Totally Tubular
#2526
Quoted: 4806 Post(s)
Liked 3,933 Times
Thank you kindly for the tips.
Start with a stand! beats fumbling like I do. Hell, and old fork set in a bucket of sand would work.
I did watch the YouTube videos and did the 2 day process. but, instead of ruining a quality paint brush, and it was too late to hit dollar tree for sponge brushes, I placed a rubber glove on my hand and basically finger painted.
Excess on the rim wasn't an issue, a dab of paint remover took it off. The tire, even though mostly inflated was a different scenario. It got sloppy.
I will take your words to heed and start properly prepared.
And trick - unless you just pulled this tire off its stretching rim, re-mount it onto a dry rim. NOw you know how tightit is and how hard you should pull.
#2527
Quoted: 2588 Post(s)
Liked 4,826 Times
All done, no muss, no fuss. For posterity, I took some pics:
DD
DD
Likes For Drillium Dude:
#2528
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
I hope you left a small untaped section directly across from the valve. I makes removal much easier.
Likes For CV-6:
#2529
Liked 4,826 Times
Nope, not this time. But I did order a pair of blue-anodized valve caps, and they'll be joined by a set of blue-anodized chainring bolts, because this bike needed just a smidgen more bling
DD
DD
#2531
Liked 4,826 Times
The Jantex tape has a plastic backing film, but it is also somewhat flimsy. Once, while removing when I had the tires up to 100psi or more, it tore. Had to wrestle the tire off in the area of the tear (which wasn't easy, even though I'd only taped it on minutes before) to retrieve the torn end, then slowly pulled, with greatly reduced tire pressure, the remainder out. Was a bit of a challenge getting the tire perfectly straight in that section, but I got close enough.
Now, I only put in about 30psi, to get the tire into shape, and to aid in the seating process. I pull one tab of backing film a couple feet, then do the same with the other, alternating until one meets the other. By the time you remove the film, you will have aligned your tires as best as possible, so when it's all out, pump the tire up to the desired pressure, let sit 24 hours.
That's always worked for me. I'll know around noon tomorrow if I got it right again.
DD
#2532
Quoted: 4513 Post(s)
Liked 6,392 Times
This is good news - in particular, the praises sung regarding the ribbed portion of the tread. Hand on heart, I was never a fan of the look, particularly the straight-up Corsas with grooves across the entire width. But this one, with the herringbone tread edges, is a nice mixture of the two. The channels have me wondering if they'll be magnets for little pieces to get stuck in, so at the conclusion of each ride I'll religiously look closely at this feature. Hearing your experience with the tread has me looking forward to the ride, and I'm going to run without sealant until the same happens to me, then give it a go since you've proved that to be an option. Plus, I have a free spare to pop on in any case
But, really, the main takeaway in handling/mounting them was that they are very well-made, and although they don't seem to weigh all that much, they feel substantial. Does that make sense?
DD
DD
Yes, quality, robustness, etc can always be felt to some degree, especially when you have been around as long as we have.
So many things now days come out of a trusted box or package only to find they have mucked up the mix, your heart sinks and you instantly know another reliable, long trusted and revered product will never be the same.
Likes For BFisher:
#2534
Quoted: 2339 Post(s)
Liked 2,832 Times
Thanks!
DD
DD
and for others i know a lot that ther are many that like the effroto (sic) tape... same question
thx
#2535
Liked 4,826 Times
My experience pulling flats off is limited to the two Gommitalia tires I removed a couple weeks ago, after the rear blew out - and I decided to find some modern, new stuff. Both tires came off easily enough once I deflated them most of the way; in my case, the rim tape remained on the rim, so I just had to peel it off once the tires were removed.
DD
DD
#2536
“Senior” Member
In my experience whatever glue protocol you follow as to how many coats and drying time, the key to not having a sloppy mess is to make sure the glue on the tire has cured for good while (think 30-60 mins) before you install on a rim with just applied fresh glue.
i generally use two coats of glue on the rim and one on the tire. When I used to use more, excess glue tended to squirm out and discolor the gum walls.
#2537
Quoted: 591 Post(s)
Liked 663 Times
what is your experience with pull a flat off with tape. First tubulars I did were the inexpensive tufo and use tufo tape..... when I went to pull the tire off a lot of it came off with the tape. so I have being gluing since (vitorria glue)
thx
thx
I use Miyata rim tape. My first experience left the tape on the rim. And it was difficult to remove the tire. Second left some on rim, some on tire. Mounted spare and rode home at a slightly lower pace. I now carry a piece of plastic with new tape wrapped on it and a knife to cut it. I leave a segment of rim directly opposite the valve hole untaped. Makes removal a bit easier.
#2538
Bikes: Waterford W-13, Ritchey road logic; Ritchey SwissCross; Pinarello Paris ; Surly Karate Monkey monstergravel hauler 1983 Mike Mullet, mid 80s Alpina, late 70s schwinn world sport tourer
Quoted: 19 Post(s)
Liked 33 Times
good day fella's: love the thread on tubulars!! I for one have been loving the recent revival for me of my love of tubulars as everyone is jumping on the tubeless train and forsaking their tubulars and selling them like they are junk, which we all know they are quality tyres. Nonetheless, they are all over and very reasonable prices given the quality, and the argument that tubies are so messy..doesn't wash when your on the roadside fixing a tubeless mess of a flat.
Nonetheless gentleman, my question is i use a 1 inch paint brush when regluing tyres and hate throwing the brush away after use, do any of your reuse your brushes and if so what do you do to preserve them?? soaking in mineral spirits or what?? I am not sure what to do but would love to hear advice
thanks!!
thanks!!
Likes For mosinglespeeder:
#2539
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4339 Post(s)
Liked 2,982 Times
thanks!!
thanks!!
The mineral spirits to preserve them probably costs more than they're worth, even if it worked.
Before brushes I used the "baggie on finger" method... didn't try to preserve the baggies either.
I also have a syringe thing that works great for filling in gaps.
Likes For DiabloScott:
#2540
Liked 3,933 Times
I've been using toilet paper cardboard tubes that distort nicely to the rim radius. (Or a little more radius so the glue squeezes toward the edges where I really want it. Clean, no cleanup and reusable. Now, that acid brush approach looks attractive. Better control of amounts and thicknesses.
DiabloScott, can that syringe be used later for additional tires? And if so, how do you store it and keep it working? Any neat tricks?
Likes For 79pmooney:
#2541
It's MY mountain
Liked 2,982 Times
It came with a bunch of different "needles" - they sell these things to crafters who glue rhinestones onto shirts and stuff.
#2542
Quoted: 19 Post(s)
Liked 33 Times
I like using these acid brushes - they're too cheap to bother trying to re-use... $10 for probably a lifetime supply.
#2543
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
I purchase acid brushes at Harbor Freight.
Dean
Dean
Roll Me Up and Smoke Me When I Die
Likes For Dean51:
#2544
Quoted: 1952 Post(s)
Liked 2,014 Times
I use acetone to lean those cheap flux brushes well enough to reuse.
#2545
“Senior” Member
As someone said earlier, using your index finger in a baggie works best—more specifically: in a finger sock cut from a latex glove’s fingers (each glove provides multiple uses) works super simple with no muss at all.
Gluing can be mess free, unless you spread glue too thick or all over.
Likes For obuckler:
#2546
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1087 Post(s)
Liked 1,825 Times
I came across a trove of these tires.
They had them in a $15 close out bin. But, are they any good?
"Leave the gun. Take the Colnagos."
Likes For Robvolz:
#2547
Bikes: many
Quoted: 1448 Post(s)
Liked 1,396 Times
^^^^ Kinda skinny, but should work well as spares, if nothing else. Any hint of a copyright date on the packaging to estimate age?
#2548
Quoted: 1609 Post(s)
Liked 2,216 Times
^^^^^^^^ What is the TPI?
#2549
Bikes: 1985 Roberts SLX, Mercian 531, 1984 Torpado SLX,1981/82 Peugeot PSV-10, 1978 Charlie Roberts full touring, 1970 Charlie Roberts 531 road.
Quoted: 79 Post(s)
Liked 165 Times
A couple of questions on tubulars. Got a nice set of tubulars wheels from eBay.Fr, and purchased some of the Kendra Veloflex tubs, 28’s. Riding the other day, 94 lbs in rear tire, and 4 miles from home, ka pow, and the rear tire blew out. Had Effetto sealant, too large a puncture, though. Bad luck, too much pressure, or what. Could I use the Vittoria universal sealant, supposed to do 7mm holes, and fix it?
Likes For santa fe 2926:
#2550
It's MY mountain
Liked 2,982 Times
Certainly not caused by too much pressure. Possibly some torn threads in the casing - or brittle threads if it's an old tire.
So you've probably got a pretty good gash in the rubber, and a pretty big rupture in the tube.
Probability of fixing this with sealant I'd put at about 1%.
