Show Your Vintage MTB Drop Bar Conversions
#1152
Carpe Velo
Bikes: 2000 Bianchi Veloce, '88 Schwinn Prologue, '90 Bianchi Volpe,'94 Yokota Grizzly Peak, Yokota Enterprise, '16 Diamondback Haanjo, '91 Bianchi Boardwalk, Ellsworth cruiser
Liked 14 Times
I picked up a frame for $10 the other day with a stem like that. Not a short one, though. Have no use for the frame (a decent mixte style cross frame) but there were certainly more that $10 of decent parts including the stem
#1153
probably I am the only one clueless enough to try one of these but just in case: it didnt fit on my high sierra, ie was too thick and didnt leave enough threads for the headset nutz
#1154
Bikes: Spec 2013 Carve Comp, Spec 2011 Allez Sport, 1991 Trek Antelope drop-bar conversion, 1 X 7 commuter frankenbike
Quoted: 41 Post(s)
Subscribing. A project like this is calling my name.
#1155
Bikes: Specialized Sequoia Elite/Motobecane Fantom Cross Team Ti/'85 Trek 520
THat one is normally for threadless headsets. You can tighten it down so that it holds the preload on the bearings if you decide to loosen the stem to adjust or replace it. I have the same one on my Motobecane Fantom corss bike. I wonder if it would work fine on a threaded headset without damaging anything?
#1156
Goes to 11.
Bikes: 2015 Soma Double Cross
#1157
Bikes: many
Quoted: 18 Post(s)
Liked 16 Times
#1159
Chainstay Brake Mafia
Quoted: 16 Post(s)
Liked 11 Times
yep.. the stem on my univega has a removable roller cable guide, so i removed it and switched to a fork mounted hanger. that way i could adjust the height easily, which is important when first setting up a drop bar conversion
#1160
#1161
Bikes: Surly Cross-Check, 1983 Specialized Stumpjumper
My first post on BF is a long long time. I found this thread after picking up a 1983 Specialized Stumpjumer on CL. It is not the Sport, but the top notch model (not sure what it's called) has Shimano drop outs and Tange fork ends. Bunch on lugged goodness. Considering taking the Nitto Noodles from my Surly and putting them on it. The top tube and seat tube and almost exactly the same size as my 56cm Cross-Check, which makes it a pretty big MTB frame. I have a dirt drop stem I could use. I am concerned about fitment because the the angles etc are so different. Might just give it a try and see how it turns out. I also have a set of Albatross bars I can use on it. Trying to decide what to go with.
A few bikes (not mine) I may model this build after:
#1164
Thrifty Bill
Quoted: 1236 Post(s)
Liked 965 Times
+1 sounds like a great project to me. Have fun with it!!
#1165
Liked 10 Times
Nice score SeanBonham, early Stumpjumpers make great dirt drop bikes! If I was in your situation, I'd go with the dirt drop stem and flip the Albatross bars. I'm running a similar set up with flipped Albatross bars and a Nitto Technomic stem. I went with the Technomic to push the bars a bit more forward, I could get the same height needed but the dirt drop stem wasn't quite long enough. The Noodle bar is nice but the Albatross bar will give you just as many hand positions but at different heights (which is a big bonus to me).
Really cool build, I'm looking forward to see how it evolves, keep us posted with progress pictures!
Thanks!
-D-
Thanks!
-D-
#1167
Liked 5 Times
Thanks!
-D-
Thanks!
-D-
#1169
The Rabbi
Quoted: 16 Post(s)
I've run Northroad/Albatross bars for years, they're pretty competent in just about any scenario. You'll just do what comes natural to you. For the Northroads (the ones I've used the most), I usually chop about an inch off the ends. Descending, I tend to ride butt off the saddle over the back wheel, finger tips on the brake lever ends. Climbing I'm usually either holding on the ends (no brakes necessary), on the hoods or perched in the center of the bar by the stem. Cruising along, you have any number of positions to choose from, I've found there is about 4-5 total positions to choose from.
#1170
Quoted: 939 Post(s)
Liked 2,968 Times
Update - over the last few weeks I've slowly serviced all the components on the Ross Mt. Ranier, and decided to revert to the original Suntour bear traps with the Christophe half-clips I put on 'em when it was new - I had been running a pair of well-worn Campy black road pedals. I figure that for a local errand bike it'd be easier to jump on without changing shoes. Here's how it sat before a brief trip to Trader Joe's:
Blackburn rack and Mt. Zefal. The saddle is a pleather-topped plastique Regal with fake copper rivets and rails that is certain to be swapped out - next candidate is my old Brooks Team Pro, but I suspect I'll be fiddling with saddle options for a while.
The 1.5" Kenda 809 skinwalls look great and rode nicely. Here's the front end for all you rollercam fans:
I'm going to re-cable the brakes, I made the housings too short. I may decide to switch from black eventually, would like to know what y'all think of the blue bar tape and black housing. For me, the housing works well against the black saddle, hoods and pump.
Payload retrieved and delivered.
So overall impression is, the bike handles differently in a good way than I recall from the straight bar days, which was a surprise to me. It feels solid but not heavy and has a noticeable but not overly strong self-centering balance. Rides no-hands easily and likes to swoop through turns. I'm pretty happy. Over time the saddle will change and I'll be figuring what I want to do about racks, bags, fenders etc. In a few years I hope to be living in Manhattan, and this guy should be getting around town a lot.
#1171
rain dog
Quoted: 17 Post(s)
Liked 8 Times
#1172
That Ross is very well done. At first glance, it looks like a road bike with chunky 700's. ONly when you look closer do you see the roller cams, and the rims that are less than the seem to be. I LOVE it!!,,,,BD
So many bikes, so little dime.
#1173
This! So cool I cannot find words for it. If I had my Stumpy I've wanted for so long, it would look like this! If I could bear to remove the BEAUTIFUL bullmoose bars that is!,,,,BD
#1174
Liked 10 Times
I started to think about how to explain it but an image off Google is easier to illustrate than to explain.
If you ran the Albatross bars flipped up, you'd be limited to keeping the ends of the bar parallel to the ground. You'd be somewhat locked into a "Townie" bike set up too. No way I would ever go with that set up! How I have them positioned in the above picture keeps the thumb shifters above my hands when I'm on the grips. Also, I have a few hand holds higher than the gripped ends and a max height in the center on both sides of the stem. That center position is really comfortable for cruising and long distance riding. Once I finish the build and get everything dial'd in, I'm going to install some black leather Brooks wrap from the shifters to the center.
#1175
Liked 10 Times
Ditto, thanks Seely!
-D-
