Illusion of "aero" bike frames
#76
Super Modest
Quoted: 10965 Post(s)
Liked 4,621 Times
Exactly.
Keep the chain tight!
#77
Aluminium Crusader :-)
I'd be very surprised if Lemond's "aero" Bottecchia frame reduced much drag at all, despite the tiny "fin" behind the head tube, and what I gather were ovalised main tubes.
For instance, recent tests have obviously shown that a horizontal top tube is more aero. I suspect he would've been better off on a standard frame (perhaps smaller than his usual size, to enable the low bars) with a long, aero seatpost
#79
Quoted: 1069 Post(s)
Liked 788 Times
Likes For OldTryGuy:
#80
Quoted: 1104 Post(s)
Liked 1,825 Times
#81
Yes, someone told me on here a long time ago to never underestimate the placebo effect, after I derided someone I saw in a race frantically scoffing some chocolate less than 2km from the finish
Likes For 531Aussie:
Likes For rubiksoval:
#83
Rhapsodic Laviathan
#84
Rhapsodic Laviathan
I have a military bag from my stepdad; I would use it to carry a load of laundry and I swear I was faster. I figured it made my body more aero, as there was more surface area along my side profile and a more rounded trailing edge versus my turbulent flat back. Almost like the magnus effect, especially since I wasn't going 20+mph. I still felt the difference, I wasn't pushing as hard to get speed.
#85
Rhapsodic Laviathan
#86
Rhapsodic Laviathan
I knew somebody that had one of these tanks at the co-op. We were comparing the frame simularities to it and my Genesis Roadtech, as both are technically aero frames. Yes my roadtech was lighter, even than his 1990 World Sport.
#87
Ha, nah, on here.
Good point. Even if it he wasn't busy chewing, he might've been too busy unwrapping all the stuff he had in his pockets
#88
Jee, those brake levers bring back some memories. Well, not so much those ones with the extra extensions, but the standard ones that first came out without the cable sticking out the top. I remember they called them "aero levers", at least they did down here in Australia. As soon as I got some and saw what a simple design they were, I wondered why the hell we ever had the cables sticking out the top.
#89
Because it's the same design that levers for flat bars use.
Also because it allows for housing routing with minimal sharp bends, which helps to minimize cable friction. Almost nobody bothered putting return springs in brake levers until "aero" cable routing added a bunch of stiction.
Also because you can fiddle with brake cables and housing without pulling up the bar tape. (Downtube shifters achieve the same result for shift cables and housing.)
Anyway, the main advantage of "aero" brake levers isn't the housing routing at all. It's the placement of the brake lever pivot: it gives the fingers a more squeeze-like pull angle when braking from the hoods.
#91
Quoted: 941 Post(s)
Liked 319 Times
Purely a matter of curiosity while scanning this thread, is there any science to back this "aero" business, with wind tunnel tests, etc?
#92
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
The reason for dimples on a golf ball is to disturb laminar flow where that combined with the spin of the ball creates lift. So we need a design where the TT spins creating a huge advantage on the climbs
dave
#93
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
Univega's 1984 catalog shows a 20 lb "Aero" model as their top of the line bike. I have never seen one of these, they must be quite rare. Would love to modify one of these with modern wheels and components.
#94
Quoted: 941 Post(s)
Liked 319 Times
I realize that this was mostly in jest, but just because this is an internet discussion board ...
dave
dave
https://www.autoblog.com/2009/10/22/...-dimpling-mpg/
#95
Now, there's an idea: dimpled outer shells of the head tube, fork blades and the top of the bars that spin as we ride. What the hell, how about a rotating, dimpled helmet shell and suit?!? It's probably already been thought about.
#96
