Cadence - When do you Lug?
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
Two things:
1. It shouldn't surprise you that I've actually done the calculations. No matter what gear you're in, if you drop your cadence (which, of course, drops your speed) your pedal force will decrease. But that's a small effect; you're right that the main effect is in terms of gearing.
2. My main point was that cadence matters little; the main point was that instead of thinking about this as a cadence problem, think of this as a pedal force (or crank torque) problem. Right now, unless you're sitting at one of those cycling desks, your legs probably have cadence = 0. Do your legs hurt? If not, it's not the cadence, it's the pedal force (or crank torque).
By the same token, if you could maintain 80 rpm on a steep hill in that same gear, the pedal force (or crank torque) wouldn't be any lower (in fact, it would be slightly higher). Pedal force is pretty much insensitive to cadence under those conditions, so even if you could pedal faster the pedal force wouldn't decrease.
Likes For RChung:
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
I can't see how you expect other people to know how well you will cope with pushing a larger than optimal gear for extended periods of time?
Personally I know I can cope with grinding up a hill for maybe 15 or 20 minutes. But for long climbs like you are looking at ( 30 min plus) if I don't have a low enough gear it starts to get ugly.
Maybe you will manage, or not. There is one way to find out
You made a very clear statement regarding what happens to you in low cadence situations. I am curious as to what that point is for you.
Dave
Quoted: 452 Post(s)
Liked 162 Times
Two things:
I could have asked 'how many newtons of force can you apply long term to your pedals before you fatigue excessively in long climb', but probably would not have gotten a useful response :-)
dave
Quoted: 1858 Post(s)
Liked 664 Times
In principle I will be taking on some long and steep climbs in a couple of months. And the question of gearing is still on my mind.
In my case it seems to me that, assuming that I am putting out power somewhere in the range of my ftp, that a cadence down in the 70 to 75 range is where things start to become inefficient. I think that I could pedal at 80 rpm or 95 rpm (at around my ftp) without making a huge change in physiological effort. But somewhere in the 70 to 75 rpm range and (at the same power output) I will find that the time that I can spend at roughly ftp is going to go down. And things go downhill (as in harder to maintain) pretty quickly in a very small rpm range. E.G., there seems to be a huge difference between 67 and 72 rpm.
What have others found about this in their riding. I am just curious. A new RD (or not) for my bike is driving this question.
Thanks.
dave
ps. It is a difficult experiment to run in my case because I just don't have any climbs that are long enough to test this (everything around here is up and down constantly, so constant power/rpm is not something that I can achieve on our roads).
dave
Thanks.
dave
dave
I've found lower gears do help me maintain uphills for longer time with more comfort - not being so close to the edge.
Exactly how much lower I need is a matter of trial and error. Sometimes it's easy to re-equip the bike, and sometimes it's not.
just another gosling
Quoted: 3890 Post(s)
Liked 1,939 Times
Two things:
Higher cadence in the same gear increases pedal force due to wind resistance, which in Dave and my case, it probably insignificant - as you say, a small effect. Are there other increased resistances I'm not thinking of?
The reason to use a lower gear is to pedal higher cadence and get almost the same power as using a higher gear at the same speed. Power in a lower gear will, for us duffers out here, usually be a little lower due to metabolic effects, i.e. higher oxygen cost from wiggling the legs more. I'm using "oxygen cost" as shorthand, because that's easy to feel, doesn't require instrumentation. Offsetting that slightly lower power is the increased endurance over a long day due to lower pedal force = decreased glycogen cost. The balance between oxygen and glycogen is individual and can only be assessed through individual experience. That balance will always be slightly different for each course and length, which really complicates the issue. Just trying to simply things by recognizing their complexity.
Results matter
Results matter
Quoted: 452 Post(s)
Liked 162 Times
Dave, are you saying you would like to try pedaling on your uphills in 85 to 95 rpm range? If so, plan to reduce you deepest granny by a factor about 20% and see what happens. If you don't sell the old parts you can always change it back if you don't like it. You may or may not actually maintain ftp, but you will pedal faster going up the hills. Faster cadence may require some acclimation.
dave
Quoted: 452 Post(s)
Liked 162 Times
Butting in again . . . Actually, my legs do hurt sitting at my desk, but that's a good thing. At my age, if my legs don't hurt, I'm doing it wrong.
Next I guess would be drive train efficiency which is (again I am guessing here) probably a function of applied power. RChung probably has a good handle on that.
dave
Quoted: 1067 Post(s)
Liked 259 Times
In my area the climbs don't get any bigger that cat 3 or 4. Those I can get up ok with almost any gearing.
The few times that I have done a HORS category climb I found that having the right gearing was critical if you want to get up it well.
Basically climbing a mountain is a lot different to climbing a hill.
So if you just want to have a crack at this ride and see how it goes take your bike and gearing as is.
If you want to prepare and do what you can to get the best result. Gear it down.
Liked 1,939 Times
The next opposing force 'factor on the list' would be rolling resistance. And rolling resistance looks much like gravity in that it is pretty constant WRT speed.
dave
dave
Results matter
Results matter
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
It seems to me that cadence is very individually specific. I'm old and heavy and reasonably fit with low power to weight ratio. Nevertheless over the course of the past five years despite getting fitter but losing power my cadence remains the same until I run out of gears to maintain what I would normally do. On the flats for workout cruising is around 95 and if pushing it at a constant pace about 105 average. On climbs of significance to me, my optimal cadence whether going max or just working hard is about 86 on average. All that changes at 86 is my gearing depending on how much power at a given point that I need or my legs are capable of providing depending on freshness or fatigue level.
IMO weight is very important but increasing your maximum or FTP level of power produces better performance in endurance and speed up climbs than dropping weight. Naturally, if you can do both that's best!
Quoted: 1975 Post(s)
Liked 232 Times
I am also convinced that force (too much of it) is the important parameter here. But, even though force is the fundamental measurement being made by my power pedals, that number is not reported to me. But I can see power and cadence and can imply a relative force from those numbers. So power and cadence is how I look at this.
dave
dave
That would imply two different speeds, not two different power outputs. Power is essentially force*cadence, so if force and cadence are the same, power is the same.
Quoted: 452 Post(s)
Liked 162 Times
dave
ps. I have Garmin Vector pedals measuring power, and the ONLY data that they have is cadence and force (and crank length plus a sensor angle to deduce torque, but these are fixed values for a given installation).
Liked 232 Times
The one case that I can think of where the same pedal force and cadence would result in a different power, is when a portion of the pedal force is not inline with the pedal motion. I don't know if that was redlude's point or not.
dave
dave
Was trying to answer this question
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Last Sunday I was on a steep climb, in hot weather, really suffering. I thought I was in my lowest gear (34x28) but was actually in the next-to-lowest one (34x24). I actually had made the difficult decision to quit, after fighting with myself for the past 10 minutes. I could not go any further and complete the loop I had planned.
Just before my pulling foot out of the pedal, to stop and turn around, I saw my mistake and shifted into the 28. That one extra gear allowed me to continue and finish the ride. Without it, I would have had no choice but to quit. To me that's huge, compared to the loss of one gear somewhere else on the cluster.
I have never gotten back from a ride and thought, "Boy that low gear I had, but never used sure slowed me down." Much more often it's "If I only had a lower gear." Difficult to tell yourself that while sitting in a comfy chair at home, it's much easier to scoff and say, "Meh ... I'll never actually need THAT low of a gear."
This thread got me thinking. I've got quite a few good hill climbs on my daily rides. Anywhere from 1-5 miles going up around 800 to 1200' of vertical gain.
I'm a bigger guy for a cyclist in the 185lb range. Good legs and built like a sprinter. I am usually out of the saddle at the top of climbs pulling and pushing on pedals to sprint up over to the descent.
My cadence on steady climbs is usually 70-75rpm. I try to keep it above 70 anything below 60 is mashing and ineffective.
Reading through this thread has me thinking. I should go back through my Strava segments and see what gear I would have to be in at 90 rpm on these climbs to keep the same speed as I did at 70rpm on previous attempts and see if it is harder or easier for me with the higher cadence.
This will be interesting.
-Sean
-Sean
Quoted: 1814 Post(s)
Liked 923 Times
Maybe some folks don't have much in the way of hills, but theorizing about your ideal cadence is pointless
when the grade is much above 10%. Unless you are cat 1, you're not going to be much over 5 mph, and even with 1:1 gears
that means around 60 rpm. Different with a mountain bike, but we're talking road here.
Quoted: 741 Post(s)
Liked 412 Times
This is very true. Your cadence will be what it will be based so many factors. How much riding you have done that week. The kind of riding you have been doing previously to the climb. Of course there are more variables, but I hopefully made my point clear. I think it is always good to have a gear a few teeth lower than you think you will need just in case.
Quoted: 452 Post(s)
Liked 162 Times
Your optimal cadence is certainly an interesting discussion and this thread is as good a place as any for that.
But for the record, that is NOT the issue that I raised when I started this thread. For me I would guess that, for a long and steady (and hard) effort, somewhere around 95 rpm would be my ideal cadence. But if I were limited to 85 I don't think it would matter much. My sense of thing is that at some point as RPM drops your ability to put out the same power for the same period of time falls dramatically. That was my question, but no reason not to talk about the other side of the curve as well.
dave
Liked 923 Times
After overcoming the embarrassment, I've come to really like the 34/48, 11/34 gearing that I often ride currently.
The gaps on the small end of the cassette are not that different, so the penalty in a fast group is not much,
but much more time is spent in the big ring overall w/ few double shifts.
Interestingly, 1:1 gearing makes figuring speed easy- 7' circumference wheel= 754 revolutions per mile so, for example, 60rpm= 12.6 minutes= 4.76mph
and 85rpm= 6.76mph which for me would be 7%- 12% grades, although I would probably shift to stay below 85 rpm.
I hardly ever see an average cadence of as high as 90 on Strava, 'tho I imagine it happens more where it very flat,
which suggests that above that is not the fastest/most efficient/etc. in practice.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
A cadence of 90 is a rough average for flat time trials or flat road races, but for mountain stages, the average is closer to 70.
Here's a decent article about "optimal cadence", with references.
Quoted: 452 Post(s)
Liked 162 Times
I haven't seen many riders doing climbs at 95 cadence.
I came to that conclusion (for me) based on an observation of what I do when I am riding indoors on a spin bike (with power pedals) trying to ride for 15 to 30'ish minutes at 95% to 105% of my ftp. On a spin bike you kind of have infinite gears and when I do those rides I tend to gravitate toward 95 or so rpm.
But that is hardly a scientific analysis. Even though Froome and Armstrong climbed at high cadence, I believe that Quintana is more of a 75 RPM guy.
Of course I was not looking for the optimum cadence, but looking for the cadence (when pedaling in the vicinity of your ftp) that things kind of fall apart.
dave
Liked 923 Times
That would be Lance/Froome country - which doesn't exactly make it right for me (even if I had the gearing and/or strength to pull it off).
dave
dave
Well really you have one gear & variable resistance. Crank that thing down another 5 or 10 turns, and something will fall apart.
Now for an interlude- quote from "The Hardmen":
"Lance Armstrong said, 'Pain is temporary, quitting lasts forever', proving that even *******s can be insightful."
