Finally - Motobecane Grand Record restomod
Quoted: 7349 Post(s)
Liked 2,474 Times
Yes, I was the bike guy in South Orange and Maplewood for a few years. I even taught riding and repair classes. Fun times.
Likes For noglider:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
This is gorgeous. I love the general headset and seat tube panel scheme of these old Motobecanes, and it pleases me to see that you kept it. I've refinished a Grand Record and a Grand Jubilé and in both cases kept the original contrasting color scheme while choosing different colors. The ones you picked look great.
I also want to say the lug lining looks fantastic. Nice touch!
My Bikes
My Bikes
Likes For Andy_K:
Bikes: 1975 Motobecane LeChampion (silver lilac), 1974 Motobecane Grand Jubile (red/black); 1975 Motobecane Team Champion (orange); 1982 Pinarello Professional (Exorcist Green); 1974 Raleigh Professional MkIV mink blue, 1974 Motobecane Grand Record blk/red
Quoted: 103 Post(s)
Liked 750 Times
Fantastic job on this one! I'm a big Motobecane fan as well, with a '75 Le Champion in silver lilac, a '74 Grand Jubile in red/black, and am just finishing restoration on a '75 Team Champion, which I kept the original paint on and went in a bit different direction. As soon as I have enough posts, I will try to submit some pics. Good work there!
Likes For 75lechamp:
Quoted: 823 Post(s)
Liked 1,395 Times
UTTERLY stunning bike!
A note for future reference - Nitto stems don't usually need to be sanded down to fit French steerers. I learned this one from verktyg - run a brake cylinder hone down the inside of the steerer, just enough to knock off any corrosion. Double check to make certain the top locknut of the headset doesn't have a smaller aperture than the steerer itself, and you can run a Dremel or a file around to open it out to accept the stem when done. Apparently Nitto Technomics measure out to around 21.8. Since I learned this I've found it works pretty reliably.
Likes For rustystrings61:
Quoted: 823 Post(s)
Liked 1,395 Times
The brake cylinder hone is my friend - I've found it useful for both steerers and seat tubes. The last two 531-tubed Raleighs I bought had been fitted with undersized seat posts. Once I straightened out the seat lugs the interiors of the seat tubes had corrosion from moisture that had gotten in. The hone made things smooth again, so that with grease the correct 27.2 mm posts fit properly.
Well THAT'S annoying.
I've been looking for a TA Pro Vis 5 Cyclotouriste set for my bike. It's hilly here, I like to spin, and the TA Professional 52/42T crankset was cool, but not something that was going to work in the long run, so I've been searching for a 50.4 BCD crankset that I could run 46/30T. After not finding anything here, and seeing auctions go for $130 that would still require me to buy new rings, I finally caved and bought the Velo Orange 50.4 crankset and - smarty that I thought I was - a pretty nice looking TA Pro Vis 5 drive side crank arm, thinking that I could use this as a matching pair with my existing non-drive-side TA crank arm from the Professional, and the VO chainrings. Then I'd sell the VO arms.
Well, it looks great!
But here's a lesson learned. The teeth on the Professional chainings are cut on the LEFT side of the rings. The teeth on the VO chainrings are cut on the RIGHT side of the rings. There's no way I can get the big ring/big cog combo to work without rubbing either the chain or the crank... I guess I can use the VO arms, but it's a bummer.
See below - the lovely combo I thought would work, then the comparison: TA Professional first, then the VO.
Current project: 1976 Motobecane Grand Record restomod
Quoted: 478 Post(s)
Liked 634 Times
I know nothing about the VO crankset, but is it not possible to flip the inner ring around and still use it? I had a similar problem with a crankset I had though it was self inflicted - at first I didn't realize there was a "handedness" and installed the inner ring "backwards"....
Quoted: 5888 Post(s)
Liked 3,471 Times
Also new TA rings are available on eBay. There is a UK vendor selling them. Shipping from the UK has become expensive with all the supply chain disruptions caused by the pandemic which is too bad because I'd like to order a carradice bag support.
Quoted: 938 Post(s)
Liked 2,944 Times
Bit of a zombie revival here, can you share the Color Factory contact? I'm looking to refinish my Falcon. Thanks!
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Keep an eye out for a CLB centerpull housing stop hanger with the teeth built in. Not really better than other options, just cool and trick IMHO. Note, the one in the linked pic has been polished by the owner, they're a bit rougher as-delivered (but not bad). Take care when shopping for one because they also made them smooth on the bottom, no teeth, so look closely.
Mark B
Mark B
And no worries about resurrecting the zombie thread - I should post a "year later" update photo!
Quoted: 938 Post(s)
Liked 2,944 Times
Sure thing, ascherer - I'll dig it up and send you a PM.
Likes For ascherer:
Quoted: 967 Post(s)
Liked 1,631 Times
It's so nice when ya see something that brings back Loving Memories...
Fuji Fan
That's a fine job and a fine looking bike. That's a wet paint job, right? I really like the green and cream. I have a Witcomb with an ugly paint job and I'm thinking of using a similar color scheme (likely British racing green with white).
Yeah that's too bad about the IRD freewheel. I've heard less than stellar things about it as well. At least it has modern tooth profile so hopefully the shifting is decent.
I've been riding my '72-'73 Moto Grand Record but the paint job has crackled. I'm jealous of your spiffy paint job!
Ugh, I did not catch that this was a zombie thread.
Likes For beech333:
