Best Center-pull Brakes?
#51
Randomhead
Liked 3,701 Times
I wish we had realized BITD that the only thing you needed to keep a MAFAC from squealing was a small round file. I have some Racers on my main road bike and they work great. Need to tweak the toe in a little, they squeal occasionally if they havent' been used recently
#52
Quoted: 206 Post(s)
Liked 102 Times
Well, I hit one of the local shops that usually has a good supply of used parts. I was looking for a cruiser saddle for an old bike I’m fixing up. I found a bunch of Mafac Racers in their brake box as well as a a decent sten in a size I like and a seatpost. Got the mess for $30. I’ll clean up the brakes and maybe try them out when I upgrade the pads. And the more I think about it, since I ride mostly on the hoods, maybe the lever design will help with my braking technique.
Some days, it's not even worth gnawing through the restraints.
#53
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,614 Times
I recently built a bike with 40-year old CLB GL side-pull brakes, and they are so good - even with the original pads - that suddenly the development of dual-pivot brakes seemed a waste of effort.
#54
Quoted: 7353 Post(s)
Liked 2,481 Times
I would call it food for thought. I'm glad dual pivots are here and available to everyone. Maybe it wasn't necessary to invent them, and maybe it was, but I'm glad they're here. Most single pivots are not as good. And why do you think these are so good? I'm guessing your hands are larger and stronger than the average hands, so bear that in mind for the average person.
#55
Shifting is fun!
Bikes: Yes, please.
Liked 4,614 Times
And as to why they work so well, the one thing I've noticed is that they seem to flex less than the other side-pull calipers I've used.
The point I was really trying to make, though, is if bicycle brakes were already this good in 1980 (or 1952 for that matter, when MAFAC introduced the RACER), shouldn't we spend our resources on more important things? Just a thought.
#56
Quoted: 767 Post(s)
Liked 1,898 Times
I had MAFAC Racers on my old Peugeot and prefer them to Weinmann and Universal, although the latter two can certainly be set up to provide fine braking. I was able to brake very easily from the half hoods with the MAFACS. I ran them with Kool Stop replacement pads and used thin brass sheet to shim them for toe-in. Worked great.
#57
Liked 2,481 Times
The MAFAC RACER is nearly perfect. I know very well how to set it up, but it's easier to do it wrong, and then it doesn't work well. Dual pivots are easy to set right. So it's not a waste that they were invented.
So maybe those CLBs are made of a good, stiff alloy.
#58
Quoted: 1830 Post(s)
Liked 3,383 Times
Much better!
My personal opinion is that the Weinmann centerpulls are just fine and stop better than the Campy Record sidepulls. I'm very much accustomed to vintage brakes and don't have problems braking from the hoods or whatever, so I'm sure I have different preferences from someone acclimated to a more modern brake.
Get those Weinmanns cleaned and lubed and let us know how it works out!
Steve in Peoria
(also... the Weinmanns polish up wonderfully!)
#59
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
That's kinda how I see it. I don't remember any stories from our heroes BITD whining about brakes, so I guess they were good enough. Weinmanns, and other decent vintage brakes, are certainly good enough for me.
#60
Quoted: 1952 Post(s)
Liked 2,013 Times
My buddy talked me into a UO-8 in 1974 because he had one. Mafac Racers were apparently an improvement over the Weinmanns on my trade in 10 speed. But there was some controversy because my buddies dad had Campy sidepulls which he insisted were better--something about Eddie Merckx?
#61
I suspect some of the preference for one vs the other has to do with the levers. I prefer the MAFAC levers to Weinmann, but that's only because they fit my hands better. That's probably why for many years my preference was for MAFAC. Swap out the levers, and I like Weinmanns just as much, though they both have pros and cons. I'd still give the edge to MAFAC for brute power.
MAFAC used to advertise that the brakes were strong enough to be used from the hoods. I forget exactly how they put it, two fingers are all that's required, or something like that. Certainly they can be used that way on reasonably flat terrain for more casual braking. Kind of depends on the terrain. I've lived in extremely hilly areas most of my life.
To me, well set up MAFACs to me feel a lot like dual pivots. In fact when dual pivots first came out, and I went on the first test ride with them, my very first impression was that they felt just like MAFAC, what's the big deal? In a way, they were rearranged center pulls, marketed as something new and not old fashioned.
#62
Quoted: 767 Post(s)
Liked 1,898 Times
#63
Bikes: 1970s Alex Singer, 1960s Peugeot PX 10, 1960s Bertin C37, 1973 Carre Bertin C 37, 1972 Carlton Kermesse, 1981 Peugeot PX 14 Super Competition
Quoted: 346 Post(s)
Liked 266 Times
Salamandrine-
Is this what you were thinking of?
#64
Quoted: 346 Post(s)
Liked 266 Times
For those interested in Mafacs and other centerpulls, check this Flickr site:
https://www.flickr.com/photos/mafac_...57676387624323
#65
Liked 2,481 Times
Nice pictures. Thanks, @bertinjim.
#66
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
I haven’t read this whole thread, but I once built a bike with aero levers and centerpull brakes - very similar to what the OP showed, but with Racer calipers - and the lever pull was all wrong for the calipers. The lever would pull almost to the bar before the calipers would apply enough clamping force to brake. If that is the OP’s situation, then there is nothing that can be done besides getting the rim very true, adjusting the pads very close to the rim, shortening the straddle cable if possible, and then just living with it. Or, get different levers.
#67
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
A shorter straddle cable will usually increase the leverage, but at the expense of pad travel.
The Mafac levers seem in a class by themself in terms of great lever travel and cable travel.
#68
Quoted: 392 Post(s)
Liked 49 Times
I can’t remember all the tricks discussed here but something should help - I know the OP doesn’t have Racers but there’s similarity.
https://www.bikeforums.net/classic-v...fac-racer.html
#69
Liked 2,481 Times
@dddd is right. If the lever reaches the handlebar before much force is on the rims, lengthen the straddle cable to decrease leverage.
#70
Quoted: 206 Post(s)
Liked 102 Times
Here’s my latest plan for experimenting with the brakes on my International. Since this is not going to be a restoration, I feel I have the freedom to experiment a bit. I picked up a set of Mafac Racer brakes and a pair of Cane Creek levers that feel like they will give me a better leverage advantage. Fortunately, I’ve only got $25 into the brakes and levers. Now, I just need to get the Kool Stop pads. The only downside to all this tinkering is that I have to remove the bar tape every time I make a change.
#71
Yeah it is! Thanks for digging this up. Sorry I missed this post earlier.
"One digit suffices!"
One finger is enough is possibly a little optimistic, at least for the very hilly places. Certainly enough for just riding around.
#73
I’ve been riding my ‘74 Raleigh International a lot lately, and I’m feeling that the weak spot on the bike is the brakes. The center-pulls are not nearly as effective as the D-A side-pull brakes on my Ironman or the canti brakes on my gravel bike. Are there any classic center-pulls out there that are more effective than the Weinmann’s that came on the International? I’d really like to not have to change the style of brakes on this old bike.
MAFAC Racers were the worst bakes I ever used. I bought them new. I had them on for a week, then took them off and threw them away.
In both cases, I believe the relative thinness and long length of the brake arms leaves them too flexible.
Dura Ace and Campagnolo solved all my brake problems. Get some of those.
#74
Quoted: 3811 Post(s)
Liked 6,717 Times
I have a couple of sets of these 1980s Weinmann center pulls. The steel straddle takes care of the extra slop issue, but unfortunately reach is on the short side. They do work very well.
Likes For nlerner:
