#9126
Likes For texaspandj:
#9127
Quoted: 1200 Post(s)
Liked 1,356 Times
Life is just peachy when you have a 48cm Centurion Ironman. A few weeks and ill get it looking pretty.
Likes For malcala622:
Likes For RobbieTunes:
#9130
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
85 with Shimano Type A Braze ons?
#9136
Quoted: 4560 Post(s)
Liked 2,802 Times
#9137
Yep, yep.
The '85 Ironman came with the beautifully challenged orgin8 fork and the Shimano type A shifter bosses...and No wheels.
Here's a thread that Doc made about those shifter bosses.
https://www.bikeforums.net/showthrea...to-later-style
For now gonna use the original shifters. Eventually get some brifters and modify the cables stops instead of Dremeling the shifter bosses.
Here it is eith tri color group, I have 2 almost complete sets, Actually one is C-Cats. I have everything to complete build except wheels. Eventually this will be all electronic etap.
#9138
Here's a shot of what has or will go on the '85. Won't use those shifters and the chain is what came with this group. The 11 speed carton is just to keep chain clean. The pink cup has the original headset. The only original parts I'm using is the HS, stem, turbo saddle and shifters. Missing is the MV pink fork I'll have to use...all I got for a 54cm.
#9139
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
1988?
This one followed me home tonight. My size with original bars included. This may get MicroShift R7s over the winter. Minimal wear on the rims.
You guys are a bad influence. Honestly.
Likes For Phil_gretz:
#9140
Quoted: 1952 Post(s)
Liked 2,014 Times
So the Type A brazeons match 600 friction shifters? And the 85 has tire clearance like the Classic 86 or 87 Master? I think that makes for my ready made Eroica CA Ironman.
#9142
Death fork? Naaaah!!
Yes. Yes, we are.
I love the Microshift brifters, Lose the funky stem and radar array bars and you'll be happy.
Top
#9143
aka: Dr. Cannondale
Liked 3,406 Times
Yes, maybe even some more. I ran Vittoria Rando 28’s on my 85 with the original Araya rims so prolly close to an actual 28 and they ran fine.
Would make a fine Eroica steed!
Likes For rccardr:
#9144
Zip tie Karen
Liked 1,542 Times
'87 Cleaned Up Enough to Test Ride
Okay, I replaced the chain, cleaned the rear and front derailleurs, and swapped in decent pedals. I trued the front and rear rims, repacked the front and rear hub bearings, and cleaned and lubricated the freewheel. Now, with the original bars and stem back in place, and cleaned Shimano brake lever hoods, I've taped the bar with inexpensive black faux carbon stuff that I had.
Now for a test ride this evening. If I decide to keep this, then there will be things to change on it. I'm not a fan of this shape of saddle. The stem reach is ~1cm too long, and I'd like to lower it a bit. Then, there's the question of shifters, cable stops, and freewheel. Maybe I'll reach some conclusions tonight. 42 x 24T doesn't scare me as a climbing gear, not with this sporty of a frame geometry.
EDIT: I know that the chain is 2 links too long. I'm waiting to monkey with that until I decide its future.
#9145
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
[QUOTE=Phil_gretz;21730946]
Personally, I liked the "Radar" tape...it matched the paint on the frame...
Best, Ben
Best, Ben
#9146
Zip tie Karen
Liked 1,542 Times
[QUOTE=xiaoman1;21731650]Yup. This is what I had on hand. I also had the choices of gold, yellow, or pink. If I choose to keep and upgrade it, this bike will receive a white saddle and white bar tape.
#9147
aka: Dr. Cannondale
Liked 3,406 Times
Phil, we could get together and swap bikes for a ride so you could see what one is like with upgrades.
Mine is set up with downtube shifted DA 9 speed.
It’s a rocket.
It’s a rocket.
Likes For rccardr:
#9149
Liked 2,182 Times
[QUOTE=Phil_gretz;21731773]
white saddle and tape will really compliment the look
As you can see, I like colorful H.B. tape!
Excuse the non-drive side photo as well as a Bianchi in this thread!
Miami Vice, Purple Haze and Grey Ghost
#9150
Zip tie Karen
Liked 1,542 Times
Thanks, Doc. I may take you up on that, at least we could ride together and discuss ideas going forward. I did a 20-mile lightly hilly ride last evening and have a few observations about this bike. The ride spurs you to push harder. Part of it is the geometry and frame material, and the remainder is the tight, high gearing. At cadence, it moves out smartly. The 6-speed SIS 105 stuff works remarkably well, I thought, although the front upshift seemed to bog down a bit unless I put very positive pressure on the lever. (Note: I need to look at that, could be cable binding or something interfering with reaching the high limit position.) This bike was targeted toward stud riders. The downside is braking, obviously. I didn't swap out the pads, which appear to be original. Cartridge KoolStops would help a lot, as would better calipers. Overall, though, I like it, I must say.
