What's an acceptable leak rate from tubeless gravel tires
Old 08-16-20, 03:58 PM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
Leaks are unacceptable to me no matter how small a leak may be...That's why I don't use tubeless, it seems more trouble than it's worth.
wolfchild is offline
Old 08-16-20, 04:46 PM
unterhausen
Randomhead
Liked 3,700 Times in 2,520 Posts
all tires and tubes are leaking constantly, the difference is the rate at which they are leaking. I had 20 flats on my gravel bike the year before I switched to tubeless. I would switch to tubeless on my road bike if I had a little more faith in it for narrower tires.
unterhausen is offline
Old 08-16-20, 05:02 PM
Toadmeister
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times in 170 Posts
Originally Posted by Koyote
Toadmeister , that might be sealant coming through the sidewalls...And I wouldn't worry about it. To make suppler tires, some mfrs intentionally make the sidewalls relatively thin to the point of being porous. And then they are counting on the sealant finishing the job of making the sidewalls airtight. The alternative is much heavier, stiffer sidewalls, which will reduce ride quality.
If these tires had !,000+ miles on 'em, and we were actually seeing sealant (as opposed to some damp-looking spots), I might be more concerned. But this looks fairly normal.
PS: You might not see even this little bit of leakage if you use Orange Seal next time.
yeah, makes sense. Sorta what I figured, today was the first day I noticed that but now I think back, I have seen it before.
I have used up all my Stans and am starting to use Orange seal on my newer wheels.
Toadmeister is offline
Old 08-16-20, 05:05 PM
Toadmeister
Quoted: 198 Post(s)
what unterhausen said. A trade off of light tires is a higher rate of air permeation. Add more sealant and spin those tires to help seal.
tubeless tires are one of the best upgrades I’ve done to my bikes. More supple ride, less roatating mass, self-sealing. I’ve had a couple roadside punctures this year, nail and glass, that sealed themselves. What a relief not having to change a tube roadside!
Also note, your auto tires are tubeless.
Old 08-16-20, 06:45 PM
Pratt
Quoted: 417 Post(s)
Liked 498 Times in 295 Posts
Maybe try larger gravel
Pratt is offline
Old 08-16-20, 07:50 PM
Troul
Troul's Avatar
Liked 2,981 Times in 1,921 Posts
experienced a tubeless carbon wheel having less air loss over time compared to a tubeless aluminum wheel using an identical tire.
The carbon wheel was much more of a tight turdcase mounting the tire on.
-Oh Hey!
Troul is offline
Old 08-16-20, 09:03 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10970 Post(s)
Liked 7,496 Times in 4,192 Posts
Originally Posted by Helldorado
Still, it should not have taken almost two weeks for the tires to stay inflated overnight. I attribute it to the low-budget rims that came OEM with the bike. Thanks for your comments.
Low budget rims shouldn't be on that bike. Thats the real crime here.
mstateglfr is offline
