Show me your cruiser.
#1401
but it didn't fit quite right
so I had to shave the edge off of it.
And then I bought a sealed bottom bracket for it which is the best $20 I've ever spent on a bike. I'll be going with these as often as possible.
I also bought the cheapest crank set I could find,
I had to pull it in close to the frame to get the larger ring to line up with the wheel. That meant I had to grind some tabs off of the inner chainring (it's all welded together). Not the ideal situation but the crank was literally cheaper than buying a round chainring to replace the biopace I had on the first 3 piece crank I put on here. The Biopace would have worked but I wanted that crank for a different bike anyway.
Likes For DesmoDog:
#1402
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
When I got the frame it had a bottom bracket adapter with it.
#1403
Bikes: 91 Ritchey Ultra, 1992 Specialized Stumpjumper, 1990 Klein Rascal, 97 Trek OCLV9700, 90 Minnelli Eclipse, 95 Marin Bear Valley SE, 1991 Breezer Lightning Flash 1991 Diamondback Axis 1992 Stumpjumper Comp 1983 Stumpjumper Sport
Quoted: 101 Post(s)
Liked 646 Times
Likes For victorm:
#1404
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
Refining this into more of a clunker. Wanted something somewhat lightweight and with clean handlebars. Also wanted bigger tire clearance and I really think big 26inch has a lot going for it if your neighborhood doesn’t have the best roads.
Down to 26.4 lbs. likely close to the lowest weight this will go.
Will save some weight by switching cranks to something like a Sugino 75 copy. Will add some weight by installing beefier pedals.
I think right now it’s 40-22.
Thinking about setting up a set of wheels with off road oriented tires with this gearing.
Then a more street oriented setup with an 18t cog.
ETA. The chain line is off a bit. I figured it out after the chain dropped a couple times popping wheelies or hopping curbs. Hoping by switching cranks to something with a 110 or 130 bcd I can adjust the chainwheel in with washers.
And… I think the bearings in the BB ate the cage on the right side. Have only had the rear wheel apart so we’ll see.
Likes For SkinGriz:
#1405
Bikes: There is always room for one more.
Quoted: 185 Post(s)
Liked 391 Times
[QUOTE=SkinGriz;22943090
And… I think the bearings in the BB ate the cage on the right side. Have only had the rear wheel apart so we’ll see.[/QUOTE]
This is looking good! Since you have to get into the bottom bracket anyway, can you move the existing chainring in with a shorter spindle?
Don
Don
Likes For GeezyRider:
#1406
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
I don’t know. The crank arm doesn’t have traditional bcd arrangement or a one piece pin. So I think it’s more likely that the chainring won’t be reused.
And I would like the option of changing chainrings without removing the crank arm.
As a teenager I had the cromo GT splined cranks on a BMX bike. Some of my friends had the similar Profile 3 piece cranks. They weren’t at all heavy and we’re ridiculously strong. All that to say I’m not convinced aluminum is always the higher performance material.
Likes For SkinGriz:
#1407
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Those euro adapters are great, you get a bmx bb
https://www.ebay.com/b/19mm-Euro-Bot.../bn_7023231059
The red one is cool...
and cranks like these
https://www.danscomp.com/stolen-mob-...s625/p1221126?
Makes what you're trying to do child's play.
Likes For Schweinhund:
#1409
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
This.
Again, this.
The only thing I can add is BMX is the way to go in your case. it's easy to adjust the chainline with spacers
Again, this.
I think it might (big maybe) be square taper under the arms.
Likes For SkinGriz:
#1413
Quoted: 101 Post(s)
Liked 646 Times
78 Trail Mate
Likes For victorm:
#1415
Quoted: 101 Post(s)
Liked 646 Times
wheels are from 1954 CCM that I sold to a buddy. He gave me the wheels and tires back cause I liked them so much. Ended up with this frame so figured I’d put them together.
Likes For victorm:
#1417
Quoted: 101 Post(s)
Liked 646 Times
Likes For victorm:
#1418
2023 Sun 3-sp cruiser with aftermarket saddle and ape-hangers
Likes For NYLowLife:
#1419
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Quoted: 238 Post(s)
Liked 323 Times
My wife likes an upright riding position and is a pretty weak rider. I sold her city bike, and got her this Electra Townie GO! 7D eCruiser, so she can keep up.
It has 36 V, 7 Ah worth of batteries in the downtube. That's not a lot as eBikes go, but enough to keep her going any speed she wants up to 20 mph. It has a simple display with 5 green LEDs showing battery level and 3 red LEDs showing PAS level. (Power Assist System) It has a a nice quiet 250 W motor in the rear hub, and the downtube isn't too huge, so people don't always notice it's an eBike. It has a 7-speed cassette; just the one smallish sprocket in the front. Granny gear is VERY low; walking speed, so hills are no problem.
This past week, she bought the Electra luggage rack and shopped at Target and found a basket she likes, which I zip-tied to the rack. I plan to have her join a coffee ride with my local bike club Saturday morning.
The bike is the center one in this pic, and the wife is on the right.
Wife's Electra Townie GO! 7D is in the middle.
Just before riding it home on the first day.
#1420
Quoted: 242 Post(s)
Liked 455 Times
Did a tuneup and complete scrubbing/polishing of this beauty at the shop.
It a two speed using the lever to change speeds. It was frozen but a bit of a soaking in mucoff did the trick. It came out great and the owners...original mind you...loved it. Rode it a bit and it is a nice ride, very smooth. Just a coaster brake but it works.
A Schwinn "Corvette"...seems to be around a '60's vintage...wonder if Chevy said anything.
#1421
Live not by lies.
Quoted: 860 Post(s)
Liked 784 Times
Beautiful bike. Glad owners are happy with it.
Likes For Kai Winters:
Likes For spyderjohnson:
#1425
Quoted: 101 Post(s)
Liked 646 Times
Trail Mate is complete
Likes For victorm:
