Racer Tech Thread
#3226
If you do get rollers, I suggest doing it now. There is a bit of a learning curve to riding them.
#3227
Quoted: 1852 Post(s)
Liked 679 Times
I have a set of the cheap Performance brand Travel Trac rollers. They work well for my use and would probably suit your needs. And I agree that it is probably a good idea to get some practice on them.
I've also seen some very narrow rollers with a front fork mount that are designed for race warm ups. I think they pack up pretty small. That might work well for your needs. Here's one: https://www.feedbacksports.com/shop/...table-trainer/. It's pretty pricey though.
#3228
Bikes: Scott Foil 10, Di2
Quoted: 148 Post(s)
#3230
Quoted: 19 Post(s)
Problem with rollers is you need flat ground. If you're parked in a field or grassy lot a trainer will be easier. Just something to think about.
#3232
^ probably not.. They fixed the battery door problem which is the only issue I've had.
#3233
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
Just leave the trainer-compatible skewer on full-time so you don't have to swap anything pre-race.
#3234
commu*ist spy
my stages had power drain issue. upon search, this is somewhat common. currently going through the warranty process.
#3236
Tyrannosaurus Rexitis
Bikes: Scott Addict 6870
Quoted: 60 Post(s)
It's pretty low risk area IMO, but it's your $$. I didn't buy it when I purchased two Stages for us last year. Glad I didn't because two sets of warranty replacements later we sold them.
#3238
Quoted: 60 Post(s)
Wahoo Kickrs inside, HRMs outside. Made winter oh so enjoyable. Plus I spend a month at sea per year - the kickr will save my bacon.
I'm not really out of the market, but have been fine by RPE/HR so far. Ideally want a Pioneer. Just need to save $ for it (remember whatever I buy, double it). We are dinks, just dogs and we rent.
I somewhat prefer doing indoor anaerobic work. No need to watch for traffic, plan routes (there aren't any good ones), or worry about differences in FTP between us and me ending up miles down the road.
#3240
Ninny
Quoted: 686 Post(s)
I broke one on my cross bike (cracked the pod), and had another fail out of warranty. I was an early adopter so they had comped me the protection plan, which covered the out-of-warranty fail. The cracked one still mostly works, but I'd have replaced it if I had the protection plan.
#3243
Bikes: 2008 fetish illustre
Quoted: 10 Post(s)
Liked 8 Times
Wahoo kickr snap question: I bought this smart trainer a couple months ago and enjoy it for the most part. Issue is that the resistance generated when just under target seems high. For instance if I have target resistance set to 200 watts and I am at 180 it seems to generate a high resistance (feels like 300 watts!) until I get back up to 200... if I happen to drop down to 150 watts I have to be out of the saddle mashing the cranks to get back up to target wattage. I've done multiple calibrations and tried different iOS apps. Current favorite app is Cycleops virtualtraining.
Thanks for any thoughts on this.
#3245
Quoted: 160 Post(s)
#3246
Bikes: Yes
Quoted: 9 Post(s)
#3247
he's talking about in ERG mode.. if you let your cadence drop too low...it indeed feels heavy. I too experience this at very low cadence levels. I really wish they would release the app that lets you adjust slope like the old days, although my kickr currently is matching well with my vectors..stages read about 5w higher, but then I'm left leg dominate too.
#3248
Bikes: Yes
Quoted: 9 Post(s)
I thought he might have been referring to his unfamiliarity with erg mode but that doesn't negate the need to get it working right first.
#3249
Quoted: 163 Post(s)
Liked 5 Times
I think it was the firmware update that really solved my issue, not necessarily the spindown. But if you get bogged down, if you come to a complete stop before re-starting, the brake will release and you can get going again. I had the same issue with computrainers in a class I used to take.
#3250
Quoted: 10 Post(s)
Liked 8 Times
Thanks all for feedback. I've done multiple calibration spindowns with identical results. One thing I haven't done is check for firmware update. Will do that and report back!
