Bikesdirect Mini Velo upgrade thread
#676
Bikes: parlee altum R, 3rensho katana, mercier nano, campy equipped
Interesting -- how does the shifter limit itself to just 8 shifts? Is it the RD limits that lock it? Like do you match it up highest gear on the shifter to smallest cog on the RD?
#678
shifters dictate the clicks, indexing.
RD dictates the sweep/ upper lower limit.
#679
Quoted: 16 Post(s)
Handlebar width
I have read through the thread and did not read anything about this question I have. My Mercier Nano is on its way from bikesdirect. I definitely want to upgrade the handlebars to some short and shallow compact bars. My question is since the effective TT is 3.5cm shorter than my cyclocross bike should I use handlebars that are wider to accommodate the handlebars being closer to me?
I posed this question in the fitting forum in much more detail and got no response.
https://www.bikeforums.net/fitting-your-bike/1101912-going-soma-double-cross-dc-mercier-nano.html
...Thought I might have better luck here.
#681
Use a longer stem with drop rather than rise. I use a Velo Orange stem of 130mm in length with -/+17° rise on a minivelo. On a headtube of 73°, a -17° stem offers no effective rise and lies parallel to the ground. Here's an image of such setup...
#683
Thanks.
Another issue to think about is the diameter of the steerer and stem. Minivelo steerers tend to be 1" in diameter while the standard, most common stem diameter is 1-1/8". If the steerer is 1", you will need a shim, like I did, when installing those VO stems which are 1-1/8". Fortunaly VO knows this, and sells the shims which match their stems previsely.
Another way to stretch out the cockpit is to use a seatpost with set-back, meaning the saddle is pushed back relative to the axis of the seatpost and seat tube. On minivelos with short wheelbases of 93cm like the Nano, and my own mixte minivelo, however, this may have a negative impact on weight distribution and handling.
#684
Quoted: 16 Post(s)
Thanks.
What tires are you running on yours?
I am leaning towards Tioga Powerblocks but am a little concerned that they are race tires so am not sure how they will hold up in wet conditions....
#685
Take a look at the Maxxis Torch 37-451.
Or the Maxxis DTH.
Or the Maxxis DTH.
Thank you so much for all the input. I am actually looking forward to the shorter cockpit and wheelbase of the mini velo, I think it will be a fun bike when I am finished getting it set up.
#686
Quoted: 16 Post(s)
I'll look into the dth's as I know they are 406's and that's the size wheel the Nano has. I have heard good things about Maxxis, I have friends that I run 650b's and swear by their Maxxis. Thanks for the tip.
#687
Oh, sorry. Forgot the Nano is 406. Yeah, I'd look to the DTHs...
#688
Another option from Velo Orange is an adaptor that goes from a 1" stem to a 11/. this will allow you to use a longer stem and you will also be able to benefit from a removable face plate so you can pull the bars without taking everything off. Between a longer stem and handlebars that have a grip ahead of the stem end such as bullhorns, moustache bars, regular bars with bar ends, or even the bars that come with the bike.
#689
Thread Killer
Quoted: 3152 Post(s)
Liked 1,717 Times
https://www.bikeforums.net/fitting-yo...cier-nano.html
Also, it's going to be difficult to find a modern short/shallow bar in the Nano's stem clamp size of 26.0; I recall the Soma HWY One fits the bill. You'll may find it makes more sense to use a threadless stem converter and step up to the new 31.8 standard, as the stock stem is really quite cheap looking anyway.
#690
Quoted: 16 Post(s)
I'm not sure I follow the rationale which would suggest bar width should increase as the bars come nearer, so I guess I'd answer "No," presuming you like the width of the bars on your CX bike in the first place.
Well the rationale is such that yes, since the cockpit will be tighter should my bars be wider? As I am quite broad shouldered and I feel that a 40cm bar being closer to my body would be an uncomfortable riding position.
I measured my shoulders (bony part to bony part as 42 cm and added 2 cm as Art's cyclery says in their video.) I went ahead and purchased a 44cm short shallow bar with 31.8 bar clamp diameter. Yes i am using a 1 to 1 1/8 inch adapter with an 80cm threadless stem that fits 31.8 bars. So we will see how the fit feels when I put the bike together (it's still in the box).
PS I hate the stock quill stem and definitely wanted to replace it for asthetics alone. There are so many elegant quill stems to choose from and that chunky clunky-looking thing is what they chose? It's begging to be upgraded and discarded.
#691
Quoted: 16 Post(s)
Question regarding headset stack hieght and the Mercier Nano
I have been looking at JIS headsets and see several on eBay in my price range of $5-$30. My question is does anyone know the stack hieght of the stock headset and how much leeway does one have in choosing a new headset with more or less stack hieght than the stock headset and it still work with the stock fork?
I am quite adept as an ameteur bike mechanic but I will admit that headsets are something I know very little about.
#692
I have used 3 of these, one in 1 1/8 and two in i". They cost a bit more but have worked flawlessly for years. Google measuring headsets and see if your will fit one. '\
Grand Cru 1" Sealed Bearing Headset - Headsets - Components
#693
Thread Killer
Liked 1,717 Times
Chaadster, thanks for replying.
#694
Thread Killer
Liked 1,717 Times
You're going to need to stay pretty close, obviously, because you'll need to have enough purchase on the steerer threads with the locknut. Of course you know that, probably, so I guess I'd say 1.5mm either way because there is a spacer washer you can remove and substitute with a little thread locker to drop height of a taller unit a bit if needed. I'm no pro, though, so verify that!
HTH...and yeah, the stock HS is a POS; not even sealed! Let us know if you find a good JIS unit. I've been wanting to replace mine, but really wanted a blue one, and could only find one for $200; I'd be happy with black at this point.
#695
Quoted: 16 Post(s)
I understand your question about bar width, but I guess I've just never thought of, nor heard of, making any such width adjustment based on reach. To think about it, I guess I'd reckon that at the extremes of bike types, okay, put wider bars on a Dutch upright than on a road racer, but I don't know how to figure how comfort might factor in vis-a-vis width with decreasing bar/saddle reach on a drop bar bike. Sorry I can't help with that!
#696
Quoted: 16 Post(s)
https://store.velo-orange.com/index.php/components/headsets/vo-alloy-headset-in-iso-or-jis-size-46.html
That VO headset is an option I am looking at but I would like to have a black headset and am thinking about trying out one of these from eBay:
Look at this on eBay https://www.ebay.com/itm/381938306285
Look at this on eBay https://www.ebay.com/itm/311831224525
Look at this on eBay https://www.ebay.com/itm/201025694526
#697
Quoted: 16 Post(s)
I just put the calipers on my stock Nano headset, and it looks like 35.5mm (25.5 upper cup to locknot top, and 10mm for lower cup).
Thanks for the measurement data, it's much appreciated. One of the headsets I linked to had 30.6mm stack height, with 30mm outer diameter, and 27mm crown race, weighs 100grams and sells for around $25, so I'll probably go with that one and let you know it works out.
Quick question though is it possible that the listed stack hieght of 30.6mm is too short? I don't think that would be a problem as I know a stack hieght can be too long/tall but am not sure that the opposite could pose any issues...
Last edited by Cowick22; 03-26-17 at 06:53 PM. Reason: Wrong measurement data in post
#698
Quoted: 16 Post(s)
So I will probably then go with one of the other headsets I listed that sells for $13.99, and has these specs:
Steel MINI BMX / ROAD BIKE headset - 1" threaded
Material: Steel
Finish: BLACK
Size: For 1" threaded forks (BC1)
Diameter: 30mm bearing cups/27mm crown race, This is known as a "JIS" headset (as opposed to a ISO headset).
Stack Height: 24.5mm + 10.5mm = 35mm
Bearing: Caged: 5/32" X 8
Weight: 126 g
#699
Thread Killer
Liked 1,717 Times
Disregard that last question about stack hieght shortness. I see you had already answered it in saying 1.5mm either way.
Material: Steel
Finish: BLACK
Weight: 126 g
Material: Steel
Finish: BLACK
Weight: 126 g
#700
Quoted: 16 Post(s)
Good call. Thanks for looking out. I guess I'll just have to deal with the stock HS for now or maybe look into the VO jis HS for $28. I would rather have it in black so I'll probably hold off doing anything to it except greasing it for now. Thanks again
Likes For Cowick22:
