Confidence destroyed, humiliated for starting a thread in ****** cycling
#51
Quoted: 2952 Post(s)
Liked 3,106 Times
I get pain when I ramp up duration or if some factor like a headwind has upped the intensity for a prolonged period of time. I think it's also a good indicator of going beyond your baseline (which might be very strenuous) OR not having worked them strenuously recently.
#52
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Different muscles, but that definitely happens to me in the early season as I transition from the gym to the bike. Now having a bit of that as I transition back into the gym--my arms especially as they definitely get neglected during bike season.
#53
Quoted: 850 Post(s)
Liked 344 Times
I don't know where to start but I recently made a post on a ****** (starts R ends with a T, censored for some reason, pronounced "read it") forum cycling about me having difficulty getting muscle soreness and thought that muscle soreness was an indicator of a good workout. I gave some background information of how I started cycling and what kind of riding I do. I mentioned that I did a 20 mile ride a few days ago, that I was going full gas all the way but that even when I was hurting all the way, that I experienced little to no soreness. I just asked for any advice that would help me.
After I made the post, people started commenting things such as "how autistic are you?" "we aren't here to stroke your ego". One person even asked in what time I did 20 miles and I said in 1:20 hr and I get so many negative downvotes for that and he says that it is pedestrian speed. Someone even shared my post to another forum and they are all putting me down saying how embarrassingly slow I am and that their grandma rides faster than me. I've become a laughingstock now all over ******. Honestly I feel unmotivated to even go out on the bike anymore. I just cared about breaking my own personal records and improving my fitness, I could care less if I'm slower than 90% of cyclists. I feel pretty down and unmotivated to cycle.
I think your post got interpreted as “I did this ride that was so hard/fast and barely got sore!”. I believe what you meant to ask was “I went really hard but wasn’t sore after. Was this not as good of a workout as I believed it to be?”
Take the following with a grain of salt because I’m not formally qualified to be talking about any of this:
I think there’s a difference between soreness and fatigue. If you get into lifting, and start piling on heavy weights day 1, you will experience serious soreness. You could end up practically bed ridden. This is due to micro-damage to your muscles/tendons. However, as you start to lift regularly, even lifting very heavy weights will barely cause any soreness.
So back to biking. Biking is a largely aerobic activity. It doesn’t challenge your leg muscles’ structure very much. Climbing stairs or running are probably an order of magnitude harder. You should not expect to be sore after a bike ride, unless you do several sharp neuromuscular efforts. Ie the hardest you can possibly go for under a minute - a sprint, even. This can happen in a spirited group ride but is extremely uncommon for people to do alone unless they are training to race.
Your legs burning up are a sign of fatigue. You’re out of glycogen and are pooling up lactic acid. This doesn’t cause soreness afterwards. It just makes your legs feel empty and weak.
Your definition of a “good workout” will change depending on your goals. The fact that you were fatigued but not breathing hard implies that you just need to develop some aerobic endurance (separate from “top end” aerobic capacity). Some call it fat adaptation or base fitness. Essentially, you want your muscles to be able to work without burning up all your glycogen immediately.
Ironically, the best way to do this is to do long, easy rides. Some even do these rides fasted in order to *start* the ride with no glycogen in their muscles, thus forcing their muscles to use fat for energy.
Someone can correct me if my “diagnosis” is wrong.
#54
To your original question: I don't think muscle soreness is a good indicator of whether or not you had a good workout. It is a good indicator that you haven't used those particular muscles strenuously very recently.
Also, if you're truly going "full gas," then 80 minutes all out is a brutal workout whether you're a noob or a UCI pro. If you do it every ride, that's a recipe for plateauing and then burning out.
#55
Quoted: 1002 Post(s)
Liked 237 Times
Keep in mind that the guys on the internet who can easily outperform your 15 mph pacing for 1:20 are also NASA physicists, self made billionaires, and are dating the entire Victoria's Secret model crew at the same time.
It's easy to be better than everyone else on the internet....when you don't have to back up and of your bull++++
#56
Liked 3,106 Times
I am not sure if I used "full gas" in the right context but it was almost 10 pm at a relative's place. I wanted to get home quickly and it was getting cold when I just had a jersey on so I opted to pedal harder and keep warm than to shiver all the way through which is not fun at all. I was just going as hard as I can without burning myself out but my legs really started crying at mile 10, all I could think of was getting home, my legs were becoming almost numb yet burned like hell. Wasn't a pleasant ride but it felt great coming home to earning a few PRs that I had not touched since 2016.
#57
Quoted: 346 Post(s)
Liked 398 Times
R. Moudatir, DON'T LET IT GET YOU DOWN. Unfortunately it seems, among a young and very immature, nearly 100% male segment of cycling community that regards itself as the "Serious Cyclists", they are just bullies for whatever reasons, insecurities and problems in their daily lives, that to feel like special people, they have to mock, ridicule, harass, intimidate, and ostracize those bicycle riders that are Not like them. They are insecure and afraid of including all into the membership of the bicycle riding community because they somehow feel threatened that having "Novices" or "Non-Performers" for lack of better word choices, will somehow ruin bicycling as they know it. You see these dumb ahzzz-es in their replies on various forums and threads. Instead of offering encouragement and positive advice, they essentially wish to run of the riff-raff that don't belong here anyway, as they feel in their own pea-brain, numbskull minds that they are the only folks that really matter.
You see it all the time, where they delight at bullying and negativity and ridicule towards those New to the community who may only be casual riders or folks that ride basic bicycles. You see these turds that reply to folks' subject topics on their fun, joy and challenging struggles in whatever type of riding that they do. You see these such turds that ridicule some of these folks for riding and owning a ( BSO ) , Bicycle-Shaped-Object, as in their warped minds, it does not qualify as a bicycle.
These young male idiots have a lot to learn about life. You just have to look at them in the proper context. They are insecure losers who are just being bullies because it gives them a feeling of superiority. Most of them will mature and grow-out of this stage. Until then, just remember that there likely will always be pricks such as these on cycling forums, and just don't give them the satisfaction of ruining your day, because they are just turds anyway so just Flush Em !!
Likes For Vintage Schwinn:
#58
Quoted: 4227 Post(s)
Liked 2,488 Times
It sounds like OP is suffering from low self-esteem and lack of confidence. If you can't put up with a little bit of negative talk on internet forums how are you going to deal with negativity in real world ??...HTFU
Likes For wolfchild:
#59
Quoted: 2236 Post(s)
Liked 1,314 Times
#60
Hear myself getting fat
Bikes: Sir Velo A Sparrow
Quoted: 335 Post(s)
Liked 265 Times
Don’t let a few dicks get you down. The ****** thread ain’t that bad and more than a few people gave some very useful advice.
Keep going, it’ll make you mentally and physically tougher.
#61
Expired Member
Quoted: 3674 Post(s)
Liked 5,438 Times
#62
Forum Moderator
Quoted: 3091 Post(s)
Liked 6,601 Times
Bike Forums does not allow threads about other forums.
Closed.
Closed.
