Show Us Your 650B Conversions
#726
Bikes: '71 Peugeot UO-8, '83 Trek 720, '81 Trek 412, '83 Trek 620, '72 Atala Competizione, '51 Raleigh Sports 'C' Tourist, '58 Raleigh Sports, '91 Bridgestone MB-1, '94 Specialized StumpJumper
Quoted: 45 Post(s)
Liked 64 Times
1982 Trek 613
This is the twin to natterberry's 614
Likes For BocaJr:
#727
Bikes: 1986 KHS Fiero, 1989 Trek 950, 1990 Trek 7000, 1991 Gary Fisher Hoo Koo E Koo, 1992 Trek 1400, 1997 Cannondale CAD2 R300, 1998 Cannondale CAD2 R200, 2002 Marin San Rafael, 2006 Cannondale CAAD8 R1000, 2010 Performance Access XCL9R
Quoted: 284 Post(s)
Liked 385 Times
132mm, wow. And I haven't taken any of my frames past 126mm yet.
There are a lot of elegant and inelegant methods out there for dimpling the stays, mine is somewhere in the middle. I took a spare pair of vise-grips and ground out one jaw to be smooth and more or less the radius of the outside of a chainstay, then padded it with a few layers of duct tape. I also ground one side of an 11/16" wrench to be rounded and smooth, and so my process is to place the rounded side of the wrench where I want to make the dimple, open up the vise-grips a bunch to fit around the chainstay and inner face of the wrench, and then gently squeeze. I try to only do a little at a time, and you don't have to make a deep impression on the inside of the chainstay to open up a decent amount of tire clearance. Afterward, it's a good idea to double-check your dropout alignment.
Very cool use of a versatile tool!!!
#729
Quoted: 45 Post(s)
Liked 64 Times
Thanks! This thread with many bikes like yours were a big help in this build. I wish I was better at documenting with pictures throughout a build. This was a $50 CL acquisition needing a lot of work. Here's the CL ad, my only before picture. I guess the bike needing so much work gave my a sort of 'blank canvas'
#730
Quoted: 284 Post(s)
Liked 385 Times
As I recently picked up a 2002 Marin hybrid, surprised at the relatively narrow chain stays. I had hoped to fit a 700x45, but a 700x40 is all I can fit. I am giving a serious consideration to a 650b conversion, and seeing your modified vise grips might get me the additional room I need. I have a friend bringing me a 27.5 rear wheel to see if I have reach with my current V brakes or not.
#732
Quoted: 45 Post(s)
Liked 64 Times
Yes I did. I’m usually not one to modify components or frames, but I did in this case. I guess I really didn’t do my homework, since I thought the Tektros would work. I grounded the slots, but it was a white knuckle moment!
#734
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Likes For CV-6:
#736
Maybe didn't post this here yet? '71 Raleigh/Carlton Professional Track, bought as a frameset. With 700x28 Vittoria Corsa tires, actual width around 26mm, clearance at the chainstays and under the fork crown were _very_ tight. With 650b GB Cypres, actual width around 32mm, clearance at the stays is reasonable, 4mm/side, and under the fork is clear as a bell. BB is on the high side, so the lower overall height hasn't been a problem. Getting the long-reach Campy front caliper to reach the rims was a chore, might end up replacing it with something just a smidge longer.
With only a front brake, and Jersey traffic, I went with a modern aero lever plus 'cross levers. Recently added a tandem dummy right-hand brake lever stub, no photos with that yet.
Before, 700c:
After, 650b:
Before, 700c:
After, 650b:
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
#737
Good time to post my completed '83 Trek 620 project.
Decided to hold off on implementing a full dynamo system for now, as I sort of like having a dynamo-less wheelset. If/when I move to New Mexico next year, I'll have to rebuild all my wheelsets anyway to go tubeless.
You can guess who did the frame/fork/rack work. How is there not already a dedicated thread to showing off your bikes that have undergone gugie -ficazione? Is there?
Likes For bear_a_bug:
#738
Quoted: 3361 Post(s)
Liked 3,647 Times
#739
Quoted: 502 Post(s)
Liked 466 Times
#740
Quoted: 3811 Post(s)
Liked 6,720 Times
#742
Current ‘82 614 setup:
#743
Quoted: 1106 Post(s)
Liked 1,328 Times
An un-conversion; 650B to 559
I had a 80s Peugeot berceau to work with; steel 650B rims, 103 tubing, Positron 5-speed, needed tidying. Still need proper touchup paint, that Peugeot white pearl is difficult.
Now has Shimano rear and 6 gears. And alloy 26 inch rims, only made sense when 650B tyres are north of 50 dollars each, rims are not cheap either, 26 inch rims and rubber *are* cheap, and those Altenberger brakes have at least 75mm reach centre-to-centre. Stem police - that's as far *down* as it will go, there's a sleeve inside that stops it there, so adjustment upwards is limited to about 3/4 inch.
Sorry all, I'll get my coat.
#744
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Meh, ga head!
#745
Quoted: 293 Post(s)
Liked 218 Times
#746
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
This is a 26" conversion, not 650b, but it's the same general idea.
www.rhmsaddles.com.
www.rhmsaddles.com.
Likes For rhm:
#747
Quoted: 591 Post(s)
Liked 663 Times
Love that half-step/granny on the LeJeune, CV-6 . What's the gearing?
Beautiful frame. Was this a repaint/redecal, or original? Feel like I saw this one somewhere before.
47/40/28, 14-28 seven speed.
Frame appeared in its own thread. Started as a tribute bike based on a Carré frame. Found the real deal, so changed it up to a 650B using parts from the tandem that never gets ridden.
#748
Quoted: 1088 Post(s)
Liked 1,205 Times
Likes For noobinsf:
#749
Liked 5,803 Times
Likes For gugie:
#750
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
Thats more than just a 559 conversion!
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Likes For mountaindave:
