Bianchi Serial Number Identification
#1351
Prince of the Royal City
Mystery frame update
Here is the bike built up with AME hoods and reproduced Maruishi decals.
Driver side
Left side with 3/4 close up of front
Driver side
#1353
Quoted: 4722 Post(s)
Liked 3,038 Times
#1354
SW4121318 serial number that could not be reached.
#1356
Liked 3,038 Times
I do not recognize that as a a known (to me) Bianchi serial number format. There are several ways in which it could be reverse engineered, with the most likely being a 1975, 1985 or 1995 model being manufactured in late 1974, 1984 or 1994. Photographs may aid in the identification, though that may be complicated if you are not located in North America, as most members are American based and Bianchi models and sources often varied by region. Ignore the forum warnings that you cannot post photographs until you have reached 10 posts. The photographs will be deposited in gallery album where members can view them.
#1357
Bikes: Steyr Waffenrad ('52, '62, '71, '72, '74), Cannondale (Saeco CAAD4, Criterium), Bianchi (Martini Racing mtb, RC SBX "weird"), Burco (transport, speciaal opa)
Quoted: 17 Post(s)
Liked 19 Times
Hi, I am trying to identify an old Bianchi with Ishiwata Magny tubing. Reading elsewhere on the forum indicates "that it was contract manufactured in Japan but it's not the top Japanese model, the Limited. which used CrMo tubing. However, it's also not the bottom of the line model, the Standard, with hi-tensile tubing." Serial number is BS588389. Says B3 under the bottom bracket - I would guess this is a part number? Can we date the bike - early 80's but which year? Also can we identify the factory of manufacture? Thanks!
1980's Bianchi
1980's Bianchi
#1358
Liked 3,038 Times
Likes For T-Mar:
#1359
Thank you for reply. There is another code which I have misseen. P5161865 ( P could be 8 , not sure)
I couldn't find a way to upload the photos, I will check again.
#1360
Liked 3,038 Times
#1361
Identification Help
Hi folks!
I could use some help in identifying what year/make my Bianchi is. It was given to me years ago but I don’t have much info about it (I’ve tried searching for its serial number). Some info below.
S/N: BS353816
Decals: Piaggio, Bianchi, and Eduardo Bianchi (blue and gold)
Frame: white
I imagine it’s Japanese because most of its parts are?
Thanks in advance!
S/N: BS353816
Frame: white
Thanks in advance!
#1362
Liked 3,038 Times
Hi folks!
S/N: BS353816
Frame: white
Thanks in advance!
S/N: BS353816
Frame: white
Thanks in advance!
#1363
Bikes: Specialized Sirrus Comp
Hello, I started a thread asking about bianchi serial number not knowing this one existed...
From my post:
I recently scooped up at Bianchi frame with carbon fork and mavic cxp33 rims. The frame is generally in bad condition, paint stripped off completely with no decals. I hope to restore this as a project, but really have no idea what the model or the manufacture year is. Was hoping to get the information so I can start looking up the correct color way and parts... I plan to powder coat it and add the decals from the correct time period.
This is the Serial no.: WBK2567627 I found on the frame.
Any and all help is much appreciated :-)
From my post:
#1364
Liked 3,038 Times
From my post:
From my post:
Likes For T-Mar:
#1366
Need help with vintage Bianchi.
Sorry to jump into this thread, but am new to this. I have a vintage early to mid 80s Celeste Bianchi that I’m trying to identify. Serial number is 59 D-266. I know the 59 is the frame size. Thanks.
#1367
Liked 3,038 Times
Likes For T-Mar:
#1368
Liked 3,038 Times
The seial number, as reported, is atypical for Bianchi. There should be another number associated with the 'D'. Typically, it would precede the 'D', but Bianch QC left something to be desired, so it be after the 'D'. Offhand, i don't think it's early 1980s as most members miss the serial numbers from this period, which are located on both sides of the seat lug. Also, you mention the frame size stamps, suggesting, the numbers are on the BB shell, which would push into the late 1980s.
#1369
[QUOTE=T-Mar;21605924]The seial number, as reported, is atypical for Bianchi. There should be another number associated with the 'D'. Typically, it would precede the 'D', but Bianch QC left something to be desired, so it be after the 'D'. Offhand, i don't think it's early 1980s as most members miss the serial numbers from this period, which are located on both sides of the seat lug. Also, you mention the frame size stamps, suggesting, the numbers are on the BB shell, which would push into the late 1980s.[/QUOTE
Thanks for the feedback. One with the same frame and serial number format just showed up on eBay. I’ve been looking for 3 years and one shows up a couple days ago. Serial number under the bottom bracket is 59 (Drive side) and D.297 (opposite side). Listed as an 80s Specialissima Mondale Reparto Course. Not sure what the difference is between the D.297 and mine that is D.266. I have seen other 80s Specialissima Bianchis with the same serial numbers format, but with a C rather than D. So, can I assume the eBay posting is correct. I’ll post pictures as soon a I have enough posts.
#1370
I would post a current photo, but unfortunately am not able to add attachments yet...
Appreciate the help :-)
#1371
Bianchi model and year request
purchased used Bianchi last year
under the crank, it has two sets of identifications:
WBK749846H
NX2748644H
Made in Tawain sticker
Gear shifts are in the brake levers
Derailers Shimono Tiagra
WBK749846H
NX2748644H
#1372
Liked 3,038 Times
Welcome to the forums. Assuming the Tiagra is OEM, it should be from 2013. The USA model equipped with Tiagra in 2013 was the Imola but yours is a Danish market model and have a different name.
#1373
Bikes: couple
Can any Bianchi expert help? I am trying to establish what brakes the Bianchi Folgorissima came with? When the bike was renamed the Paris Roubaix they were the Universal Mod 50. I believe the Folgorissima also had Universal Mod 50, but these brakes did not come out until 1950. The Folgorissima was produced for one year spanning 1949/1950. Does that mean they had early release of the Mod 50 brakes or was the first bikes fitted with the Universal Mod 39?
My gut says the Folgorissima came initially with the Mod 39 and then then Mod 50 - but does anyone know?
Thanks in advance
Clive
Thanks in advance
Clive
#1374
Liked 3,038 Times
Thanks in advance
Clive
Thanks in advance
Clive
#1375
Bikes: couple
My thanks appreciate the information. Could not find the one on ebay you mentioned as would have been worth checking. I notice the one with appears on web searches all the time has Mod 50. Quick question if I may, was the 1949 Bianchi team on Folgorissima or the predecessors to this frame? I thought the team road the Folgorissima in the 1950. If they also used in 1940 that certainly confirms the bike came with both Mod 39 and then Mod 50. Thanks for you help so far and for anything further you can provide.
