ISO and for trade thread part 5
#6151
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
I’m looking for a silver 48t 110 BCD shark tooth ring you want to get rid of. Not a good one, a bad one you want to let someone up-cycle into a chain guard. I have bits to trade, but if it’s hanging around (literally) and you’re about to throw it out and you want someone to pay for shipping to get rid of it for you, I’m your guy!
Here’s my process:
Here’s my process:
I know this might be too much grinding but I have a free 48t in 110BCD for ya, but it's black-painted STEEL.
If that doesn't scare you off, just PM me
BTW, my process (thanks to trial and error) with alloy rings is to first break off as much of the teeth as practical with the aid of a vise-grip.
It's often the case you can get most to break "pretty cleanly" and that really cuts down on how long you have to spend on the bench grinder!
#6152
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
I gotcha, I like to make my own homebrew chainguards from otherwise trashworthy rings, but i usually use bigger donors (like the common 52t or 53t).
Re technique: I tried just what you described. Last time but couldn't get the teeth to break, so I just used the grinder. Anyway, it didn't take too terribly long. (Maybe a softer alloy?) Not something I would want to do on a regular basis, but for my wife, worth it.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Likes For mountaindave:
#6153
Quoted: 3811 Post(s)
Liked 6,713 Times
I use a bolt cutter to trim the teeth down before moving to the grinder. @mountaindave, I might have that ring, but am out of town until Sunday, so I can check then if you still need it.
#6154
tantum vehi
Liked 992 Times
I’m not in a rush, @nlerner so if you end up finding a silver one, that would be fantastic.
#6155
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Here’s my process:
Here’s my process:
If you have a belt sander, you can use that to remove the teeth and simply change the belt when it becomes clogged.
#6156
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
#6157
Liked 6,713 Times
Likes For nlerner:
#6158
Liked 1,064 Times
"A word of caution: aluminum will clog the grinding stone and can cause it to overheat and potentially shatter. You don't want to be anywhere near when that happens! If you haven't already, re-dress the wheel with a dressing tool to remove the clogged surface and expose fresh stone."
I have heard the cautions about just that for many years (probably first time from a shop teacher in Junior High) so thanks to JDT for the reminder: he's right of course.
Nevertheless I don't always follow good advice (such as I often grind ALU on a carbide bench grinder wheel) and one day that's going to catch up!
But I DO have a wheel dresser (just like the blue handle number JDT pictured) and I DO use it...if you play fast and loose you should at least dress your grinder wheels. Or use a sanding belt as he suggests, they cut nearly every bit as fast as a wheel, better in some cases! And I'd add: use eye protection (always) and leather gloves, too.
Likes For unworthy1:
#6159
Liked 1,064 Times
WTB or WTT: a "Blackburn" style caliper-mount "strap" for oldskool rear rack(s)
I admit to being a "hoarder" of certain items. One being: I save up rear racks to add them to most every the bikes I build up for others.
I usually find and keep around some older 'classic' Blackburns (or imitations) that frequently have lost all or most of their mounting hardware.
I can find long aftermarket stainless 'straps' for the racks that need two (L&R) with a twisted end that bolts to braze-on boss (if you got those) or P-clamps (if you don't)...but no luck finding the center-only single 'strap' that bolts to the brake-bridge hole.
Something like what comes with this "Axiom" brand current rack, but hardware is not sold alone, AFAIK.
I'm looking for one or more, in good condition, I like them because they are stainless steel and have a clean slot and hole. Plus they are correct width for the racks that have a channel, and require nothing more than bending to get all correctly aligned.
If I went to fabricating my own I'd probably have to use inferior aluminum stock and could not make as nice a nice slot, just drill and de-burr some regular holes...plus I don't need that extra work!
Anybody got a small stash of these? Or a link to where they are still sold?
I have plenty of stuff to trade but happy to spend reasonable $ if I have to
#6160
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
#6161
Liked 1,064 Times
I think the Rivendell "diving board" is closest to what I want, but for $20 I may just "frankenbike" one of the incorrect side struts I have onhand
#6162
Quoted: 1611 Post(s)
Liked 2,593 Times
You see that big pile of racks at the Fairfax swap? Roy was giving away a lot of stuff.
#6163
tantum vehi
Liked 992 Times
Last drift, I promise!
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#6164
Liked 1,064 Times
There was a shocking lack of racks and bits found at my last visit to Waterside Workshop in Berkeley (who usually have what I'm looking for) so could be they have all migrated to Marin (the Rack Pack HQ of Cali?)
#6165
señor miembro
Liked 6,488 Times
Isn't it about time for @nlerner to get the message and upload an appropriate avatar? I even cropped it for him.
Likes For SurferRosa:
#6166
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 228 Post(s)
Liked 294 Times
Likes For MooneyBloke:
#6167
The part I am looking for isn't C&V but I have plenty of C&V parts to trade. I am looking for the rear derailleur shift cable adjuster for a 10 speed Campy Veloce derailleur. I could buy a new one but it would cost nearly as much as I paid for the complete groupset.
#6168
Quoted: 1106 Post(s)
Liked 1,328 Times
https://branfordbike.com/rear-der-pa...railleur-parts
E1 - adjuster for 8/8s Veloce - 12.88
#6169
Thanks for the link since I now know the exact part number I need. I did get the groupset for a pittance. Once you add in the shipping and tax it is more than half of what I paid for the whole groupset. I have a ton of C&V bike components I am in the process of selling off that is why I am looking for a trade if possible.
Either you got a great bargain or you are not looking hard enough -
#6170
Liked 1,064 Times
I've had the same bit (E1 - adjuster) break on a couple RDs before.
At least some versions seem to be cast metal and of a soft alloy to boot!
Bad choices, Campy!
Bad choices, Campy!
#6171
Liked 2,593 Times
Digging through a BOC I picked up for a bottom bracket a friend needed and ran across this. It has a sleeve with a c-clip so I'm not sure it is the same. 9 speed Chorus.
#6172
Supposedly there is a difference between 9 speed and 10 speed adjusters according to the Campy site. Thanks for checking for me.
#6173
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
I have a Campy Centaur derailleur that came to me with the same part broken. I found that it had the same threading as the equivalent part on a differently broken Shimano derailleur that I had on the shelf. If you have anything else sitting around, I'd suggest trying a mix-and-match to see if you can find anything that fits.
My Bikes
My Bikes
#6174
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
https://www.ebay.com/itm/22424931682...8AAOSwBPZfvj8y
