#2426
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
Keep us up to date, that's a beauty!
#2427
Edumacator
Quoted: 2440 Post(s)
Liked 3,130 Times
The Nuovo Record was up for maintenance and at the same time I replaced some parts with parts off a Bridgestone. Some wider bars, the whole brakeset (from Exage motion to Exage Sport) and getting rid of my cruddy white hoods(the Sport came with some dark purple ones). Then both rd and fd also Exage Sport. Rebuilt both wheels.
IMG_0731 by 2cam16, on Flickr
IMG_0732 by 2cam16, on Flickr
IMG_0735 by 2cam16, on Flickr
Likes For jdawginsc:
#2428
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
Probably a 1985 Spectrum. Not a ton of use ever. It's biggest problem was that the previous/original owner was also a heavy smoker. The entire bike is coated with a tacky yellow film, nicotine.
It's pretty much required full disassembly to get it cleaned.
Full DA 7400, and low miles (ya know, smoking makes it hard to ride a lot). I'm only replacing tires, hood covers, brake pads, bar tape, and cables and housing. I'll lube the bearings and wax it and hopefully ride it this week.
#2430
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For thook:
#2431
Quoted: 576 Post(s)
Liked 1,003 Times
Front derailleurs have given me a lot of trouble lately, especially on this bike. I've had trouble finding one that worked with my Tiagra shifter. This one started out with a struggle, and suddenly, it works like a charm. Finally! So I think my McLean is pretty much done for now.
It's an Ultegra, and I don't know which vintage. I used a clamp adapter which adds trickiness to the whole deal, but I'm happy with the result.
Likes For DorkDisk:
#2432
Setting up the prelude for winter spinning.
Likes For Kdogbikes:
#2433
Quoted: 964 Post(s)
Liked 1,451 Times
I did my first-ever bicycle disc brake bleed on a friend's 29er. Shimano's instructions basically mirror the protocol on the internet for SAAB and Ducati clutches, or really any hydraulic system where the lines have a low-point that keeps air bubbles from all going out the caliper nipple or up to the reservoir.
The fabled reverse-bleed was the technique, using a syringe and tubing to force fluid up through the system along with any bubbles. It was much easier to do the Shimano brakes in my living room than the same protocol on a SAAB or Ducati, which is usually accomplished on the side of the road in the rain with traffic whizzing by.
However I'm not impressed with the performance of the braking system. It's worse than long-reach Campy sidepulls! I can't even endo the bike and it squeals to high heaven, making dogs howl for miles around. I think the pads are contaminated with brake fluid from my friend's attempts to bleed the system before he threw in the towel and brought the bike to me. I tried to use acetone and clean everything up, but it didn't help. The pads are like little oil-soaked sponges and they keep releasing a sheen of goo onto the discs.
Makes me appreciate my rim brakes all the more
#2434
Quoted: 637 Post(s)
Liked 1,287 Times
Threw this together last week from the parts bin. This is about the 5th round for this frame since I got it but I think this is the best version to date. Beautiful it's not but it's fairly light and I can throw it in the trunk of the car with one wheel hanging out when I need to drop the car off to have it worked on and ride the bike home then ride it back when the car is done. It's all parts that came off other bikes, that were purchased for other bikes and didn't work out as planned or parts I acquired cheap or free. Some of the parts are nice quality with cosmetic issues like the Deerhead derailleurs and others are just functional crap like the Chinese brake levers, it's just whatever I had with no foreseen use that would fit. The only new items that have not previously been used on a bike are the Kenda 27 X 1-3/8" gumwall knobby tires and the Shimano friction thumb shifters. The tires were purchased for something else 3 or 4 years ago and wouldn't clear and the shifters were free. I have 2 other major projects going but they are both post-2000.
#2435
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,437 Times
I have been doing some general maintenance on a couple of bikes. What I have been doing mostly, that is bike related; organizing my tools, supplies, etc. In general, getting my bike room set up in a way that is more efficient and less cluttered, easier to maneuver and keep clean. I have a small,spare bedroom that I am making my bike work area. Tomorrow I am going to get mats for the floor, a couple of tools that I need, look for small item storage and check for lighting that might work better than what I have.
#2436
Bikes: Only my riders left...
Quoted: 350 Post(s)
Liked 782 Times
Weighty problem!
I paid about $10.00 for it!
Whoops! Can’t have this!
Metric and standard!
Built in tape measure!
I was weighing some bikes, some vintage bikes, and my repurposed luggage scale must have skipped some teeth internally and started added weight to my bikes!
I broke it down, figured it out, and fixed it!
Blessed with mechanical thinking!
#2437
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I'm in the process of refreshing my '95 Killer V, a little at a time. I finally found & downloaded the pdf file, for Cannondale's Force 40 brake boosters yesterday. Today, I cleaned & greased the main pivots (kinda like a cantilever post), and set them up the way they're supposed to be. I had already cleaned & greased the canti posts a few days ago, so that just left final adjustments to the pads & cables, which is pretty simple, even for me. 😁😉
One of the spring stops (?) was broken, on the front Force 40, but it still works far better than it was now, and both front & rear brakes work fine now. 👍
After that, I got some fresh grease inside my headset. I'll need to upgrade that whole thing, but for now, at least it doesn't squeak, lol, and I at least know that it's relatively safe. 🤔😉
Next project, repacking my hubs. Those are Acera X Parallax, which is a new one on me. I've had Deore LX Parallax hubs before, but never needed to repack them. I guess I'll have to read the instructions, if I can find them. 🙄😉
#2438
Quoted: 350 Post(s)
Liked 782 Times
Freshened up...
Freshened up my backup beater bike...just a great no frills bike...
Didn’t do much, front and rear bearings, lubed front and back rear brakes, derailleurs, no adjustments needed!
Totally built/rebuilt quite a few years ago...company bike, ridden, neglected, forgotten...it has never disappointed!
Another freebie from years back!
Just picked up a donor bike with all good SLR brake parts...this has worked for more years than I can remember...
I know, I know, I shouldn’t clamp on the top tube...pretty much just hanging the bike here while I redo the wheel bearings...
#2439
Quoted: 938 Post(s)
Liked 2,944 Times
I’ve been building up the 1970 Raleigh Pro. It’s time to massage the fenders. May take as long as everything else to get just right!
Likes For ascherer:
#2440
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For thook:
#2441
Quoted: 938 Post(s)
Liked 2,944 Times
#2442
Quoted: 350 Post(s)
Liked 782 Times
Oh yeah...that’s why it wasn’t being ridden!
Pulled these out of the top drawer...I gotta start writing down what is wrong with a bike so I don’t forget and go for a ride later! I also use to write down the combos on old locks when I figure them! Also for putting for sale prices during sale days.
#2443
Quoted: 4512 Post(s)
Liked 6,387 Times
Likes For merziac:
#2444
Quoted: 938 Post(s)
Liked 2,944 Times
Thanks @merziac, I appreciate that. This is one the nicest builds I've done.
#2445
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
#2446
Quoted: 938 Post(s)
Liked 2,944 Times
#2447
Bikes: Olmo Competition, Wiler Trestina Ramata, Pinarello Special, Bianchi Campione del mondo
I am currently working on a late 70s Pinarello Special, today i have sanded clearcoat to get it ready for another and final layer.
#2448
Quoted: 938 Post(s)
Liked 2,944 Times
The generosity of this community is the secret of its success. Many thanks to the forum member that mailed me this little beauty .
#2449
Quoted: 796 Post(s)
Liked 522 Times
#2450
Quoted: 350 Post(s)
Liked 782 Times
I have the replacement clamping posts if doing anything aggressive or if the frame is too pretty to clamp...
