#552
enginerd
^ That Scirocco sounds fun. I've been getting my V70R in the best shape it's been in in years just to sell it.
I've been slowly working on a giant Concorde I picked up as well as cleaning up a Cannondale Crit frame that needed a little paint love
the R:
the R:
#554
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
Just finished this, '83 PFN-10. All-French drive train (except for the pedals), wheels, and brakes.
Real cyclists use toe clips.
jimmuller
jimmuller
#555
1986 (I think) Pinarello Record.
#556
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,609 Times
I'll check the can for a color code.
#557
Bikes: 1992 De Rosa SLX, 1992 Specialized Epic, Late 60's Bottecchia Proffessional, 1998 Stumpjumper M2, 1992 Stumpjumper M2 (in a box)
Quoted: 73 Post(s)
#558
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times
Sweet! Yeah I started with Toyotas back in the day, hence my rendition of twincam16,the 4AG motor. Then I moved on to Subarus. Used to auto-x in a WRX and a Miata with SFRSCCA. Also a few track days here and there. Laguna Seca for the best. Then it got too expensive. lol
#560
Quoted: 4560 Post(s)
Liked 2,802 Times
Tweaking the '89 Centurion Ironman. Repacked the hubs with fresh grease. Swapped in a 39T Vuelta chainring to replace the original 42T Suntour, and a 13-25 SunRace freewheel to replace the original 13-24 Suntour. A bit easier on the steepest hill climbs, especially with head winds.
The new SunRace freewheel shifts more crisply and quietly. But I preferred the gear spacing with the original 42/52 chainring setup on the 13-25 SunRace spacing. With the 39T chainring I'm needing to double shift more often, and am losing some momentum on hills. Maybe as my climbing strength improves I'll swap back to the original 42T chainring, but I think the 13-25 SunRace is a keeper, at least for the less-tight spacing.
Also been trying to reduce some chain line tension. There's way too much spring tension in the Suntour GPX rear derailleur, and cleaning and regreasing didn't fix the problem. Needs a lighter spring, but I doubt I'll find one. Might replace the derailleur itself. Meanwhile I've added a couple of links and adjusted the wheel a bit farther forward to help reduce some tension without chain drops. Helped a bit.
#561
Sempiternal Newb
Bikes: '92 Trek 750, '85 Univega Gran Turismo, '95 Stumpjumper,
Quoted: 232 Post(s)
Liked 15 Times
My neighbor has had this bike for at least a decade, if not two, having originally pulled it out of a dumpster in Brooklyn. It's ugly, it's rusty, it's clunky, the fork is tweaked, but the steel rims keep on rolling with some new tires and the headset is smooth again with new bearings. This bike will outlive any apocalypse.
#562
Just finished up these two beauties.
Peugeot PA10
Tommasini Prestige
Peugeot PA10
Tommasini Prestige
#563
Quoted: 7351 Post(s)
Liked 2,477 Times
What's your plan for the Peugeot, @jimmuller?
#564
aka: Mike J.
Been monkeying with this lately (when not working on the house), added the saddle last night. Not sure about the green but it functionally fits and I guess it matches the new to me trainer.
Ps,
I should add (so I don’t get booted out of here) that the his&hers Raleigh Sports matched pair hiding back in the corner will be next in the queue to get worked on right after some minor nut/bolt replacements on my wife’s bike that she picked up earlier this summer.
Ps,
#565
Bikes: 1973 Raleigh Sports, 1964 Raleigh Sports (Canadian?), 1969 Triumph Ladies, 70's Columbia Sports III, 07 Diamondback Venom
Quoted: 83 Post(s)
Been tearing down my first English 3 speed (64 Raleigh Sports) and preparing my 01 outback for a 2 inch lift and some grabber AT/2's (yes we also own a Baja)
Day i got it:
1964 Raleigh Sports 3 speed by David Ashe, on Flickr
Day i got it:
#566
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Here's a DiamondBack Ascent belonging to a friend of mine. He retired recently and wants to get back into shape so plans to include riding with his walking and weights regimen. He bought the bike new in about 1990 but has not ridden for years and had let his brother use it until today. Nothing seriously wrong except the RH RapidFire shifter seems broken; won't downshift. I expect repair will be impossible and replacements hard to find but that will need to wait for exploratory surgery. He also wants a taller stem and/or bars and it's a good thing he's in no hurry because I'm in the midst of a bathroom remodel that has priority.
#567
Liked 645 Times
jimmuller
jimmuller
#568
Quoted: 472 Post(s)
Liked 1,028 Times
I broke down and washed my gloves recently. The water came out black. Guess they needed it. Give that a go then ride dem white bars.
#569
Liked 645 Times
On-topic, I had an interesting mechanical "thing" develop these last few days. I've been riding the Grandis to work, started hearing something rattling, a sort of metallic clinking like loose change (which I'm not too familiar with). Sometimes it would be there, sometimes it wouldn't. Nothing seemed loose in a cursory inspection on the roadside.
Then it occurred to me it might be a FW sprocket. Hmm! Another roadside inspection revealed a rattling outer sprocket which had come completely unscrewed from the FW body. When I got home I pulled the wheel off. It had created some wear marks on the inside of the DO but otherwise seems to have done no other harm. So I screwed it back on and tightened it with the chain. I guess it's trying to tell me to use high gear more often. I should remember not to forget to stand on the pedals in high gear to tighten it further the next time I ride it.
But today is for the first voyage of the white-barred PFN-10.
jimmuller
jimmuller
#570
Shifting is fun!
Bikes: Yes, please.
Liked 4,609 Times
#571
Liked 2,477 Times
I carry wet wipes in my tool bag, but I forget about them until it's too late.
#572
Quoted: 3361 Post(s)
Liked 3,638 Times
#573
Liked 645 Times
Thank you. I can't claim credit for it, only for restoring it. Peugeot made the paint/chrome decisions.
I did ride it to work today. Nothing untoward occurred, no tire went flat, nothing broke! And the bar tape didn't get too dirty. But then, I started with clean gloves. @Prowler, I throw them in the clothes washer pretty often. Otherwise they become intolerable.
jimmuller
jimmuller
#574
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,007 Times
I had a Subaru Brat, bitd. It was the ancestor of the Baja. I had a lot of fun with that little car/truck. They put jump seats in the bed to get around the imported truck tariff, but I could still carry a dirt bike if I put the front wheel between the seats.
#575
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
All Work, Little Play...
... means more time to spend in the shop!
A couple of projects have captured my attention lately. First, the Bianchi Sport SX that I call Celeste turned into a very nice sport-tourer:
I've only ridden her on local trips so far, but she has the potential to cover some serious miles.
Tonight after work I was very tired - it's been a very long week. So as soon as I got home, I went into the shop, sat in my favorite leather and wicker chair, and gazed at my domain from behind my latest project:
My thirty-dollar PFN-10 Velo de Ville is coming along nicely. With this bike, I've made a breakthrough that will definitely influence future bike purchases.
What I have found is that I prefer bikes that are conventionally too big for me. I am 5'9" tall, and by rights should fit best on 55 - 58cm frames. But when I do that, I find the top tube too short for my torso. I was buying longer stems and setback seatposts to compensate until I discovered how to set up a 59 - 60cm frame so it fit me.
Since I can't ride in drops comfortably anyway, I want a saddle-to-handlebar setup that places the grips slightly above the saddle, and far enough away so that I get a decent stretch. The only off-the-rack frames that do this are theoretically too big for me. The standover height exceeds my inseam, so I have to be very careful how and where I stop.
But I had the muscle memory stored away from childhood, riding bikes that were too big for me, and the leg-leverage saddle-mount maneuver came naturally. So did the graceful one-legged stop.
As a result, this has become my favorite bike of the moment:
Just finished tonight, once the rain clears the area tomorrow, I plan to put on some miles. If I do, watch for a ride report over on "Where Did You Ride Today".
USMC 1981-1991 Semper Fi!
