What does Alto rim brake carbon wheel test tell us?
Quoted: 4412 Post(s)
Liked 1,566 Times
"Drivers who switched to Progressive saved an average of $550." Right. And who's going to switch if they aren't going to save money? Ask the question the right way and you'll get the answer you want.
Thread Killer
Quoted: 3149 Post(s)
Liked 1,714 Times
Bikes: 2010 Felt DA, 2012/6 Felt F5, 2015 Felt AR FRD
Quoted: 27 Post(s)
It doesn't tell us anything.
That's a textbook example of what someone thinks is a scientific test, but is actually junk science. There's so many variables that aren't controlled for, that you can't make any useful conclusions.
I'm no CF engineer, but about the only way I could see one layup conducting heat better than another is if one layup has voids in it and the other doesn't, or one layup uses less resin so that the CF fraction of the whole matrix is higher. Which I doubt.
Quoted: 1814 Post(s)
Liked 923 Times
Yeah, I smiled at your catch of their word mixup. I appreciated your joke. But yeah, whether their machines made a taut layup, or they created some AI to impart a little of its "machine learning" to their carbon, the idea that their tires conduct heat so much better because their machines produce a more taut layup just sounds like BS.
One carbon fiber says to another "Wow, we got machine laid and now I'm going to have your baby."
The other replies "No way, I know you're pre-preg."
Thread Killer
Liked 1,714 Times
Check out FSE's filament winding construction, which both eliminates voids and reduces the amount of resin needed.
Thread Killer
Liked 1,714 Times
I don’t think uncontrolled variables were the problem, rather the narrow design of the test. Which variables are you thinking of?
Quoted: 27 Post(s)
There's a lot
1) The work done on the rim by the brake pad.
2) Disregarding the fact that while they applied the same force to each rim, the coefficient of friction between the rim and pad remains unknown. This directly effects (1).
3) pretty much everything in here: https://www.bikerumor.com/2017/12/14...im-brake-test/
4) As everyone else has mentioned, wrong brake pad for each rim.
5) Disregarding that while the rims may have melted, a person riding them down a mtn wouldn't have been on them as long, because they would have removed more energy, slowing them down more quickly. They 'overworked' the rim per se.
6) Using 1200W as they did in the study is outside the realm of reality for that length of time. Someone would have to be falling off a mountain to require so much work/power be dissipated.
There's also the lack of depth in the study. They need at least ~16 rim tests to be sure the failure isn't due to random chance, and that's putting a lot of trust in student's t stats.
There's the lack of cooling on the rim as well. Unless I glossed over it in the study, there's no active cooling as there would be on the road.
There's probably a million more, but for all of these reasons alone, it's bunk. Could it be improved to the point where their points are valid? Probably not, but they'd need a whole lot more carefully designed experiment if they were going to convince me.
Thread Killer
Liked 1,714 Times
Thread Killer
Liked 1,714 Times
There's a lot
Quoted: 27 Post(s)
I think what he/we are getting at is there is no actual measurement of how much energy was put into the rim, by the brake pads. It's clearly different for each rim, because the coefficient of friction between the pads and brake track are different for each. He stated the same force was applied to the lever for each, but that's only part of the work equation.
Quoted: 1975 Post(s)
Liked 232 Times
Either total braking power or total braking work done. This controls the conversion of braking force to heat and actually gives you an idea of amount of heat dissipation that must be performed by each wheel.
Quoted: 1067 Post(s)
Liked 259 Times
If they had measured the braking force/torque at the caliper the amount of energy being dissipated could be calculated. They already had the rpm (the other part of the equation).
The 1200w motor thing was meaningless as it seemed to hardly vary in speed. I think it may not of been loaded enough to bring it down from its no load rpm.
Bikes: BH, Cervelo, Cube, Canyon
Quoted: 212 Post(s)
Liked 6 Times
I think the lab screwed up the power input measurement to the motor. It's the one factor that simply explains everything wrong with the test. And it fits that a bunch of mechanical engineers would bumble an electrical something or other.
Thread Killer
Liked 1,714 Times
That was not the point of the test. Would have doing so made it a better test? Maybe, but that’s a different test. It was a bad test for a variety of reasons, but not because of uncontrolled variables.
