offered 100 bucks: seller says ok.
I think it's a 86 Allez SE SIS. Missing a bunch of stuff so the plan is to use a box of shimano 600 that came off an 86 IM that was too big for me and I sold the frame for what I paid for the whole bike. I don't know yet how I'm going to work out tires and I can't remember if I let the IM's seatpost go with the frame. I think this Allez takes a 26.?
Likes For Classtime:
#155
Here is a update on my Centurion. I have clean all of the paint off of the drive side fork , on the other side I just cleaned off the spray paint and left the original gold pain on the upper half. I have greased front and rear wheel bearings , put on a bottle bracket , got the front derailer cable moving so I now have all 10 gears. Also done some custom Commemorative lettering. I have been riding a few times and am at 35.94 miles.
#156
Non-drive side bottom bracket bearing cup and bearing cage/bearings had enough rust to make them unusable, so I swapped them out for more parts bin stuff. The cone on that side was fine, and the drive side stuff was fine. Crank spindle also fir fir purpose.
Since American bottom bracket one-piece crank parts are at such a premium, I'll say $2 for the cup and bearings/cage.
Bottom bracket and headset/detangler all cleaned up and ready to put back in to the frame.
#157
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
At long last, the Nishiki has paint!
As originally purchased in June 2016 (minus the parts).
Here's a pic I took in September 2018 while I was in the middle of stripping it.
It was mostly rust-free at that point. I finished stripping it to bare metal that month and then it sat in my unfinished projects pile for nearly two months. This weekend, I dug out the rattle cans I had bought for another project that never happend sometime around 2008 and got to to work.
Primer? I hardly knew her!
Lemony freshness!
And the fork...
Once the paint has time to dry, I'll need to get the paint stripper back out becase...
My choices are the original post (which I used to hold the frame while I was painting it) and a Campagnolo 2-bolt post I bought at Eroica a couple of years (which would put me more than a little over budget).
Lemony freshness!
And the fork...
My Bikes
My Bikes
Likes For Andy_K:
#158
Liked 2,013 Times
AndyK I have a 26.2 SR Custom or some such other good looking post that I was thinking of shimming for my 26.8 Clunker Allez SE. If you had something I could use, we could collaborate on our clunkers if that is within the rules. I'm already at $100.
edit: a little screwdriver/prying action let me use a 27.0 but I could use a couple worn out booted 700c tires.
Would look nice in a freshly painted seat tube.
#159
Quoted: 796 Post(s)
Liked 522 Times
Lemony freshness!
Lemony freshness!
#160
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
Likes For Andy_K:
Likes For Oldsledz:
Likes For Oldsledz:
Likes For Oldsledz:
#164
Quoted: 3811 Post(s)
Liked 6,713 Times
#165
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I've ridden 47.4 km on the Schwinn 3 speed since the challenge was announced. I'm at 70+ miles after I bought it. It's a cushy ride! Like a vintage Lincoln or Buick!
Take me to the river!
Development continues apace on the Supercourse:
Zut alors! The axles in the wheels I need to use are difficult to turn by hand, and feel crunchy. Oh, and the installed freewheel is a Maillard large ring model with 24 splines.
Thankfully the extra space lets me undo the NDS cone and extract through the DS... or so I thought. Everything was loose, which means the cones had over-tightened on the hub. I adjusted the cones so it rolls as smooth as butter, and addressed the front hub.
The cups were in fantastic shape!
I've seen lots of pitted French hub cones, these flawless cups and cones looked great! I simply put fresh grease and the old bearings back in and locked in the adjustment.
Rusty cable stop, chrome lost. ☹
I took off the components to derust them. Or at least the ones staying for the intended builds.
??? Are they designed this way?
I'm not sure how to address this. The wheel is oriented perpendicular to the fork crown but the brake calipers look twisted to the NDS. I've seen Calvin Jones take an adjustable wrench to caliper arms for toe in adjustments, but these arms don't budge.
Eh, they'll probably still work.
Likes For Unca_Sam:
#166
Quoted: 796 Post(s)
Liked 522 Times
Oldsledz Once upon a time I dated a girl from Midland MI, even passed through there once in the early 90s.
#167
The dropped
Liked 1,014 Times
Supercourse Update
I bought new rubber for the 27" wheelset, plus tubes and cables, for $35 total.
Then I fished the pedal bodies, cages, spindles, cones, locknuts, and keyed washers from the EvapoRust bucket. They got a rinse, polish, and the steel bits were sprayed with some fluid film. 40 5/32" bearings and some grease later. The pedals spin like new. I also realized that I could clean up the leather toe straps and use them for the challenge. Eucalan was my substitute for saddle soap. They'll work alright. Add $2 for the bearings.
The straps are almost dead. I'm being they'll serve me well enough for the challenge.
Catos of England cages, with scrapes and plenty of chrome lost for the left cage.
At some point, something or someone damaged the stem clamp bolt and nut. After lots of light oil and WD-40, i got them apart without rounding them (too much) or snapping the bolt!
Overtorqued? I don't know how a single thread gets moved like that.
Similar damage inside the nut. Grease your threads!
Where does one get an M8 tap and die cheap? Harbor Freight! I have a better quality m3-m7 tap and die set, and boy I could tell with how difficult it was to correct the threads with the carbon steel set from Pittsburgh tools. I did it though, and now the bolt and nut actually work together!
Threads no longer distorted. Threads on easily by finger!
I'm currently sitting at $88.14 for the project. I'll have to replace the headset bearings, but I'm pretty close to finished with materials I paid for. The attendants generally don't want to ring up ferrules and cable hangers and cable adjusters .
#168
Bikes: Yes
Liked 3,868 Times
I've been letting the paint cure on the Nishiki all week. With temperatures in the 90's today, I put it in the back of the car for a bit of extra baking. Alas, it didn't quite get to 100 inside the car. It'll do, I guess. I'll start the build this weekend. Tonight I dug out an unopened tube of silicone sealant that I bought for a bathroom remodeling project years ago and reattached the head badge.
Not bad, eh?
Not bad, eh?
My Bikes
My Bikes
Likes For Andy_K:
#169
Ok as Lackluster as my entry is, ID like to play,
I bought this last December at my local Goodwill Outlet for $14 as pictured. In fact, this pic was taken before i loaded it in the trunk.
Add one 26.4 seat post from Hazetguy for the cost of shipping ($11)
and a seat I had in the junk box (value $10?) i may rethink the seat though.
The tires were practically new but quite knobby although i think i can do 100Km on them.
Everything on this bike should be serviceable as is. just some elbow grease (and grease).
Of course, i do have a little room if i decide to replace a cable or 2?
am I in?
am I in?
Likes For norcalmike:
#170
Quoted: 796 Post(s)
Liked 522 Times
norcalmike I wouldn't value that saddle at any more than $5 personally. That old Hardrock should clean up nicely and I think we are only 1/3 of the way thru the 100 days of the challenge,,,,
Likes For ryansu:
#171
#172
I'm up to about 40 mi on the Worksman, hopefully early tomorrow morning I can put in some serious distance. Here is a pic with the basket and grips, both saved from a trip to the landfill. Someone mentioned putting on some Skyway wheels, I am 100% putting on a new set when this challenge is done. I can't seem to find a set for sale, much less for challenge friendly prices. I also considered aluminum BMX wheels, but these Worksman wheels are comically bulletproof and are working just fine. Good lord I hate the tires though, lol.
Sidenote: I found one possible benefit of the ludicrously low bottom bracket height, the crank acts as a kickstand!
#173
The dropped
Liked 1,014 Times
This folder is still available though:
Rare WW2 Japanese puppy folding bike
https://www.facebook.com/marketplace...5929951509327/
#174
Quoted: 796 Post(s)
Liked 522 Times
Unca_Sam I might get it for the saddle and the scrap value
#175
