Panic buy RD-6700-A GS for 12-30 ?
Quoted: 1944 Post(s)
Liked 2,164 Times
I understand wanting keep an Ultegra group intact and for your setup it will work great. The 9 speed MTB “rear” detailleur is with a 10 speed cassette and 10 speed (road) brifters. At one time that was a preferred setup using 10 speed cassette and 10 speed (road) brifters for cyclocross. There are a bunch of threads out there.
I only brought it up because you started talking about using a wolf tooth at some point in time. You can live by the tech docs; but I would think looking at people who are playing in the mud in the real world carries at lot more weight.
John
Edit Added: The truth is, your hanger has as much to do with pushing max cog as anything else... up to a point.
John
Really Old Senior Member
You install a 1.8?mm spacer on the FH body when using a 10 speed cassette vs 8 or 9.
Both RDER's have the same cable actuation ratio. A 10 speed just pulls slightly less per shift. The "brains" is in the shifter. The RDER is just a slave.
When you count your "steps", you have to remember you're already standing on the 1st one.
Licensed Bike Geek
Actually, the 'stack" of a 9 speed is slightly wider than 10.
I know you’re going to go in a different direction but I’m posting this as an FYI hoping you can wrap your head around why 9-speed can be happy with 10-speed. Back when 10-speed was new there were no large cassettes that the touring community could use. When it was found that 9-speed rear ders worked perfectly it became very common to use that combination.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
DaveT,
Thank you for the clarification.
So 9sp RD moves the same distance regardless of 9sp or 10sp brifter. The 10sp brifter simply moves less per step.
Got it.
Barry
Got it.
Barry
Quoted: 431 Post(s)
Liked 460 Times
OP I'm glad you've finally settled on a setup that works.
But my goodness how many times does one need to be told that 1) the original 6700 RD would have worked fine with a 30t (and in many cases 32t) cassette and 2) the best way to go beyond a 32t cassette is to use a Shimano MTB 9sp RD?
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
tFUnk,
About the same number of times you need to be told it was about the WHY and learning something.
Licensed Bike Geek
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Bikes: Carbon Road, Ti Road, Aluminum Cross, Steel Road, MTB, circa 1999-2012
I've been using RD-5700 GS / RD-6700 GS with SRAM 1070 32t cassette for years. With SS I can go up to 30t no problem. If I remember right, when I did a similar research some time ago, someone explained the reason why Shimano only spec'd up to 30t cog is because that was (or is) their largest 10 speed road cassette at that time.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
ne46st
Welcome to Bike Forums.
Just to let you know, you just woke up an extremely old thread (almost 2 years old).
It's not a problem for me, but some do frown upon it.
I finally wound up with an RD8000 series long cage (GS version) and a PC1170 SRAM 11-36 cassette.
It works great and details can be found in another of my threads.
All the best
Barry
All the best
Barry
Likes For Barry2:
Liked 2,164 Times
ne46st
All the best
Barry
All the best
Barry
Going to 36t is probably a better long term move.
John
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
70sSanO John,
At 58yrs I find a 11-36 very helpful. Despite the abuse I receive from a certain "friend".
And yes, if I had his FTP (approaching double mine) then I wouldn't need 11-36 either!
If you like to see what I did..... HERE
It's way beyond Shimano specs, but I've been running it for 8 months & ~3000 miles without issue.
Even had a buddy go the same route with a mechanical (non Di2) R8000-GS long cage.
Just be really sure to get the chain length correct. I recommend the Park Tool Video (Big-Big+2) method.
Barry
Barry
Quoted: 431 Post(s)
Liked 460 Times
ne46st
Bnib
I bought a BNIB 6700 RD but realized I want the silver colour instead. Up for grabs, it was costly. Letting go 170$ if anyone interested.
