#2176
Bikes: '72 Fuji Newest, '79 Fuji Royale Gravel Grinder; '84 Schwinn High Sierra BMX Cruiser; '97 Huffy Tremor BMX
Quoted: 33 Post(s)
Liked 134 Times
[QUOTE=JaccoW;21123464]Stripped a bike and built a wheel this weekend.
Sweeeeeet! Want to see that when it's done!
Likes For FujiSam:
#2177
Eccentric Old Man
Quoted: 248 Post(s)
Liked 173 Times
30 cent lamp mount. Cutoff section from handlebar, a nickel, and a quarter.
#2178
Quoted: 33 Post(s)
Liked 134 Times
I have a 1992 Trek 950 I need to rebuild. I partially rebuilt it once when I first picked it up to make it rideable (overhauled the hubs and replaced the BB which forced me to replace the crank). I then ended up riding the bike in winter which is tough on a bike. So it's time to take it completely apart and rebuilt it. I never liked the v brakes and those shimano trigger shifters are only so so. I plan on rebuilding with cantilevers and thumb shifters. I'll likely go with a butterfly bar since I want to use this bike for touring on tough surfaces. It's next on the build queue.
#2179
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3896 Post(s)
Liked 6,498 Times
Someone who should be tarred and feathered used a plastic washer behind the crank bolts of the Rossin I picked up yesterday. The nds bolt had deformed the washer, preventing a 14mm socket from securing around the bolt head. Arrg! I finally succumbed to a tiny drill bit to remove enough plastic from around the bolt to remove it. I'm almost there ... I hope ...
The drive side washer wasn't deformed enough to prevent a socket from removing the bolt:
I guess I should consider myself lucky these weren't 15mm bolts.
#2180
señor miembro
Liked 6,498 Times
#2181
Overdoing projects
Quoted: 784 Post(s)
Liked 1,246 Times
#2182
Quoted: 796 Post(s)
Liked 522 Times
Getting a bit closer to the end of my Trek 420 refurb so I can sell this bike on (I have a 520 I will be keeping around)
1985 Trek 420
1985 Trek 420
#2183
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,482 Times
#2184
That’s what the forums Marketrplace is for. Let’s get some photos of that mysterious for sale campy equipped bike your trying to sell posted. Heck...maybe you’ll get lucky and find a buyer.
#2186
Bikes: 1983 Cannondale ST500, 1987 Cannondale SM400 with SA 3 speed hub, 1987 Schwinn Tempo, 1982 Schwinn Voyageur SP, 1992 Kona Explosif
Quoted: 8 Post(s)
Liked 7 Times
#2187
señor miembro
Liked 6,498 Times
#2188
Quoted: 339 Post(s)
Liked 632 Times
finished this Super course and am now cleaning up a Schwinn Prologue
Likes For capnjonny:
#2189
Quoted: 227 Post(s)
Liked 393 Times
It works! This Force derailleur needed a 31.8 to 34.9 adaptor but then wouldn't swing out far enough, not enough to lift the chain to the big ring so some trimming of the internal spring was needed. I don't think it will affect strength or reliability in any way. I'll be using non indexed thumb shifters. Still waiting on a new chain too.
Also clearcoated the stem and barends over bare metal.
#2190
Quoted: 796 Post(s)
Liked 522 Times
Continued my slow march on the Trek 420, hope to have it chained and cabled on Friday for a test ride and less dark pictures lol
#2191
Quoted: 821 Post(s)
Liked 257 Times
The heavens opened up and a PL forum member offered me my 3rd McLean.
Off to the frame prep folks in Mpls.
Let's see if I can get Chris Kvale to take this on in the winter months.
#2192
Quoted: 2588 Post(s)
Liked 4,827 Times
I have a couple/three bikes with headsets that are "indexed". The worst of them - until last night - was the one in my Colnago Mexico; this headset has been in the frame since 1994 and I don't believe it's been serviced since then, either. When I got it all apart (with the intention of retiring it and installing an almost-NOS one in its place) I was floored to see absolutely no evidence of wear on any of the races. I was expecting divots for sure, but was pleasantly amazed.
I also used the last of the blonde shellac to give the black bar tape a couple coats to extend the color-fastness. In between coats I cleaned the headset parts and re-installed them with fresh Phil Wood grease. I also made a somewhat sad replacement at the front end with an eye to allowing me to use this bike more often.
Because I was shellacking the bars I removed the brake levers. I wanted to give them a quick polish with aluminum polish, but I had also decided that for now, I would have to remove and store the custom leather hoods produced by our own @rootboy. I've noted that my hands have had a tougher time this summer gripping the lever hoods on this bike because the leather hoods are that much more thicker than the gum ones and they don't provide that vital bit of squishiness my aging paws are requiring more and more.
I decided to finally use a pair of Campy-copy hoods made by Robbie Fellows a long, long, long time ago. I got these after some back/forth between us bitd regarding drillium and such. He was going for an amber translucent look and this was a test shot he gave me. Looks brown from a distance, but up close it's translucent dark orange. Pretty cool, but more importantly squishy and smaller. I finished putting everything back together this morning and took it out for test ride and I can now go no-hands ridiculously slow without fear of losing my balance and there's no play or shudder when braking which means I got the headset final adjustment bang-on.
I wonder if I can get another 25 years of use out of this headset? Gonna give it a go
DD
DD
Likes For Drillium Dude:
#2193
Assembly process of the varsity.
Likes For Kdogbikes:
#2194
Uruguay
New shoe for my 98 GT Palomar. Deli Tire 26x2.195 i took from a GT Agressor i flipped.
New headlight, has blue (the one i use always), red, flashing red and flashing red and blue like a cop lol.
#2195
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
I like the way you seem to clean everything...I normally do a quick wipe and assemble.
I may take the queue and clean and polish this next build.
I have been collecting stuff for a while and will create a new thread asking which one I should start and finish ove the winter...I like the floor like everyone else!
Ben
Ben
Voltaire
Voltaire
#2197
Quoted: 796 Post(s)
Liked 522 Times
I was very close but was denied a cigar, my short cage derailleur couldn't handle the 12- 32t big cog on the cassette I ordered, which I would have known if I had done the research on Velo Base before I ordered the new cassette, I have a 12-28t 7 speed cassette on order which should arrive Sunday and solve the issue.
so close
so close
#2199
Quoted: 7354 Post(s)
Liked 2,488 Times
Damn it. I stripped out the extractor threads from the drive side crank on my McLean. I don't mind ruining it, as the operation was to replace the cranks, but this is going to be difficult. I'll look for one of those three-arm gear pullers.
While I had the bike apart, I cleaned it a bit. It is not enjoying life in a barn. I have to take it apart and de-rust and grease every damned nut and bolt. The front brake caliper had one arm seize to the center bolt. I overhauled the whole caliper and brought it back to life. It's an old Campagnolo Record single pivot caliper. Well made indeed. I brushed the pieces with a brass wire brush and added grease. I love having a bench vise.
#2200
Old fart
Quoted: 3594 Post(s)
Liked 3,405 Times
Likes For JohnDThompson:
